Question about Splendide 2000S Vented Washer/Dryer
WD200S overfills with water
I have a Splendide WD2000S Washer/Dryer in my RV.
Yesterday, it filled with water but didnt stop filling - so much so that it overflowed thru the external Air Vent.
I had to keep setting the machine to the drain cycle (about a dozen times) to get it to empty.
Thinking it was perhaps a one-off, we tried again and the same thing happened.
Any ideas please?
Rob
  • robmoggan Dec 07, 2008
    Unfortunately, the washer/dryer is in my RV in the UK.
    Would the "water level switch" have a part number - better still a service manual showing where it goes?
    Can you suggest anywhere to order the part please?
    Thanks!!
  • Splendide Master
  • 3,463 Answers
Sounds like the switch that detects the water level is malfuntioning, this can be caused by one of several reasons.
I assume that the water stops running in if you stop the m/c, if it does not, then you have a faulty water inlet valve, which you would have to replace.
I think you neede to call an engineer.
Hope this helps.
Please leave feedeback.
Posted on Dec 07, 2008
Splendide Comb-o-matic 2000 how do you vent it to the outside
Use 2.5" plastic pipe & elbow to replace aluminum elbow & hose with spring inside. Air velocity is higher, lint blows out without collecting.
I used wood router to remove part of exhaust connector on rear of dryer to better fit elbow. Elbow interior was smoothed to prevent lint sticking. Elbow was mounted with silicone sealant and 2 screws. Pipe was glued to elbow as normal glued pipe connection. Pipe end was cut even with side of dryer.
After Spendide was installed in RV, a union was stuck in from outside RV. Union slides on to pipe without sealant so Splendide can be removed from RV. Union better fills outside vent fitting than bare 2.5" plastic pipe. Temporary seal aroung union was made of urethane foam scraps, common shipping stuff from a computer monitor box. After 2 years of temporary, the foam is now considered permanent.
Original problem was constant lint problems in hose and slow drying. With pipe, not hose, lint is rarely cleaned and drying is much faster.
Dec 26, 2008 | Splendide 2100 Vented Washer-Dryer
Splendide 2000S
www.splendide.com
1-800-356-0766 #5 (503-656-2280)
503-722-9202
service@westlandsales.com
Monday-Friday, 7:00am - 4:30pm (PST)
You may also want to try a RV retailer in your area, they may direct you to a used part.
Jun 10, 2008 | Splendide 2000S Vented Washer/Dryer
Low water
water level is not detected means there is the problem wiht the sensor
Mar 17, 2008 | Splendide 2000S Vented Washer/Dryer
Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Mar 13, 2008 | Splendide 2000S Vented Washer/Dryer
FE error?
But does anyone knows what FE means?
Mar 05, 2007 | LG WD-3274RHD Front Load Washer / Dryer
Splendide 2000S Vented Washer/Dryer Logo
154 people viewed this question
Top Splendide Washing Machines Experts
Doug Adams
Doug Adams
isaac johny
isaac johny
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
