Question about Philips AZ1303 Radio/CD Boombox
Intermittent sound level on CD only
When playing a CD only the sound level may be low. Setting the handle down with a small tap will bring the sound level back to normal. i am not shure if this a bad solder connection somewhere in the unit or it is part of the CD player that has a problem. sound level on radio and Casette is fine and it happens on all Cds . Thanks for any help (ps there is enough torx screws with various lengths that you would need to buy a entire screwdriver set to take it apart.)
2 Suggested Answers
fairlane
  • 50 Answers
SOURCE: CD Player Does Not Read CDs
Hi As you describe the problem, there are three likely possiblities, either the laser lense is dirty, the laser is beginning to fail, or there is a dead spot developing in the spin motor. Cleaning is the first step, and the least expensive...If you have some electronics experience, they are not difficult to clean, but you must expose the laser to do it, and I don't want to advise someone to do that, and forget to unplug the unit. It's free laser eye surgery, but I doubt you would be happy with the results. I would advise you to call around to local repair shops, and see what they charge to check it out and/or clean it, and then descide if it is worth proceeding. Hopr this helps, good luck!
Posted on May 02, 2007
How to adjust the volume on Kindle pad
To change the volume level of your Kindle Fire follow the steps below:
Locate the gear at the top right of your screen.Tap the gear to bring up setting options.The slider below the few setting options is the volume level. Tap the sliding ball and slide it to the left to turn down the volume.Quick Tip - Turn Down (Or Up) Kindle Fire Volume - The ***** Tabletthenakedtablet.com/change-kindle-fire-volume/
Apr 01, 2018 | Tablets & eReaders
Electric blanket blinking,not heating
Live in North ,gone through a few of these puppies,Some of them flash to indicate they are on but not heating,usually a timer override safety issues. In the cases just push setting but to desired level.If however you only have a high/low setting or off on switch with not level settings and light is blinking,hate to say it,but it's gone to a better place.Sounds of taps playing in distance.
Dec 29, 2016 | Home
I have a 2004 ford f150 making a tapping noies can it be the cam phasers going bad
check oil level ---yes it can but tapping noise can be a lot more reasons --worn oil -low oil pressure--low oil level--rocker loose-worn or damaged lifter-worn damaged valves --timing chain --water pump--pulley --really anything can cause a tapping noise --try to isolate the area or sound and diagnose problem
Sep 21, 2016 | 2004 Ford F150
When we are trying to get a reasonable level of sound for vocals before it gets loud enough to be able to hear clearly with the band playing it starts to clip at the speakers now we are only using this set...
Proper level setting of the mixer is important. HOWEVER if the clipping is occuring at the speakers the only possible problem MIGHT be that you have a supersonic feedback that is saturating the speakers above your hearing range, Be sure you don't boost the highs too much with the EQ as this can cause the feedback that you can't hear. Also make sure that you power the speakers from the SAME receptacle as the mixer, even if it means running an extension cord to bring power to the mixer. This is to avoid a low frequency hum and common mode distortion/damage. A low frequency hum could cause the clipping.
It would be a good idea to get a sound meter to check the sound level. You should be able to reach 85 Db from this system without clipping. If you need more than that, you MAY need more speakers if the band instruments are too loud. Also if the band has amps that get into the vocal microphones that adds to the clipping level... make sure the mics don't "hear" the band instruments. Make sure your speakers are toward the audience from the mics to avoid the supersonic feedback problem. If the vocalists can't hear themselves with that configuration you need to set up seperate stage monitors.
There are some pretty good videos on YouTube about proper mixer level setup.
Jan 30, 2011 | Behringer Xenyx X2442USB / Harbinger...
I get a red light on the back panel labeled power. No green light. I don't think the PV 600 is working but when I run the channel check through my Pioneer THX receiver I hear sound. Any thoughts?
The PV600 and PV400 have auto-on circuitry that turns the subwoofer on when a signal is presented, and turns off if no signal is detected for 15 minutes.
http://www.retrevo.com/support/Boston-Acoustics-PV600-Subwoofers-manual/id/522dj484/t/2/
Not knowing which Pioneer receiver you have I have dropped in the steps for No Sound from Subwoofer:
• Check that the subwoofer is connected properly, switched on and the volume turned up.
• If your subwoofer has a sleep function, make sure it is switched off.
• Make sure that the Subwoofer setting is YES or PLUS (see Speaker Setting on page xx).
• The crossover frequency may be set too low; try setting it higher to match the characteristics of your other speakers (see Speaker Setting on page xx)
• If there is very little low frequency information in the source material, change your speaker settings to Front: SMALL / Subwoofer: YES , or Front: LARGE / Subwoofer: PLUS (see Speaker Setting on page xx).
• Check that the LFE channel is not set to -80dB , or a very quiet setting (see Bass Peak Level
on page xx).
• Check the speaker level settings (see Channel Level on page xx).
Regarding the Large vs Small assignment of speakers, what they mean isn't so much the physical size but the ability to handle real bass. Large if Yes.
Jan 12, 2011 | Boston Acoustics PV600 Main / Stereo...
Please help me on this. i have a problem on my scooter, yamaha majesty 125 year model 2001. t doesnt start. there is no sound respond from the engine and from the starter itself, as in completely silent....
Check the battery for charge and the connections for corrosion. Small batteries tend to lose water--check the fluid level in each cell--bring the level up to the upper line with distilled water only--not tap water. You may need to put it on a low current charger for 6-8 hours. Hope this helps!
Sep 29, 2010 | Yamaha TW 125 Motorcycles
I have a pioneer DEH-p3100 and I dont understand all the different levels and at what HZ to put the low high and mids at. i have (2) 12" kenwood speakers and a 600W alpine amp. I am lost when it comes to...
dude honestly you could get 101 answers for this and 101 oppinions a real person who knows what there talking about will tell you put on a sound cd with high and lows made for sound testing and play with the setting to you get the best sound to your ear every system is different even if i had the same system i would want mind different because of maybe different cars subs facing different way.prted boxes theres just to man options....so it comes down to you having to play with it and use your headunit manual or find a printout for the basic controls so you actuall know what your changing around till you find the best sound
Jan 15, 2010 | Pioneer DEH-P3100 CD Player
Sound from stereo goes on/off intermittently. Stereo power remains on, but sound will go off whether you are listening to the radio or a cd. Is there a seperate amplifier hidden somewhere?
It might not be the answer but do you have Traffic News set up? Many radios have a different volume setting for Traffic News which may have been set to a low level. Try turning the volume up when it has muted and it may solve it.
Oct 15, 2009 | Mazda 626 Cars & Trucks
Low volume from CD and iPod input
in audio system you have three different levels.
1-mic level which is very small output level.
2-line level(like cd player output)which is higher than above.
3-speaker level is highest one which drive speaker and get sound out from it.
if you want to get control for number 1 and 2 you can use very simple sound mixer.(from radio shack-or other electronic store)
connect your sound source(mic-cdplayer)to the mixer and get out from mixer to amplifier.
Jan 23, 2008 | Peavey Escort 2000 Microphone
Bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Feb 25, 2007 | Bose Wave Radio
Philips AZ1303 Radio/CD Boombox Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
