Question about GE Spacemaker JVM1640SJ Microwave Oven
Intenal Fuses for Lights
One of the over stove lights on my GE spacesaver microwave blew and it seems to have taken an internal fuse (I hope) with it. Are there internal fuses and how do I get to them? Do I have to remove the oven and disassemble?
  • GE Master
  • 9,086 Answers
In some cases, it may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
In some cases, a light failure where a bulb shorts can damage the control board itself.
If the problem is on the control panel, we regularly repair these for customers nationwide by mail for $39.95 postpaid in about a week.
Feel free to contact me
directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 13, 2008
GE Spacemaker microwave makes groaning sound when start button is pressed for a second or two then blows the internal fuse. After replacing the fuse everything seemed to work, lights, exhaust fan, cl
Could be a lot of things but most probably a shorted high voltage diode assembly. If not that then the magaetron or capactors. Remember be careful there are high voltages even when the oven is unpluged. The capactors are usually charged and must be discharged. If you don't know what yor doing then time to get a qualfied tech.
Good luck
Feb 14, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
No power - blown fuse?
If it was run without the fan a thermal protect device was more than likely taken out. Check for that and replace the fan.
Mar 25, 2013 | GE Profile Spacemaker XL 1800 36"...
My GE Hvm1450dniww over the stove microwave won't
May be an internal fuse that has blown
Sep 13, 2012 | Microwave Ovens
My GE JVM1750DM blew an internal breaker or fuse when I attempted to remount a lamp lighting the stove top; it had fallen out of its mount. Where is the internal reset or breaker located, and how do
There are fuses inside the unit. No internal breaker. A lot of the time that damages the main circuit board too. Blowing the trace that supplies the power to the bulb off of the board. will probably need a new baord, or someone to repair that one.
Sep 24, 2017 | GE JVM1750DM Microwave Oven
My GE Spacemaker 2.0 over the counter microwave just died. No lights or anything.
Hi, It sounds like the internal fuse blew. To get to it, the case has to come off the unit and its located close to where the power cord ties in. With any and all microwaves, It is a good idea to put a surge protector on the plug to plug microwave into. Hope this helps.
Jan 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacesaver xl just died. No fan, no lights, no power. Where should I go to repair? I live in Las Vegas
Might want to check the 20A fuse by the power supply before you haul it somewhere and they charge you a service charge for a cheap fuse...
Nov 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave not heating lights and keypad functional
You may have a fuse blown on the micro/ the vent and lights are a diffrent cercut , Try replaceing the fuse. its on the in side of the unit. if you need further assitance and you think you can do this I will be happy to instruct U DFD
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacesaver oven JVM230 quit, like a fuse blew. No over the stove light, no exhaust fan, nothing. I checked the circuit breaker and pluged in an appliance and it worked. The plug is okay. Jim
This is almost certainly a blown thermistor. This device is located at the air outlet on the microwave. This is a thermally sensitive resistor that cuts power if the unit overheats for safety. It can fail because of age also. Replace with the save value unit. You can get this part from electronics stores like Radio Shack.
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JVM1640SJ
click on your model number. Then on the next page you can select diagrams to look at.
Mar 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Blows internal fuses after replacing
Did you use correct fuse??? REMEMBER MICROWAVES CAN KILL EVEN WHEN UNPLUGGED
grandadfixer
Apr 30, 2008 | GE JVM1850 1000 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
