Can't get the compressor to turn on on the A/c
You need a technician. The system could be out of refrigerent, and this causes the low pressure switch to open thereby prohibiting the compressor clutch from functioning. The electromagnet in the clutch could have failed or it could be a switch or fuse problem. My guess is the low pressure switch though.
SOURCE: 98 gmc serria slt air condition clutch not engaging when calling for a/c
Your A/C compressor clutch is controlled by the A/C compressor clutch relay, which is in turn, controlled by the Vehicle Control Module (VCM).
There is no "POWER" for the compressor clutch going into the back of the compressor. The connector at the back of the compressor is the A/C low pressure cutout switch, which only sends a signal to the VCM to let it know if there is enough freon in the system to allow the compressor to run. Poking around on this connector with the wrong equipment or with the wrong hook-up can cost you the price of a vehicle control module (VCM) in the blink of an eye...not good to be messing with stuff if you do not know how it works...could end-up being EXTREMELY expensive!
Your system is most likely leaking, and therefore, does not have enough freon for the compressor to operate without destroying the compressor. In this case, the VCM will not allow the clutch to engage. The fix for this would be to have your system tested for leaks, repaired, and recharged.
Other than that, the only advice I have for you is to scan your VCM for possible fault codes to help pinpoint the cause.
Please note that most generic OBD code readers CANNOT perform this function.
