Question about Zanussi TC7102W Electric Dryer
Clean filter light stays on LG TD-C70045E Dryer
Clean filter light stays on, LG TD-C70045E, filters and condenser are clean and dryer will not operate.
  • farmergiles7 Mar 08, 2009
    Ours has this problem but stops half way through a cycle. If you pause and restart it works for a while until stopping again!
    Any ideas?
  • Anonymous Mar 14, 2014
    cl check filter light is on. is there another filter besides the one inside the door of the dryer
I had the same problem. It actually has nothing to do with the filters. If your dryer sounds like it wants to start the capacitor is blown.
Posted on Jan 10, 2009
  • Scott McGarry Sep 29, 2012
    Which Capacitor is it?
Clean filter
If this is a condenser dryer, it could be the condenser unit that needs cleaning
Dec 21, 2013 | Siemens Dryers
Water doesn't go to water tank. Any advice? thanks a lot Peter. LG DRYER TD-C70045E
Try unscrewing the water hoses and cleaning or replacing the filter screens where they screw into the unit and also the valves.
Aug 28, 2011 | LG Dryers
Model: LG Steam Dryers DLEX2501R Problem: Shows "Check Filter", while dryer still does the job
do you mean a condenser dryer?, as steam is water doesn't dry anything to well, if it is a condenser dryer the check filter or clean filter light should always come on towards the end of the cycle (varies between models some have both clean filter and empty tank lights on at end of cycle just as a reminder to do so and some don't have any lights), it is simply a reminder for you to clean the filter after each use unless this is something that has only just recently happened
Apr 17, 2011 | LG DLE2514 Electric Dryer
Cooling light stays on
remover the filter and run it see if that helps or remove the vent from the back
Apr 24, 2010 | LG DLE7177 Dryer
The check filter light keeps coming ob to my lg tromm dryer model dle2514w. I cleaned the lint filter and also cleaned the air duct in theback, what else could this be
Clean the vent all the way to the outside.
The dryer will take 4-5 loads to reset the filter sensor.
Mahe sure the vent is not smashed behind the dryer.
Jan 18, 2010 | LG DLE2514 Electric Dryer
LG TD C70045E dryer not heating up, this has happened before and the guy just pressed a switch but cant remember where it located, please help!
On the LG TD-C70045E the reset button for the heater is located inside the back air-way cover. This is easy enough to remove and the button is obvious once the cover is off. The button will 'click' satisfyingly if it has tripped. Don't forget to switch off and unlug first...
Aug 22, 2009 | Dryers
LG TD C70045E problem
Fluff has blocked the drain hole into the water drawer.Try locating the hole and using a small bore plastic tube **** the debris out of the container.
Feb 21, 2009 | Zanussi TC7102W Electric Dryer
Dryer error code
is the dryer getting hot?
if not turn the power off and pull the dryer out and take the back off and push the red button in at the back
Nov 09, 2008 | Dryers
LG TD-C70045E Condensing Dryer does not heat up, how do I fix it? All other controlls work fine just no heat.
Aug 17, 2008 | LG Dryers
Zanussi TC7102W Electric Dryer Logo
1,800 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
