Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Motherboard drivers
rashmitiwari on Dec 07, 2008
I purchased my laptop 3 months ago. I formatted my system a month ago due to virus then i loaded WINDOWS XP 2000.After that i loaded its drivers from net but they are not supporting them. Dealer told that they would support only if I load windows VISTA. O.S.I am having this problem since a month.Kindly help me out please.
Company:COMPAQ-HP
Model:Presario F7300
Model no: F739AU
City: Ludhiana
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
Posted by Nic61 on Dec 07, 2008
Exactly which driverer aren working for you?
Here are all avalible working drivers for Compaq Presario F739AU Notebook PC with windows 2000 on HP:s suporter site:
"The following software and drivers are compatible with your product and the operating system Microsoft Windows 2000
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=181&lc=en&dlc=en&cc=us&product=3674876&lang=en
Good luck
Solution #1
posted on Dec 07, 2008
Not Rated)
DGKodak
Rank: Apprentice
Rating: 0%, 0 votes
I contacted HP the other day for a problem while trying to load XP on a VISTA box. They sent me to this site.. and gave me instructions for resoluation or at least an attempt.. Hope this helps
Thanks David
Let me know it if works for your problem
Solution: The reason for this error message is that notebook has been shipped with SATA hard drive i.e SATA hard drive controllers. But Windows XP does not have built in SATA controller drivers.
To solve this problem we need to install SATA Controller drivers before we install Windows XP using a USB floppy drive.
Many customers are not ready to buy USB floppy drive and installation of XP is so complicated using USB Floppy drive.
We have found the driver for the SATA controller on Intel Website. Customer has used it and installed retail Microsoft Windows XP with SP2 successfully on his dv6500 notebook.
The same can be achieved in all the dv2500, dv6500 and dv9500 also DV2600, DV6600 and dv9600 notebooks.
Here is the link for the SATA drivers:
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&lc=en&softwareitem=ob-39535-1&jumpid=reg_R1002_USEN
1. The file contains the Intel Matrix Storage Manager Floppy Configuration Utility.
2. This utility will create a floppy disk containing the RAID driver files for installation on a 32-bit operating system.
3. This floppy can be used to pre-install the Intel Matrix Storage Manager driver during the F6 portion of Windows setup.
4. You needs Microsoft Windows XP with SP2 Operating System disc and the USB Floppy drive.
5. After downloading the SATA driver in another notebook, you needs to extract and execute the file. It will help in creating the floppy disk that has the SATA drivers.
6. Boot with the Microsoft Windows XP disc and make sure the USB floppy drive with floppy disc is connected to the notebook.
7. At the F6 prompt, select F6 to install additional drivers which are not in-built in the retail Microsoft Windows XP Operating System disc.
8. When the prompt comes up to install additional drivers, insert the floppy and select the correct SATA Driver. It is Intel 82801HEM/HBM SATA AHCI Controller.
9. Once that is done, the rest of the installation runs as normal. There are only 2 drivers in the floppy disc that would work.
10. After the Operating System is installed in this manner you can install the chipset drivers for the notebook.
11. However for the other device drivers once Microsoft Windows XP is installed you may not have them from HP as these series are not released with a Microsoft Windows XP Operating System. The drivers like audio, ethernet and media card reader drivers etc.
12. Please be sure with EU that he might not have the other drivers from HP after installing the retail Microsoft Windows XP.
Note: Do not click on the link. Copy and the paste the link into the address bar of the web browser.
If the above solution does not resolve the issue, please login to chat support with the results of the above troubleshooting steps. Also, please use the same email ID.
Was this helpful?
Yes
No
Related Problems
my compaq presario acts like it wants to come on and then...
I have a compaq presario c500 that will either not come on...
after formatting my compaq presario v2000, i cant unlock the...
I just installed winXp SP2 to my Compaq cq40-133tu.I need...
Can you Help with these PC Laptop problems?
i purches compaq cq45-106 AU lap top...
Solve
i purches compaq cq45-106 AU lap top i have problem with vista my old software not installing so i... (More)
hp pavilion dv4 series
Solve
I have installed xp all driver installed but audio driver installed than extranal speaker &... (More)
cant get pass this
Solve
atapi cd-rom: cd-rom cdr_u112 error 0210: stuck key 3d when it tills me to boot i do and i get this... (More)
Sponsored Links
Describe your Computer problem:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more PC Laptop Experts
Top Computers & Laptop Repair
(601) 918-0222
I will connect to your Computer and repair the...
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
