Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Lock for selfcleaning oven did not retract all the way
My sister some how set my oven to clean and did not realize it.she pulledon the door so hard she was able to get the oven door open. now the hook that locks the door is partley stuck out. the oven door doesn't shut all the way.and the convection fan turns on and off every so often,due to the door being open a little bit.is there a way to retract the hook??
    Sergeant:
    Champion:
  • 338 Answers
Try setting the self clean letting it lock and then hitting the cancel button. usually take a min or to to see if it will retract itsself. the only other option would be to tap it lightly with a hammer so you can use the oven and replace the latch
Posted on Dec 07, 2008
Why can't self cleaning be initiated?
you sure it is not LOCK doors ?
the doors usually need to be locked to start the selfcleaning process, you must have a little lock near the main handle to lock it
Apr 12, 2016 | Ovens
After selfcleaning tried to bake put when you push the bake button it says to unlock door, however door is already unlocked and open
During self clean the oven controller locks the door to ensure one does not accidentally open the door and get insured due to high temperature. The door lock mechanism is unlocked once the temperature comes to normal when self clean is complete. In your case the controller is still sensing high temperature but the door lock mechanism has been released. This could mean the controller is detecting incorrect signal. Try to turn the mains power to oven off and back on. If this does not make a difference then you need to check the temperature sensor or worst the controller needs to be checked.
As I do not have the model number of the oven it is hard to give further diagnostic information.
Aug 13, 2014 | Hotpoint Ovens
Maytag Frigidaire Electric selfcleaning oven slide in type 30 inch wide purchase in 2003 --cleaning lady cleaned oven,unable to pull open oven door -door is jamed shut ???
Hello
Let oven completely cool then try.Locks out for safety because of extremely high temperatures involved in self clean mode.
Feedback appreciated
Aug 05, 2011 | Frigidaire FEB24S2AS Single Oven
Hi, my kenmore elite oven (#79075503207) has been on cleaning mode for the last 3 days, it is still making a noise and door locked. please help.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Dec 11, 2010 | Kenmore Elite Stainless Steel 40" Dual...
Fix a selfcleaning oven
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Try to use selfcleaning feature on range and as soon as door locks it stops and goes to F9
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%
Jul 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchenaid superba oven stovetop oven door will not open after se
When the oven goes into clean mode the door is automatically locked as a safety feature. I would put it back into clean mode again, let it clean for a while and then hopefully when it cools down the door will open. good luck .
Mar 20, 2009 | Ovens
Frigidaire electri clean selfcleaning feature
It locks automatically. You can download the manual from Frigidaire here (as I just discovered while trying to figure out how to use the self-cleaning feature :) ): http://www.frigidaire.com/support/manuals.asp?NewSearch=New+Search
You don't need to type in the whole model number. For example, if the model number (found in the upper left when you open the oven door) is RSE37BAW*4, you only need to enter RSE37BA.
Apr 27, 2008 | Frigidaire Ovens
GE OVEN SINGLE ELECTRIC JKS05BW
I have the same problem. Mine is a self-cleaning oven. But I'm just preheating it 450 and it did it. Then this AM it did it while broiling.
Apr 09, 2008 | GE JKS05 Electric Single Oven
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
115 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
