Question about Brother XL-5340 Mechanical Sewing Machine
Brother sewing machine
Tension is to loose
    Problem Solver:
  • 6 Answers
Try using a brush between the tension discs, there maybe something stuck in there that is reducing your tension.
Posted on Jan 16, 2009
My stitching on Brother ls 2020 sewing machine is loose. How do I fix the problem
Without more description of the stitch symptoms, the only suggestion is that the tension is too loose. Whether it is the upper, bobbin, or both tensions, we cannot answer without more information.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Dec 31, 2016 | Brother Sewing Machines
The tread under my fabric is loose and slack when I sew with my brothers LX3125 sewing machine please help
increase top thread tension a little, make sure that the top thread is between tension discs.
Oct 27, 2015 | Brother LX3125 Sewing Machine
How do I adjust a too loose tension?
Sound like your top thread tension is loose try increase the tension.
Dec 20, 2013 | Brother CS6000i Computerized Sewing...
Brother vx1090 can't move tension dial
I suggest taking the machine to a sewing machine shop & let
the technican look at the tension & see if it needs to be replaced
Jul 30, 2012 | Brother Sewing Machines
I have a Brother LS-1717 Sewing Machine, it was given to me, without the manual. My thread keeps jamming and the thread is lose on the fabric. Also I have these dials on the front and I can't figure out...
You really need a replacement manual and Brother is excellent about providing them. Go to http://www.brother-usa.com/manuals/ if your machine was sold in the U.S. If not, you'll need to contact Brother International.
Loose thread and jams usually mean the tension needs adjusting. If the loose threads are on the underside of the fabric, it means that the tension on the top thread is too loose. Be sure to have the pressure foot down when you adjust the tension and only move the dial a tiny bit at a time. Also, when you begin sewing, hold the top and bobbin threads securely in your left hand for the first few stitches. That bit of tautness helps prevent 'birds nests'.
Hope this helps!
Robbie
Aug 10, 2010 | Brother LS-1717 Mechanical Sewing Machine
My brother LS-1520 sewing machine is having major tension problem
Try some metal bobbins, #15 or SA 156. that seems to help. If, you don't have a manual go to brother.com and download one for free
Jul 19, 2010 | Brother LS-1520 Mechanical Sewing Machine
I HAVE A BROTHER LS-2125 SEWING MACHINE AND THE STITCHING UNDERNEATH IS OK BUT THE UPPER THREAD IS LOOSE AND ALSO SKIPS
Sounds like either the bobbin case tension is too light or is not in the tension at all.
Consult your manual for how to place the thread in the tension and retry. Increase the bobbin case tension if necessary.
The top tension may be set too high.
Jul 11, 2009 | Brother LS-2125 Mechanical Sewing Machine
I'm having troubles with my brother sewing machine
Your tension is loose on top. Adjust your tension dial up a little at a time until you have a desirable stitch. Before adjusting the tension, you may want to look into the tension and see if there are any threads caught between the disc. If so remove them. Another common problem is that your machine is not threaded properly, make sure the pressure foot is in the up position when threading and if needed consult your manual for the proper threading diagram.
Jan 16, 2009 | Brother LS-2125 Mechanical Sewing Machine
Boobin tension is to loose
that means your top tension is incorrect, be sure to make sure your machine is threaded correctly and that your tension assembly is working correctly,,,,,,easy fix!
Jan 22, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother XL-5340 Mechanical Sewing Machine Logo
134 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
