Question about GE Profile JT955SFSS Electric Double Oven
UNABLE TO USE MY BOTTOM OVEN DUE TO LOCKED DOOR INDICATOR
Locked door light flashing for bottom oven, I am unable to bake, broil or even self clean. I tried the GE tricks to clear the problem- open the door, press in the light button/door shut button, then press the clean button for 10 seconds, when cycle starts quickly press the clear off button- the cycle never starts. I checked the circuits involved on the sensor and lock switch connector, temperature probe reads 1100 ohms, voltage thru the correct limit switches and thermal switch--except that voltage at the door latch output pin is supposed to read -25VDC it is -11.81VDC instead, although the upper oven reads the same and does not have an issue.
  • 87 Answers
You have a bad clean microswitch in the back of the oven
Posted on Jun 14, 2007
Door locked wont self clean
Turn off breaker for minute or so if no contact repair man mcro switch bad or out of position. Did he try to pull door right after candle. The motor takes time to clear the hook from the latch. If so he probly bent some thing in the mech that latches the door or on the switch plate that holds the micro switch
Apr 25, 2017 | DCS (WOTD-227) Double Oven
The oven is stuck at LOC.
The locking motor has gone bad on the range. Common for this to happen after self clean. You will have to replace or have the lock assembly replaced for the stove to work again
Mar 06, 2010 | GE JKP45 Electric Double Oven
Self cleaning gas range: Bake and broil will not light up.
the thermal fuse in back is out. sometimes they are resetable
Feb 09, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
I can't get oven to work on broil or bake; only self-cleaning.
Hello
Welcome to Fixya
My name is Huum,
Try turning the breaker off for 5 minutes and see if this resets the system.
if not you may have a defective Control board and you will need to have a HANDS on tech to diagnose these parts to be sure! They will have the diagnose equipment !
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 21, 2008 | GE Profile JTP18 Electric Single Oven
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
GE OVEN SINGLE ELECTRIC JKS05BW
I have the same problem. Mine is a self-cleaning oven. But I'm just preheating it 450 and it did it. Then this AM it did it while broiling.
Apr 09, 2008 | GE JKS05 Electric Single Oven
GE Profile JT955SFSS Electric Double Oven Logo
324 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
