Question about Sharp 32L-X2000 32" TV
Reception/ jacks on the back of a SHARP L32 - X200 Cinema select
There is a jack labeled ANT/CABLE 75 above the coax jack. The jack is coated with what appears to be a thin coating of plastic. Got hurt at work and cant afford sattelite right now. A few local channels through an antenna is the other option. The coax jack is very loose and does not work any longer with an adapter and a long ribbon antenna. What can you tell me about this other jack?
Thanks
  • smrb5106 Dec 07, 2008
    are you saying that i should run the antenna off the dvd player? What is the coated jack labeled ANT/CABLE 75 ? Is it usable if I remove the coating? Thanks
    Scholar:
  • 195 Answers
Go to VCR, OR DVD player. Use channel selection there.
Posted on Dec 07, 2008
Have no picture just keeps say no signal
Check the input jacks in the rear. Each should have a unique label. Pick one input that has cables connected to it. Note the input name. Follow the cables back to the device connected - DVD, BluRay, Cable / Satellite box, etc. Turn on the TV, and select the same input you noted above. Turn on the device connected to it (DVD, BluRay, Cable / Satellite box, etc.). If this fails, try again with a different device or connect the cable / satellite box to the antenna input and select ANT.
May 21, 2014 | Televison & Video
Not detecting devices
test this steps and fix it. God bless you
    • 1
      Check the back of your Sharp TV for the HDMI input. These will be long, thin rectangular jacks labeled "HDMI." Most Sharp TVs will include another label on those jacks with an input number ("Input 5," "Input 6" or the like). Remember that number. It will have a bearing when you turn on the TV.
    • 2
      Connect one end of an HDMI cable to the input jack on the Sharp TV and the other end to a compatible component such as an HD DVR from your cable/satellite company or a Blu-Ray disc player. The TV won't broadcast in HD if you can't connect these devices with an HDMI cable (though it will still broadcast in standard definition using RCA cables or S-video cables).
    • Sponsored Links
    • 3
      Turn on the TV and the requisite component (Blu-Ray, DVR).
    • 4
      Press the "Input" button on your remote. A list of signal sources will appear on your screen ("Input 1," Input 2," etc.). Use the cursor to maneuver down to the input number corresponding to the HDMI outlet you just hooked up and press the "Input" button again.
    • 5
      Press the "Menu" button and maneuver the cursor to select "Option." Go to "HDMI Setup" and press "Enter." Move the cursor up or down to the desired item and hit "Enter" again. Then move the cursor from side-to-side to select the proper setting. Hit "Enable" to allow the Sharp TV to automatically recognize the HDMI signal and "Digital" to get the proper audio signal from the HDMI cable. Then hit "Enter" again.
    • 6
      Exit the menu and watch TV as normal.
Read more: http://www.ehow.com/how_4840499_turn-hdmi-input-sharp-tv.html#ixzz2a6Xat0JU
Jul 25, 2013 | Seagate 1TB GoFlex Cinema Multimedia Drive...
How to hook up a cable remote to a Samsung cable box?
    • 1 Examine the back of the your cable box and the back of your Samsung HDTV. Note which cable jacks are of an identical size and color. Those are the ones that can be used to connect the two devices. Samsung HDTVs cluster all the jacks in a single panel near the power cord.
    • 2 Look at the square rectangular boxes labeled "HDMI In." These are for high-definition multimedia interface cables--combination A/V cables that provide the highest possible image and sound clarity. Look at the back of your cable box for an identical jack labeled "HDMI Out." If you see one, connect the two jacks using an HDMI cable. If you don't, you need to use another set of cables to hook up your cable box.
    • Sponsored Links
    • 3 Check for a series of three round jacks labeled "Component In" and color coded in red, green and blue. These are component video jacks, which provide a good HD picture, but not as good as HDMI. If your cable box has an identical set of "Out" jacks, use them to connect the two components.
    • 4 Look for a pair of red and white jacks (possibly connected to a yellow one). These are audio RCA jacks. If you're using component video cables to hook up your cable box, you will need to hook these two up as well: Component video cables don't provide sound. Any cable box that uses component video cables should also have "Out" jacks for RCA audio cables.
    • 5 Find the raised circular jack with a pinhole in the center of a milky white plastic interior. This is the coaxial jack. Samsung HDTVs label them "Ant In." Every cable box should have a corresponding jack labeled "Out" or "Ant Out." If none of the other cable jacks on the cable box match, use a length of coaxial cable to connect the TV to the cable box through these two jacks. You can also use this connection to hook the TV directly to the wall cable.
    • 6 Turn on your TV and cable box, and set the TV to the input jack connected to the cable box. You can do this by pushing the Menu button on the remote, scrolling down to the "Input" option and pushing "Enter." That will let you cycle through the various input options, labeled by cable type (HDMI, component video). Press "Enter" again when you reach the right component, then exit the menu. You should now be able to watch TV as normal.
