I recently purchased an old IBM Correcting Selectric II; I have everything working (I think), but my big problem is the "carriage return". It will scroll the page up as it should, however it only jumps and jerks toward the left a few spaces at a time. It is almost as if the tab sets are working backwards; the carriage won't return to the left margin except when I continue repeating the Return button.
  • 365 Answers
The motor driving it may be damaged .try to check it
Posted on Dec 07, 2008
IBM Selectric II jammed
The lubricants dryp over the years. Try spraying everything with WD40 you can't hurt it.
DickyO
Feb 23, 2013 | IBM Correcting Selectric II
Selectric II Pitch-shift lever won't change from 12 tom 10
If you haven't changed the pitch for a long time the lubricants dry up, if you have some WD40 spray it in the slot inthe margin bar where the L. & R. margin levers ride. Give it a few minites to work.
DickyO
May 16, 2012 | IBM Correcting Selectric II
IBM Selectric III correcting. Carriage return and
You most likely have a broken torque limiter tension spring. We have them in stock but tou must have a good mechanical ability to install.
DiclyO
216-241-0027
Jan 29, 2010 | IBM Office Equipment & Supplies
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
IBM Selectric II keeps returning to right.
Check the pitch lever on the top L. of the cabinet it may be in between positions.
DickyO
Sep 08, 2009 | IBM Office Equipment & Supplies
I have a IBM Correcting Selectric II and I'm having trouble clearing out the margins. Can you help?
space to the right side of the machine, hold down the tab clear key and hit return.
If the carriage stops partway back, one of the tab stops has rotated too far on the tab bar.
remove the platen and paper pan, go to the stuck stop, rotate it to the rear of the machine to line up with the other tabs
Jul 16, 2009 | Nakajima AE-710 Typewriter
IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Jul 02, 2009 | IBM Wheelwriter 30 Typewriter
IBM Correcting selctric II keys are jammed
It sounds like the cycle shaft is not fully in home
position. With the machine OFF, try to turn the print shaft (the steel shaft with the single groove that goes through the carriage) top towards the back of the machine. Then turn the machine on. Try the space bar first. If it works, your machine probably needs the cycle clutch spring adjusted or replaced.
Feb 18, 2009 | IBM 3500 Typewriter
Carriage return problem
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
DickyO
Dec 08, 2008 | Office Equipment & Supplies
IBM Selectric II
R152
Sounds like you have a broken torquo limiter tension spring you should have it professionly serviced.
DickyO
Jul 07, 2008 | Office Equipment & Supplies
19 people viewed this question
k24674
jasbo
jasbo
