Question about Belkin (F6C800-UNV-PL) UPS System
F6C800 no pwer to backup receptacles
Batteries are fully charged to 13.3 volts each. Trickle charge current flows when power is on. When AC power removed, I get power to the backup receptacles for about 2 seconds, then I hear a relay click and they turn off. Under this condition, the yellow light is on steadily (even after the receptacles click off). I do not see a red light (alarm) under any conditions. So I think the batteries are good (I tried it out with a fresh battery too and the problem remains).
From original poster: yes, the batteries were indeed bad. Showed full voltage on a voltmeter but had no discharge capacity at all. Batteries replaced, unit works properly now.
Posted on Apr 18, 2007
  • 114 Answers
That´s pretty strange and i would say that the batteries aren´t properly charged, try to let them charging over night without any load. good luck
Posted on Feb 27, 2007
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Tip
Batteries & USB Devices & Charging
I see lots of people have trouble with their batteries for their various USB connected devices. Unfortunately you cannot usually charge a totally flat battery, or even a 1/2 charged one... from the USB port. These are only used to "Top Up" the battery... & keep it charged up via a "Trickle Charge". at very low current.If your battery is in this condition then you need to replace it with a fully charged one, and then use the USB to keep it fully charged.Another way is to connect the "Flat" battery up to a power supply or machine that charges them, at the right Voltage (Usually 3 - 6 V) & Current rating, and once fully charged, then use the USB.
on Jan 29, 2010 | Computers & Internet
96 dodge ram 2500 diesel turbo good batteries, alternator good.. batteries won't charge
check that the charge rate from the alternator is no ac current. A multi meter will show a charge rate of 13.5 to 14.5 volts but that could be unrectified current because of a failed diode in the rectifier in the alternator. Set the meter to read for ac voltage and if you have ac reading then have the alternator overhauled. Have a load test done to check the batteries for a problem cell under load.
Jul 05, 2014 | Cars & Trucks
Holden caprice 2007 alternator warning light
charging lights work on the principle of a balanced current throughn the bulb. no charge and the current flows from the battery through the bulb to the alternator. conversly when the alternator is charging at 13.5 volts or better the current is flowing back through the bulb. this opposing current puts out the bulb 12 volt batteries arte in fact 13 volts and alternators charge at 13.8 to 15 volts the 2 odd volts difference is not enough to make the bulb light up. Knowing this it means that some where you have an open circuit that is allowing I suspect battery voltage to make the bulb work. So I would be checking the wiring at the back of the alternator especially the continuinty of the 2 small wires in the connector as I suspect one may be broken in the platsic covering at the fitting The heavier lead is the one that carries the charge directly to the battery
Jan 06, 2013 | Cars & Trucks
Need Homelite Mower UT13122 wiring schematic to check switch problem. Battery fully charged
Check the switch for current flow with and without the key. Then make sure the ground switch is disengaging when you pull the handle.Possible stretched cable.
Dec 11, 2012 | Garden
My battery boils /
If the battery is boiling through an overcharge it will be hand-hot.
It takes a while for a battery to become so hot.
A new battery and regulator should not cause the excessive cell gassing that would force electrolyte out of the breather.
14.5 volts is high enough above the battery voltage to maintain a steady current flow into the battery that might be too much for a relatively small battery.
Under normal circumstances a vehicle alternator is incapable of charging a battery, the alternator being designed to maintain a fully charged battery and to provide sufficient current to power the vehicle equipment. This is because the high internal impedance of the lead acid battery means it soon achieves the fully charged terminal voltage whether the battery is charged or not and the regulator will then reduce the output to that of a trickle charge.
On the typical car alternator the regulator rapidly switches the energising power to the rotor, reducing the current output even though a simple voltmeter check will be around 14.5 volts.
A permanent magnet alternator produces a constant output. To be honest I don't know how the motorcycle regulator works and whether it limits the current but I do suspect a constant current supply at 14.5 volts will be too much for a small motorcycle battery.
Honda used to go to great lengths using complex switching to reduce alternator output to prevent excessive battery gassing; full alternator power was only available when the headlight was switched on.
I guess it is possible the problem might be there is simply too much electrolyte in the battery or it is being subjected to too much vibration. I suggest you check the current the battery is consuming which with a fully charged battery should be in the region of half an amp.
Oct 01, 2017 | Motorcycles
My batteries are struggling to charge do i need new ones
Harold Do you mean that they won't fully charge or won't charge at all. If you have the small 12/12 batteries then they do not last as long as the U1 batteries (bigger) If you have the U1 batteries check the voltage of the batteries with a volt meter Fully charged should read over 12 volts and up to 13.5 volts. Also check your charger to make sure that it is charging with a voltmeter you can measure the voltage aith the charger plugged in and you should be reading over 13 volts on each battery. Hope this helps you
Sep 07, 2010 | Pride Health & Beauty
Freestyle M11 Wheelchair by Quickie
 If you are getting juice to the battery terminal and the batteries are not charging it is because the batteries have fallen under 12 voltsDC. If the system detects batteries that are depleted that low,it cant bring them back up. So you will need to get the batteries on a trickle charger or slow car charger. That way you can bring them back up to around 12 volts each. At that point the inboard charger can do the rest.
Mar 21, 2009 | Electric Mobility Power Electric Scooter...
Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Jan 17, 2009 | Computers & Internet
Belkin (F6C800-UNV-PL) UPS System Logo
227 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
