Question about Sony Ericsson Walkman W810i Cellular Phone
W810no network coverage
Signal is weak
  • 54 Answers
Well its not your mobile problem sometimes the service providers signal become weak or in simple way dont able to reach to your handset
try to insert sim of other service provider if problem still persist than it must be your handset problem
try to consult your authorised dealer
Posted on Dec 10, 2008
Signal weak
I'm assuming that your cell phone works fine.
Your cell phone gets its signals from cell towers serving your cell phone service provider, e.g. Sprint, AT&T, Verizon, T-Mobile.
If you are in a building or elevator, your signal can be weak. Try going to the edge / side / top of a building, like by a glass window to see if the signal is stronger.
Or if your cell phone service provider (phone company) doesn't have a cell tower close to where you are, the signal can be weak or nil.
You can find out your cell phone company's cell tower coverage areas ...by checking their website. If you are at locations where your cell phone service provider has good coverage, you will get stronger signals. Otherwise, expect to get weak signals.
Yes, it's always prudent to check which cell phone service provider has good cell (tower) coverage in areas where you are (using your cell phone) most of the time, and subscribe to that company's cell phone service.
Nov 04, 2013 | Samsung Star Cell Phones
Nokia c2 00 phone say no network coverage problem
Nokia c2 00 phone say no network coverage problemjust make jumpaer v- vat to pf.... power ic or pf is always ok in ths problm
Dec 02, 2012 | Nokia mobile C2-00 Dual SIMbiosis
My nokia n70 not net work coverage
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company
Nov 06, 2012 | Nokia N70 Cellular Phone
My mobile has a special problem. The mobile shows a weak signal and sometimes zero signal at my home even though the other nokia mobile signals are very high at my home.(same network other nokia mobile...
Are they the same models?
The phone's capability to sustain a stable network coverage may vary even in model types.
While at your home,remove the phone's battery and simcard and fit them again.
Note how the phone's network signal registers.
It may start very high and then drop drasticaly to very low or no signal at all or sustain a constant signal reception.
If the reception's good in other areas,then your home area's network coverage may not be that good.
Hope this helps.Thanks!
Oct 31, 2011 | Nokia Cell Phones
BlackBerry Curve 8520 signal swing
#1 Your BlackBerry does not have sufficient Power
Check the battery charge level as shown by the battery icon on the top left of the home screen. No Power - Battery Charge Indicator does not show a charge or is very weak. The battery icon may be red. Charge the battery.
#2 You are Out of Network coverage area
Check the Signal Strength Indicator on the home screen. (1 to 5 bars, as shown below, indicating signal strength). If there is no signal, you may be out of range of the network.
If you are sure you are in range of the network, but show no signal strength, press Alt-Right Shift-Del at the same time. This will cause the BlackBerry to reacquire a network connection.
The process for this procedure is:
  • Press Alt-Right Shift-Del (The Del key is also the Backspace key.)
  • The screen will go blank, and an hourglass will appear. Wait for the hourglass to go away.
  • The startup screen will appear. Wait for it to go away.
  • A screen that says Verifying Security Software will appear. Wait for it to go away.
  • Check the Radio Tower icon.
If you are in Coverage Area of your Service Provider, You will get the network.
#3 Your Data plan is switched Off.
Feb 22, 2011 | RIM BlackBerry Curve 8520 Smartphone
Hello.. look.. here is the problem. i have a samsung s5230 star since the begining of this year. since two weeks ago my phone only shows limited service or no service. however sometimes i have signal .....
Your phone can't seem to locate signal on your are that's why it says No service. There;s nothing wrong with the phone, it's more on the signal coverage of your netwrok provider. There are some areaas that have strong signals and some areas that have weak signals. You may also want to contact your network provider about it.
Aug 28, 2010 | Cell Phones
Sir my pfone not show network
As you are not getting network, below are the possible causes for that,
1. Your phone is not receiving any radio signals or the received signal is too weak.
Contact service provider and make sure that the network has a coverage where you are.If so try to do new search.
2. SIM card is not working properly.
Insert your sim in any other mobile. If you still get the same or similar message please contact your network provider.
3. Phone is not working properly
Insert your sim in any other mobile. If it works then the problem is with the mobile only. Please go to the nearest authorized dealer of your mobile make. They will rectify the problem.
Thank You
Aug 17, 2010 | Samsung SGH-J600 Cellular Phone
No network coverage
Phone is not receiving any radio signal / received signal is too weak:
Confirm that network coverage is available where you are by contacting your service provider.
SIM card is not working properly:
Insert your SIM card into another phone
Note: Contact your service provider if you get the same message again.
Phone is not working properly:
Insert your SIM card into another phone. If the second phone works with the inserted SIM card, then
the problem is probably with the first instrument.
Note: In this case, contact your nearest Sony Ericsson service center regarding your phone problem.
May 30, 2010 | Sony Ericsson Walkman® W995 Cell Phone
No signals
Hi kccute61,
Network connectin does not depend on the mobile model, it depends on the connection service provider that you have, Network coverage will not be there if you are in a place where for a few miles there are no tower of your service provider, if you are in a place where there are proper power signal and still you dont have proper network coverage then check whether you are in a closed room where no signals can enter, you will get the connection once you come to open places where your mobile will sense the signal,,,,,,,,,
Please leave me comment, if you need further assistance
good luck with your fix,,,
have a nice day,,
A VERY HELPFUL RATING IS APPRECIATED,
Thanks
Regards
Arul
Mar 10, 2010 | Nokia 3200
No network coverage/signal problem
i had no display on my nokia 3230 cellular phone. now its ok but it has no network coverage/no signal . plz help me..... .
Sep 24, 2008 | Nokia 3230 Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
188 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
