Question about ASUS My Cinema-P7131 (90C1VFV00UAYZ)
Cannot get card to work with video fed to yellow rca plug
Also no audio comes thru usind the red and whire plugs.The sensitivity on TV on the UHF cannel very low buth VHF channels ok.FM portion ok but no joy from rear video in socket and plug at back..How should I do the setting to get this to work??
Thanks Barnie.
  • 145 Answers
You need the drivers
Posted on Dec 12, 2008
Does the Magic Sing ET19KV require a special "3.5mm to 3 RCA" cable? How to get it to work with aftermarket "3.5mm to 3 RCA" cable? "3.5mm to video only" works.
Hi
firstly check that the 3.5mm plug has the same number of contacts as the original there should be 4 segments
The three rca plugs are coloured red white and yellow
white is left audio,red is right audio and yellow is video
usually composite video.
some tv,s have an rca input some have two
and some have rca outputs
the sockets on the tv are also coloured to match the plugs
please check that the plugs are inserted into the correct
coloured input sockets
I would plug in the 3.5mm plug then the yellow untill i get video,once i have video i would connect the red plug untill i have sound,same with the white
Dec 03, 2017 | Televison & Video
I have the 3 RCA red, yellow, white cables on back of dvd and to tv. Video only plays when I select video 1 under the input. When when I select video 3 only sound and no video. What else can I try?
Sounds like from the symptoms that you have plugged the white and red cables into AV3 input on the back of the Teleivsion and plugged the yellow cable into AV1 on the back of the Television.
Check the cables are all plugged into AV1 input ports on the back of the Television. Red and White go into the Audio inputs and Yellow goes in the video input. Also make sure you have not plugged cables into component inputs on television look for AV1 in on back of Television .
Mar 08, 2015 | RCA Televison & Video
Vizio M550SV no sound. Is there an audio card or does the main board have to be replaced?
See page 8 here:
http://cdn.vizio.com/documents/downloads/hdtv/M550SV/991UG_M420-470-550SV.pdf
From the top
- HDMI - both Audio and Video come from device via one cable.
- RF Coaxial (aka CATV) - both Audio and Video come from device via one cable.
- 15 Pin Dsub (they are calling it RGB), Video comes from this cable and Audio is from a dual 1/4" plug (looks like a headphone wire at both ends).
- Component (this is true RGB) uses RCA type cables - two sets of cables, cable one has 3 RCA at each end and they are color coded, as follows Red/Green/Blue, cable two has two RCA color coded as follows White/Red. Cable one is Video, and cable two is audio, total of 5 connections at source and 5 connections at tv.
- Composite AV - one cable set, coded as follows - Red/White/Yellow, Red/White are audio and Yellow is video.
Hope this helps.
Nov 25, 2014 | Vizio Televison & Video
Connecting my new samsung blu-ray player (bd-fm57c) to my toshiba theaterview tv.
I don't think that cord will work. HDMI carries video and audio signals, you might get video but probably no sound. You might as well try anyway though so here goes... The red green and blue plugs are your video and the other red plug and the white plug is for stereo sound. The yellow plug is just a lower quality video plug. So plug in the red blue and green plugs into the component video inputs on the TV then the red and white plugs into the audio inputs. DON'T plug in the yellow plug. If this doesn't work go to your local home theater store and ask for a receiver or switcher that will downscale high def HDMI to component video and stereo audio. You can probably pick up a cheap one for around $100. Good luck!
Mar 29, 2014 | Toshiba 50 Inch Big Screen Flat Tv Theater...
No sound when trying to play back on TV. Can hear sound thru camera but that's it. It's a JVC GZ-HD320
Normally you require a cable to connect to the TV. It should have at least 3 RCA connections to connect to the TV: Yellow for video, red for right audio and white for left audio. The camera connector will have a small stereo type plug that has 3 sections on one stem corresponding to the yellow, red and white cables.
May 13, 2011 | JVC Everio GZ-HD320 Hard Drive Camcorder
I cant connect my wii to my tv. can you give me instructions how?
Most TVs have a yellow video and a white audio and red audio input. The Wii comes with a cable to connect to a TV with a yellow, white and red RCA cable. Plug in the large block end of this cable to the Wii (rectangle block) and the other end into the TV using the yellow plug to the yellow input jack and the white plug to the white input jack and red to red. Select on the TV using the TV remote, the input where the Wii is hooked up. This is the standard way.
Apr 10, 2011 | Mitsubishi Televison & Video
Can't hook-up RCA wires in back of tv, dvd recorder,and directtv dvr I don't know which go to input or output red, white, yellow
from your dvd,plug the yellow to video output red and white to audio output. then plug the other end of the yellow to video input on tv and the red and white to audio input on tv. from tv, plug the other rca cable yellow to video output and red/white to audio output and the the other end yellow to dvd recorder video input and the ed and white to audio input
Nov 13, 2010 | Hyundai Televison & Video
RCA LCD Flat Panel HDTV and RCA Home Theater System--No sound
Video comes from external device to TV - OUT on device and IN on TV.
Sound connects by the red/white cable set (or HDMI). Place set in Audio OUT ports on TV and Audio IN ports on DVD. Then select AUX IN on DVD.
Jan 05, 2010 | RCA RT2380 Home Theatre System System
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
I HAVE A RCA TELEVISION, MODEL F20632. I CANNOT FIND THE MANUAL TO HELP ME SET UP MY VCR. I HAVE A 4-PLUG VIDEO CABLE (YELLOW, BLACK, GREEN AND RED). CAN YOU TELL ME WHICH CONNECTIONS ON THE TV I NEED TO...
the yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Jan 05, 2009 | RCA F20632SE 20" TV
ASUS My Cinema-P7131 (90C1VFV00UAYZ) Logo
238 people viewed this question
Top ASUS Televison & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Michael Galve
Michael Galve
David Payne
David Payne
Are you an ASUS Televison and Video Expert? Answer questions, earn points and help others
