Question about Clarion DRB4475
Setting the clock
I dont have an owners manual and i am trying to set the clock. also there is a light blue wire with a white stripe on the harness i am trying to figure out what it is for. thanx
    Scholar:
  • 135 Answers
Wiring harness colors have been fairly standardized for many years. The blue/white lead is the "Amplifier turn-on lead", and can be connected to the remote turn-on lead of an external amplifier. To set the clock, press and hold BAND and DISP to display the clock. Press and hold BAND and DISP until the display flashes. SEARCH left to adjust the hours; right to adjust the minutes. Press BAND to set.
Posted on Feb 19, 2007
I bought a Ouku 7" screen DVD Navi unit for my 2009 Honda Civic. There are 4 loose wires on the harness labeled as follows:
Orange goes to the switch on the emergency brake. This allows the DVD player to play movies with the brake on ( liability issue...people sued and bankrupted a manufacturer because they watched tv while driving and some people got killed) should be the light green wire at the switch on the ebrake handle.
Blue is used on a vehicle with factory analog steering wheel controls
pink is connected to the back up lights and activates the backup camera feature if you have a back up camera
blue w/white stripe...best guess has to do with infra red remote ...possible allows an ir eye to be installed.
I would suggest go ogling the model number for a wiring diagram or owners manual if you don't have one.
Nov 01, 2016 | Honda Cars & Trucks
I would like the wiring instructions for a jvc kd-g845
Wiring harness connections as described in the installation manual:
  1. Black: Ground to metallic body or chassis of car.
  2. Yellow: Terminal in fuse block connecting to car battery (bypassing ignition switch) (constant 12 V).
  3. Red: To an accessory terminal in the fuse block.
  4. Blue: Power antenna if any (250 mA max).
  5. Blue with white stripe: To the remote lead of other equipment (200 mA max).
  6. Orange with white stripe: To car light control switch.
Speaker connections:
Left front: + White - White with black stripe
Right front: + Gray - Gray with black stripe
Left rear: + Green - Green with black stripe
Right rear: + Purple - Purple with black stripe
Jul 17, 2011 | JVC Car Audio & Video
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
What wire colors do i connect to my old wires in my 95 dodge neon
For Dodge Neons:
Factory in-dash wire harness has 2 pc harness (black plug and gray plug).
(Black plug)
(Gray Plug)
Metal braid plastic connector attached to back of radio is the ground wire.
May 20, 2010 | Car Audio & Video
Bought brand new car audio head unit CQ-RX420W, but no installation instructions. Blue and brown wires, not sure which is for aerial and what the other is for. Can you help?
what you have there is a good panasonic head unit. the solid blue wire is going to be used for an automatic antenna.
Yellow- Constant Power (keeps memory for your clock and presets)
Red-Switched Power (turns your radio on when you turn the key)
Black-Ground
White- Left Front speaker (+)
White w/ black stripe - Left front speaker (-)
Gray - right front speaker (+)
Gray w/ black stripe - Right front speaker (-)
Green- Left Rear Speaker (+)
Green w/ Black stripe Left Rear speaker (-)
Purple - right rear speaker (+)
Purple w/ black stripe - right rear speaker (-)
Blue with white stripe - power out, (commonly used for the amplifier turn on wire, or antenna wire.
you may have orange wires in your harness,
or brown ones. these you dont really need
the orange wires are for your dash board dimming lights
and the brown one is for Tele, Muting.
what kind of car do you have, i can give you the wire harness colors
Dec 30, 2009 | Car Audio & Video
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
Purchased a Thor Alarm with door locks and autostart and trunk release I believe model CF425 and was curious if anyone had a wiring diagram not sure what each wire is. One harness has 12 wires the other...
I have this alarm / remote start / keyless entry system and I have the poorly translated installation manual. Everything in mine installed fine in my 2005 suzuki aerio (except the power locks as the manual is worthless in that area) but I have heard nothing but horror stories from others online since I installed it.
