Question about ViewSonic VA2226W LCD Monitor
No power to VA2226w viewsonic 22 " monitor
Disconected power supply to rearrange leads. when turned on, no power indicator lit and blank screen. all other equipment powering up and power outlet operating. have reinserted all leads to cpu etc. used power unlock but no change.
SOURCE: vx900 viewsonic monitor problem . Blank screen except for power off/on
no, Viewsonic has the part for sale 42.99 - free shipping. Easy to replace
Posted on Jul 13, 2007
SOURCE: ViewSonic VA912b (Back light with blank dark screen)!
Wow, many people are having this situation. Mine died out about 2-3 months ago. Same problem. need help :[
Posted on Oct 14, 2008
budmrtn
  • 11361 Answers
SOURCE: my viewsonic
You may have problem in the power supply, see my pictures here so you will know what to look for if you want to DIY: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Hopefully not the LCD panel (I never have to replace one yet in this model).
Posted on Apr 18, 2010
SOURCE: Viewsonic VG2021m Image Vanishes on Start Up
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Posted on May 07, 2010
HnstTrstMe
  • 12 Answers
SOURCE: ViewSonic VA2226W LCD Monitor unlock power button
Try holding the vol+ & vol- or hold the vol+ & Menu and lastly try the ch+ & ch- buttons. When doing this you must do it from the tv not the remote, and hold them down for ten seconds or until it says it has unlocked.
Posted on Aug 20, 2010
We have a Viewsonic VA2226W that goes to black screen after 15 seconds or so, is it toast or is there a way to fix?ViewSonic monitor VA2226w
Make sure you are supplying a valid timing mode to the display. Call ViewSonic technical support to resolve your issue.
Oct 01, 2014 | ViewSonic VA2226w 22" Widescreen LCD...
Viewsonic - VA2226w - dual monitor configuration. Monitor is black / no image- all test pass showing monitor is functioning properly.
Swap this monitor with the main one.
If it works, you may simply not have the secondary output enabled in the operating system.
In Windows for example, in the video properties, there's a place where you choose which video card you're dealing with (and/or which output or monitor) and there's a checkbox that says "extend my desktop to this monitor"
If that's not enabled, monitor 2 will be blank !
If the monitor doesn't work in the same connector that the working monitor is in, you may have bad capacitors in this one.
Watch the video below on how to fix that issue.
Mar 25, 2011 | ViewSonic VA2226w 22" Widescreen LCD...
Mouse movement is not clearly visible & get more H'lin brightness
Have somebody take a look at the capacitors in the power supply first, look for caps that are leaking/bulging top, very common failure in LCD monitor.
Please see some failed bad caps album and failed VIEWSONIC monitors due to bad caps here:
http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps:
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 01, 2010 | ViewSonic VA2226w 22" Widescreen LCD...
I have a viewsonic VA2226w and when i'm away from my desk for more than one hour the monitor display dims. the work around i need to do to make it go to it's original state is to turn off the monitor and...
Look for bad caps in the power supply section, that will be the first place to look. 90% of LCD monitor failures are due to bad caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
May 27, 2010 | ViewSonic VA2226w 22" Widescreen LCD...
My viewsonic VA2226w has horizontal lines running on the screen any solutions?
Apr 17, 2010 | ViewSonic VX2235WM Monitor
When Monitor has been switched off for 8 hours it takes 5 minutes to get back up again. Once up it will work perfectlt
This monitor is more than 2 years old, time to look for bad caps with bulging top in the power supply, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 19, 2010 | ViewSonic VA2226w 22" Widescreen LCD...
Viewsonic VG2230wm 22 Blank screen
Look for bad caps in the power supply first, see example of failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you furhter.
Feb 06, 2010 | Relisys RLT1720 17" LCD Monitor
Installing Ubuntu after vista install gives "out of range"
http://www.tech-tips-now.com/2008/11/12/how-to-dual-boot-vista-and-ubuntu-810-part-7/
this is great guide to set up a dual boot option on your on pc
Mar 16, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
ViewSonic VA2226W  LCD Monitor Logo
46 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
