Maytag top loader washing machine stooped pumping water out
    Sergeant:
    Champion:
  • 200 Answers
HI
If there's no water at all, make these checks:
  • Is there water getting to the machine?
  • Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
  • If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
  • Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
  • Thank you
    Posted on Dec 07, 2008
    Anybody have an issue with drum leaking on a Maytag Centennial washing machine?
    top loader leaking ?? this is unusual !! I did have a top loader leak once (not maytag) that the operator overloaded it and allowed it to try and spin dry , it shook unattended so bad it shook loose the hose connections from drum to pump , id suggest checking exactly were it leaks from with a flashlight looking at machine with back off ,while its running , use only your eyes !! for safety !
    Oct 20, 2016 | Maytag Washing Machines
    On Maytag top loader, water enters but drains immediately.
    check that the drain hose is above tub level
    check for faulty program board engaging the pump all the time
    Sep 20, 2016 | Maytag PAV2300 Top Load Washer
    Maytag top loader on final spin cycle leaves the clothes soaked
    how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
    Aug 20, 2009 | Maytag Washing Machines
    Does not spin or pump water out
    Is it a front loader or top?How old? What model? need more info If front loader sound like you need to remove hose from pump and cheak for obstruction in pump good luck:)
    May 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Maytag leaks water in the spining cycle and makes a loud noice.
    how old is your maytag top loader ? pump do not leak that often on maytag top loader you may need stem&seal kit &tub bearing kit
    Feb 18, 2009 | Amana 3.2 cu. ft. Top-Load Washer
    Front loading washing machines
    not really front loaders have top loaders beat all the way but stay away from admiral and maytag .a front loader will wash your clothes using the soap that your top load failed to get out if i may suggest buy a frigidaire with a mechanical timer not electronic control more junk on them more to fail the best combo in my mind is a frigidaire front loader and whirlpool dryer front loaders use 2/3 less water 2/3 less soap and will get your clothes twice as clean they have no transmissions and are direct drive the most common promblems with them is having to clean out the pumps where people leave stuff in their pockets also you need to buy soap thats for front loaders its called high effincey or he soap and they will get your clothes make sure you read the installation guide and remove ALL the shipping braces
    Mar 18, 2008 | Admiral AW22 Top Load Washer
    Washing Machines Logo
    153 people viewed this question
    Top Washing Machines Experts
