MY CD PLAYER (IN MY KARAOKE MACHINE) WON'T PLAY ANY CDs. IT JUST SHOWS AN ERROR SIGN. PLEASE HELP :(
  • rblightrb Dec 10, 2008
    Thanks a lot, what you said makes so much sense. I will try it and see what happens, but I feel it will solve the problem. Thank you very much.
    Problem Solver:
  • 5 Answers
Most likely dirty laser head
just need a cleaning cd or if you can see the Head just clean it but becarefull at not moving it
better use a cheapo cd leaner
Posted on Dec 07, 2008
My karaoke machine will not play CDs
the only suggestion I can offer is clean the laser lens with a Q-Tip and rubbing alcohol gently and allow several minutes to dry, if that fails! the whole assembly will need to be replaced.
Mar 15, 2012 | Venturer CD-2160 Shelf System
I have a fleco karaoke machine the problem is that when you put a cd in the machine the word error appears what do i do please help
Hello. These karaoke machines can be a pain in the neck in that not all karaoke CD's work in every machine. Check in your manual to see which CD's are recommended. I had the same problem until I went to the home page for my karaoke machine and found the exact CD's that would play. Good luck with it. J.
May 22, 2010 | Sony STR-DB930 Receiver
My gpx karoke machine will not play at all power is on, shows cd number but no sound at all
Here are some things to try:
  1. Take the cd out, turn off the power, unplug the machine, plug it back in, turn on the power, put cd back in and try again.
  2. Check whether other cds play in it or if is it just this disc. Perhaps the disc is not compatible with the player. Might wanna check on that.
  3. Is the volume knob turned up?
  4. Does the mic work or is it just the cd? This will tell you if it is the disc or the machine that is not functioning properly.
  5. If no compatible disc works and the mic doesn't work and the volume is turned up, it "sounds" like the machine is defective.
Hope this helps. I'm a singer, so I wanna get you singing! Good luck.
Nov 04, 2009 | GPX Karaoke Party Machine CD+G Portable...
AUX connection from Tape Karaoke Machine to CD Player= no music
Probable that it IS Outdated. CD input May be to Hi or Low for "OLDER" Units
Jul 21, 2009 | Pioneer Premier DEH-P480MP CD Player
It wont play CDs
the cds you put in there are not compatible to the player.if it had been playing the same cds then it is time to take your set to a tech for repair it can be your memory chip or your lens.good luck.
Apr 18, 2009 | Memorex MKS5009 Karaoke System w/CD/CD+G...
Karaoke machine wont play cds
I'm having the same problem with mine! As soon as I figure it out, I'll let you know...
Oct 20, 2008 | B&W 5.5" TV/CD+G Monitor Karaoke Machine...
Professional new karaoke system skipping and lyric problems
your disc is scrath or maybe the lens of your player is already weak,or have dust,if you can do the job,clean it with a soft cotton..wipe carefully with only one direction..try also the lens cleaner.
Feb 23, 2008 | Memorex MKS5009 Karaoke System w/CD/CD+G...
Blank karaoke machine
Try looking on the back of the machine for vertical and or horizontal hold controls (marked V-Hold and H-Hold) and try adjusting them, especially the horizontal hold.
If that doesn't help, then the next troubleshooting step would be if the machine has a video output you could try connecting to a TV/Monitor and see if the graphics appear there.
Feb 01, 2008 | B&W 5.5" TV/CD+G Monitor Karaoke Machine...
Problem with Karaoke System Memorex MKS5009
If it was "lying" in the attic, that is in any position other than upright, the drive probably has failed.
Sep 09, 2017 | Memorex MKS5009 Karaoke System w/CD/CD+G...
115 people viewed this question
 Grubhead
Grubhead
