Question about Samsung YP-U3 MP3 Player
How to rest
Hello, I bought it 2 months ago, I just press some buttons at the setting panel, my last remember I press for default then it turn off, I try to open it again but none . I want to reset it, but where to find the reset button?
  • qalveen Dec 15, 2008
    tq, i Just got it
  • 8,596 Answers
  1. Turn the power on.
  2. Press and hold both the [MENU] button and the [A/B] Button. The device will turn off.
Posted on Dec 15, 2008
I have an Emerson 900W Microwave MW8999SB and it will randomly assign DEF1 and the rest of the keypad is difficult or not functioning. None of the quick buttons work, and only the 30-second button works....
Pressing the Clear/Pause button works. Sometimes. Most of the time, about a microsecond after pressing Clear/Pause, it goes right back to def1. Most of the time, pressing ANY button doesn't work. Usually takes me 10 to 20 tries to get anything to work. My microwave is about 3 months old. I will never buy Emerson again.
Sep 27, 2013 | Emerson MW8168B Microwave Oven
Cant turn on set and remote wont work, how can I reset tv and remote to work after our grandchildren locked the fromt buttons ans remote?
hello it sound like the key lock has been activated
The TV can be set up so that it can only be operated with
the remote control.
This feature can be used to prevent unauthorized viewing.
This TV is programmed to remember which option it was
last set to even if you turn the TV off.
Press the MENU button on the remote
control, then use the UP/DOWN arrow
button to select the Special menu.
Press the RIGHT arrow button to activate
the Special menu.
Use the UP/DOWN arrow button to
choose Key lock, then press the RIGHT
arrow button.
Use the UP/DOWN arrow button to select
On or Off.
Press EXIT button to save and return to
TV viewing or press the MENU button to
save and return to the previous menu.
the remote control.
Language
Main Source
PIP Source
Captions
Caption/Text
ARC
Key lock G
Auto Convergence
Auto Move
F Back Next G
SETUP
VIIDEO
AUDIIO
TIIME
LOCK
SPECIIAL
On
Off
With the KEY LOCK ON, the display
'KEY LOCK' appears on the screen if
any button on the front panel is
pressed while viewing the TV.
which option it was last set to
even if you turn the TV off. good luck
regards
shaun
Dec 12, 2010 | Zenith R56W36 56" Rear Projection...
I have no hot water at all. just bought this house in florida and it was working when it was inspected 2 months ago. is their a switch to turn it on or off?
Well there should be a circuit breaker in your panel. Be sure it is on. If the water in the house was OFF while the heater was on, the element(s) could have burned up. You can go to Reem's web site and download a manual for the water heater. It will depend on your experience as to whether or not to work on this. On must follow safety procedures to work on a energized water heater for testing. There is a high limit reset button under the cover that houses the thermostats. I would recommend turning breaker off before opening this cover. The rest is a red button. Remember electric and water don't mix.
Oct 31, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
I bought a new OfficeJet. How do I change the date
Hello and Welcome to FixYa!
You can change the Date on the front panel of Office-jet 6500 by following this;
  • Under the display window press the "Setup" button (located below and left of the "OK" button).
  • It should now show a "1. Help Menu".
  • Press the Right or Left arrow next to the "OK" button until you reach "6. Tools".
  • Press "OK" again and you should now see "1. Date and Time".
  • Press "OK" again and it should show "Enter date:" You will probably figure the rest but I will continue for continuity.
  • Below it will show "00-00-00" and "m-d-y". You won't need to enter the dashes(-), just the numeric month, day, and last two digits of the year.
  • Next of course will be the time (in 12 hour mode). Lastly it will ask to enter 1 for AM or 2 for PM.
  • I forget some of the specifics such as exactly when to press "OK" during the last parts but this should get you where you need to be..
Note: the little columns under the date are ink levels so don't let this confuse you.
I hope this will solve your query, if in case yo are still having issues, do tell me.
Concerned, Nooh
Aug 12, 2010 | HP Officejet 6500 Wireless All-in-One...
Don't know access code. Bought used control panel
2. Unplug the transformer and disconnect the battery.
3. Simultaneously press and hold Cancel, Clock Set, and
Minutes +.
4. Restore power to the panel with either the battery or the
transformer while pressing these three buttons. The
panel announces “Hello. System XX OK.” Release the
buttons.
5. Connect the remaining power source to the panel.
- AlarmProfessor.net
Jul 16, 2010 | GE Security Simon 3 Wireless Home Security...
Motherboard failed problem?
probably by changing seetings. if it was in the bios ( where you go when you press f2 when it loads up) then jsut set all teh setting back to default. if its the software on the haradrive itself then just do a system recovery of the opperating system
Jan 13, 2010 | Computers & Internet
Shutter don't stop halfway
Yes, there is a small 2-stage micro switch that needs to be replaced. 1st stage is permanently pressed and not switching/returning back due to so many time it's been pressed.
It just time. Switch is right under top cover.
Apr 26, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
How do i turn off my lock on my tv
Hello there. This is taken rigth from the manual...
To reset to the default factory settings, follow these steps.
1. Press the MENU button on the remote control to
open the OSD.
2. Press the Navigation (UP/DOWN) buttons to
select the Options menu.
3. Press OK to open the menu.
4. Press the Navigation (UP/DOWN) buttons to
select Factory Preset.
5. Press OK.
6. Press EXIT to close the OSD.
You can find the rest of the manual here.
Dec 03, 2008 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Whirlpool duet dryer
Try pressing the End of Cycle button on the far right and holding it for more than 3 or 4 seconds.  It should reset.
Jun 01, 2008 | Whirlpool GEW9250 Electric Dryer
Blurred pictures in auto mode
it is probably a camera shake problem. Consider using a tripod. Also, using higher ISO helps..Using flash helps too.
Jan 03, 2008 | Nikon Coolpix 5600 Digital Camera
Samsung YP-U3 MP3 Player Logo
53 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
