Question about LG Televison & Video
Don't have the remote control and need the AV channel
Lg tv around 6 years old, remote nor working and I can't get av channel
Benimur
  • 6966 Answers
SOURCE: RE; Remote control TV/AV button doesn't work LXI series
Hi, Based on your post/description: 1. the TV is stuck to A/V; 2. you have two video sources - VHS & DVD (assuming both are external and both have A/V outputs with the VCR also with inputs); 3. you want to use either VHS & DVD, one at a time. You can do it the old fashion way, remove yellow, red, white RCA connectors from DVD and plug them at the outputs of the VHS when you want to use the VCR; or Connect the A/V outputs of the DVD to the inputs of the VCR, connect the outputs of the VCR to the A/V inputs of the LXI TV. Hopes this give you an idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Aug 24, 2007
SOURCE: How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.98fe8a9.jpg
Posted on Jan 19, 2008
crazy larry
  • 6 Answers
SOURCE: how to access AV channel on Toshiba TV model 2125RA
some sets auto-go av when you plug a rca jackin the set, others have a switch in front or back , others you might set your channel to 00 or 99 or 100 forget and work different , I the owners manual of course would tell you. but I assume u dont have it . try hooking it and letting the dvd run now find it using the remote.
good luck.
Posted on Feb 23, 2008
SOURCE: changing the channel to av without a remote
I dont know if you tv has this sertting but click menu usally 4 times and it will bring u to a page wich might say channel or something else and u can chane the channel by using the volume buttoms this worked for me and i can put it onto av1 av2 av3 and av4
Posted on Jan 03, 2009
SOURCE: finding AV channel without a remote control
get ewf 2004 on av channel without remote
Posted on Feb 19, 2009
CHANGE CHANNEL TO AV/SCART ON A GOODMANS TVC 1400 WITHOUT THE REMOTE CONTROL , ONLY RUNS THROUGH 7 CHANNELS
Not familiar with this, but see if there is another button on front or top or behind a cover marked AV or source, if so then that will select the channel you want.
Sep 16, 2014 | Televison & Video
Need to get my tv (model LG) ack on to av mode. no remote control
If you want to select its inputs, you must have its original remote control. No universal remote control will go.
Dec 12, 2013 | LG Televison & Video
No remote need tv in av mode
While ur TV is connected to d AV device which must also be on, run a frequency scan and all available channels including ur AV channel will be detected and saved. After d scan, u can manually change channels to ur AV choice.
Jun 06, 2013 | Televison & Video
I have an LG TV "soundmax plus" AV STEREO/26 System, the remote control is damaged and cant find one, I bought a UNIVERSAL REMOTE CONTROL and tried to fix the problem but I cannot make it.What is...
Universal remotes have 3, 4, and 5 digit codes depending on the age of the devices to be controlled. 3 digit codes can only control devices made before year 2000. 4 digit codes can do upto 2007, 6 digit codes can do upto the date of the remote manufacture date. Your universal remote is too old for your TV.
Nov 29, 2010 | LG Televison & Video
How to select av without remote control
try pressing plus and minus channel on the tv at the same time. works with my daughters tv
Nov 16, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Panasonic TV Model PV-C 1320
There should be a TV/AV button located with the front control buttons, press this & it should switch over to the AV source ie. your camera input.
Sep 02, 2009 | Panasonic PV-C1320 13 in. TV/VCR Combo
you might try going to channel 00
If you cannot just dial the number 00, go to channel 2 and then channel down.
Does not always work, but without the model number of the TV it is hard to advise further
Mar 12, 2009 | Televison & Video
Tv will not recognize channels to save, goes to black screen
If you want to get the original remote for this model (AV-30W776), you can find it at this JVC parts ditrubutor:
JVC AV-30W776 Replacement Part Remote Control
Jan 09, 2009 | JVC AV-30W776 30" TV
Finding AV channel without a remote control
Hi, I brought a EmersonTV model EWF2004 without a remote control and I can't find the AV channel to watch DVD's I hope you can help me
Sep 01, 2008 | Emerson EWF2004 20" TV
Televison & Video Logo
29 people viewed this question
Computer Repairing
Computer Repairing