Read more: How to Hook Up a Cable Box to a Samsung HDTV ' eHow.com http://www.ehow.com/how_4867255_hook-cable-box-samsung-hdtv.html#ixzz2DwgQRtRE
Dec 03, 2012 | Televison & Video
Sound
Except for the Headphone jack (mini-jack) and the coax audio, all of the audio jacks are audio IN. Which jack do you have your speakers connected to? The headphone jack is on the side next to the coax connection (ANT) and the coax audio out is at the bottom of that set of side jacks. The headphone mode should automatically cut the TV speakers. The coax audio out is set up by pressing Menu and then using the down arrow to highlight Audio. Then press the right arrow button to enter the submenu. Press the up or down arrow to reach SPDIF. Then you use the left and right menus to select PCM, Digital Dolby or OFF.
I hope this helps.
Jul 10, 2010 | Element ELC-HS321 32 in. LCD TV
How does my mother hook up the antenna and get her TV to work (no cable)
First, you'll want to make sure that her antenna has a coaxial cable (one of the thick round ones) coming from the antenna. Some older ones have a flat piece of plastic with two wires sticking out. These are less efficient, but if you have one, use a balun (a vhf-uhf matching transformer) to change to coax. You can google "balun" if you don't know what one looks like. Next, you'll need a digital converter box (if you don't have one already). Connect one end of the coax cable to the antenna (or balun) and the other to the jack on the converter box labeled "ant. in." Finally, using another coax cable, connect one end to the jack on the converter box labeled "to tv" and the other end to the jack on the TV labeled "ant. in." Finally, depending on your converter box, you will probably need to "scan " for tv channels. Follow the setup instructions with the converter box to do this. If you don't have the instructions, try googling the converter box company and model number to find the users manual. I hope this helps, and good luck! Sincerely, Der Strom
Apr 09, 2010 | Sansui DTV1300 TV
Poor reception. Changed the radio with another of the same model. Reception is still poor. Must be an antenna problem. How do I go about replacing the antenna and coax?
1. Disconnect negative side of battery.
2. Wait at least 2-minutes to de-energize the airbag system
3. Remove the glove box from the dash.
4. There will be a coax cable towards the top of the opening. Disconnect the antenna cable lead.
5. Remove the right kick trim panel. There should be no screws just clips.
6. Loosen the rubber grommet insulator from the door hinge area. This is a rubber accordian style guard for wires located between the "A" pillar and the door.
7. Pull the antenna cable out of the dash area to the hinge area.
8. Jack up the front right of the vehicle. Support with Jack Stands. Do not use only the Jack! Use the jack as a back-up in case of Jack Stand failure.
9. Remove the right front tire.
10. Remove the right front wheel housing splash shield. There should be 3-push type retainers and one 10 mm bolt below the bumper.
11. Slide the plastic cover (on the base) up on the antenna mast.
12. Use a open end wrench to unscrew the antenna mast at the base and remove the antenna mast.
13. Remove the plastic cap from the base nut on the base and remove the base nut.
14. From underneath the fender: pull down the antenna base. And pull the cable towards you - out from the door hinge area into the fender area.
Good Luck! Installation is reverse of above.
If this helped or you need clarification or additional help: let me know at fixya.com
Nov 27, 2009 | 2000 Dodge Caravan
Trying to hook up "back-up camera" which only has a coax output jack. Can I hook it directly into "ANT" jack or do I have to go through a demodulator and reduce to an RCA and then plug into V1 jack?
I would be interested to know the model number of the camera. "Coax" jacks are usually only used for tuners. It is more possible that it is a BNC connection. If it truly is coax than they may have used the coax jack because an RCA style plug would come unplugged too easily while driving.
Just get an F (male or female depending on the connection) to RCA (female) adapter and an RCA cable and plug it into any composite (yellow) video input.
If it is BNC than get a BNC to RCA adapter.
http://www.cablesnmor.com/bnc-rca-adapter.html
Take the part into Radio Shack and they will have the right adapter.
Nov 25, 2009 | Sylvania 6615LFP 15 in. EDTV-Ready LCD...
On the back there is a jack above the coax jack and it is labeled ANT/CABLE 75 and the jack is coated with what appears to be a thin coating of plastic. There is only satellite where I live and I cant...
remove the plastic and see if there is a free to air signal, or a cable connection from a previous tenant.
The jack socket that is loose, just replace it. They are around 5 bucks from an electrical wholesaler or Home Depot.
Jul 05, 2017 | Sharp 32L-X2000 32" TV
Coax Cable
You need a cable box if you have channels that are digital (mustly the channels above 74). If you do not have those higher channels you can use a vcr or a dved player that has a tuner in it. Put the cable into the vcr and then use the Video and Audio jacks (A/V jacks) and the back of the vcr that say "OUTPUT" and hook them up to the same type of jacks on the back of the tv that say "INPUT".
Nov 10, 2008 | RCA HD52W58 52" TV
I have a Motorola Quasar TV and an outside UHF Antennae. I have coax coming from Ant. There are 3 coax connectors on the back and one pair of screw terminals for 300 ohm flat lead in cable that is...
You are losing a VERY small amount of signal using the transformer. It won't even be noticeable I'm sure if you switch to the coax in but the fewer connections you go through the less the chance of a bad connection. Use regular " Ant. In " coax connection or " RF in" whichever the wording is on the back of your set. Good Luck!
barneyluc
Oct 10, 2008 | Televison & Video
Sharp 32L-X2000 32" TV Logo
243 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
