Question about Splendide 2000S Vented Washer/Dryer
Splendide WD2000S Fills and Overflows thru Air Vent
I have a Splendide WD2000S Washer/Dryer in my RV.
Yesterday, it filled with water but didnt stop filling - so much so that it overflowed thru the external Air Vent.
I had to keep setting the machine to the drain cycle (about a dozen times) to get it to empty.
Thinking it was perhaps a one-off, we tried again and the same thing happened.
Any ideas please?
Rob
IB4G2008
  • 3587 Answers
SOURCE: Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Posted on Mar 13, 2008
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it.  Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
Posted on Jun 02, 2008
  • 3 Answers
SOURCE: Splendide Comb-o-matic 2000 how do you vent it to the outside
Use 2.5" plastic pipe & elbow to replace aluminum elbow & hose with spring inside. Air velocity is higher, lint blows out without collecting.
I used wood router to remove part of exhaust connector on rear of dryer to better fit elbow. Elbow interior was smoothed to prevent lint sticking. Elbow was mounted with silicone sealant and 2 screws. Pipe was glued to elbow as normal glued pipe connection. Pipe end was cut even with side of dryer.
After Spendide was installed in RV, a union was stuck in from outside RV. Union slides on to pipe without sealant so Splendide can be removed from RV. Union better fills outside vent fitting than bare 2.5" plastic pipe. Temporary seal aroung union was made of urethane foam scraps, common shipping stuff from a computer monitor box. After 2 years of temporary, the foam is now considered permanent.
Original problem was constant lint problems in hose and slow drying. With pipe, not hose, lint is rarely cleaned and drying is much faster.
Posted on Jan 28, 2009
  • 19 Answers
SOURCE: Splendide 2000S
www.splendide.com
1-800-356-0766 #5 (503-656-2280)
503-722-9202
service@westlandsales.com
Monday-Friday, 7:00am - 4:30pm (PST)
You may also want to try a RV retailer in your area, they may direct you to a used part.
Posted on Oct 24, 2010
  • 403 Answers
SOURCE: hello my splendide wd2000s wont drain or spin and
If the machine senses that there is water still in the tub, it will not release the door. Unplug the machine you should her a click and the door should release itself. should take about a minute. As far as the drain and spin, remove the washer/dryer back and check the drain pump, check that the lint filter is clean and that the drain hose is clear of foreign objects. I have instructions for how to unlock the door when the machine is in a cycle. If you're door lock is continuously giving problems,i can walk you thru the steps to test it, to see if needs to be replaced. Lets start with those solutions first, if they don't work we can go to the next step, which would be to test the drain pump and the door lock, and also to put the machine in diagnostic mode
Posted on Feb 07, 2011
Dryer stopped drying yesterday.
www.RepairClinic.com
Sounds like the heating element quit.
Jan 25, 2012 | Splendide 2100XC
Washing maching overflows
inside the washer is a fill valve it has a tube from the bottom of the tub leading to this valve if the tube is blocked with sope the washer over fills clear this tube first also if there are any holes in it it still over fills the washer, the valve works on air presher,,as the washer fills the air presher builds up in the tube and shuts this valve off stoping the flow of water into the washer,,,ok? sorry but me spelling is roten?
May 05, 2010 | Fisher and Paykel WL26CW1 Top Load Washer
Washer heating element????
thats a rather clever machine ..it uses cold water to condense the steam created in the drying process .. so there is no "wet" air exhausted into the room (no external vent needed) .. alas it does not have a "water" heater built in .. just an air heater for drying .. so you would have to use a detergent designed for cold water in your case ... make sure you clean the drain filter often in that model ..
Aug 17, 2009 | Splendide 2100 Vented Washer-Dryer
Dec 26, 2008 | Splendide 2100 Vented Washer-Dryer
WD200S overfills with water
Sounds like the switch that detects the water level is malfuntioning, this can be caused by one of several reasons.
I assume that the water stops running in if you stop the m/c, if it does not, then you have a faulty water inlet valve, which you would have to replace.
I think you neede to call an engineer.
Hope this helps.
Please leave feedeback.
Dec 07, 2008 | Splendide 2000S Vented Washer/Dryer
ok. enough humor.
Mar 13, 2008 | Splendide 2000S Vented Washer/Dryer
Splendide 2000S Vented Washer/Dryer Logo
42 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
