Canon PowerShot A510 Digital Camera
Date and time reset at power-on
posted by Blaha on Feb 18, 2007
Every time I turn on my camera, the date and time are reset and I am prompted to set the date and time, again. This also occurs when I switch between photo mode and review mode.
While the camera is off, or while I am switching modes, I do not remove the batteries or otherwise "mess with" the camera--it seems to reset itself of its own accord.
Any help would be greatly appreciated; having to fix this every time I try to take pictures is very bothersome and I can't seem to find anything from the manufacturer relevant to the problem.
Thank you!
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 10, 2007
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The other reviewer is close but not completely correct.  For the Canon A510 The "date battery" is accessible under a small tab on the side of the camera near where you plug in the communication cable.   (the access point is not inside the main battery compartment, nor is camera disassembly required).   CR1220 is the correct battery for time/date retention.    The instructions for how to do this are in the A510 manual, if your manual is the same issue as mine, you will find the instructions on pages 137-138.   This is something you can do yourself, no need to take it to a repair shop.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Date and time reset at power-on:
I don't want to Accept this solution
Best Solution
posted on Feb 24, 2007
Helpful (85)
advance
Rank:Guru Guru
Rating: 90%, 344 votes
Canon point and shoot cameras have an internal backup battery (a very small watch battery sized cell). Look under your battery door - do you see a small tab that has "CR1220" or something like that marked on it? If so - this is your backup cell. Just replace it and you will be good to go. If you do not see this, then the backup battery is buried deep inside the camera and would require full disassembly to replace.
David Millier
Advance Camera Repair
Thank You!
Can you Help with these Digital Cameras problems?
On my Canon Powershot A510, the retracting lens cap...
when ever i am on line my computer creashes and says low...
Please let me know how to use canon digital A510 camera as...
when i turnt he camera on i can only review my pictures...
I have a Canon PowerShot A510. I unloaded, deleted, and...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Find Digital Camera Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