I don't recommend you install it but if you really are determined, here is what the manual says (or tried to say and I spent 4 hrs interpretting / correcting it:
8 wire harness:
-- The 4 wire connector connects to the 4 wires harness part of the 3 relays
-- The yellow connects to the yellow of the breaker relay yellow
-- yellow w/black stripe connects to the oil sensor on the motor (look for single wire connected to sensor and generally a heat shield wrap/weave, mine was blue)
-- orange connects to the brake switch on the brake pedal
-- the blue connects to the door switch /dome light trigger
12 wire harness:
-- 6 central locking wires orange, yellow, and white plus the same 3 with black stripe.. Unfortunately the manual is not clear as to where they connect. The next page of the manual shows diagrams but they mysteriously add a white stripe to all the colors and the white wires apparently become green. I suspect that orange is not likely used in most installations and for positive door lock types (the most popular), yellow goes to unlock and yellow w/ black stripe goes to lock signal and the 2 whites go to 12v+. This is only a guess so don't hold me to it.
-- black is grounded to frame
-- Red is 12v+
-- red w/ black stripe goes to power trunk release (if equipped)
-- The 2 browns go to the left and right turn signals
-- The pink goes to the alarm
Ignition switch connections
The breaker relay:
-- blue goes to the ACC ON wire
-- Cut the ignition wire and connect the 2 greens to each end
-- Yellow connects to the yellow of the 8 wire harness
The 3 relays:
-- 4 wire harness connects to the 4 wire connector of the 8 wire harness
-- the 3 reds connects to the 12v+ red of the ignition switch (or thru the firewall to the battery)
-- black connects to the ignition on the downstream side of the 2 greens of the breaker relay
-- white connects to ACC ON
-- blue connects to the starter
Apr 25, 2009 | Vehicle Parts & Accessories
Installing new radio
Factory in-dash wire harness that
snaps into the factory radio.
AS VIEWED FROM MATING END OF CONNECTOR
E F G H I N O P
A B C D J K L M
Note:
using an optional snap on wire harness adapter will simplify the wiring. Most snap on
wire harness adapters have already converted and color coded the wires from the auto
makers in dash wire harness to match typical aftermarket radio wire colors.
** The wire colors listed in the chart above are typical for these vehicles during these years
but may not be the exact colors for this vehicle. This is another reason to use a snap on
wire harness adapter. **
Typical Honda/Acura "Typical" New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (+) Red w/ Yellow Stripe Purple
B Left Rear Spkr (+) Blue w/ Yellow Stripe Green
C Power Antenna Trigger Brown w/ White Stripe Blue or Blue w/ Wht Stripe
D +12 Volt Ignition Wire Yellow w/ Red Stripe Red
E Right Rear Spkr (-) Brown w/ White Stripe Purple w/ Black Stripe
F Left Rear Spkr (-) Gray w/ White Stripe Green w/ Black Stripe
G Ground Wire Black Black
H Do Not Use
I Do Not Use
J +12 Volt Battery Wire White w/ Yellow or Blu Stripe Yellow
K Dash Light Dimmer Wire Orange
L Left Front Spkr (+) Blue w/ Green Stripe White
M Right Front Spkr (+) Red w/ Green Stripe Gray
N Do Not Use
O Left Front Spkr (-) Gray w/ Black Stripe White w/ Black Stripe
P Right Front Spkr (-) Brown w/ Black Stripe Gray w/ Black Stripe
Dec 26, 2008 | 1990 Honda Accord
Changed settings(LP to SP)
If there is still no sound, you probably hooked up the unit's wires wrong. Try switching the wires coming off of the back of your head unit so that the wire that is supposed to be connected to the amp turn on in your factory harness isn't connected to the antenna lead or something like that. I don't know what the Pioneer wires look like, on my Sony there are two blue wires, one with a white stripe on it and one just plain blue. The wire with the white stripe on is the one that should be connected to the amp turn on in the factory harness.
Mar 05, 2006 | Pioneer MEH-P5000 MiniDisc Player
Clarion DRB4475 Logo
186 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
