Can not see my Harddrive
Hi, I bought this external harddrive to save my photos, videos work etc. But when i hooked up with my pc via usb cable it shows that usb attached then start downloading drivers and it shows USB mass storage in safley remove hardware box. But the problem is that I cannot see this drive anywhere to transfer my stuff . Please help me as my pc is gone really slow and i want to move stuff to external harddrive. thanks
  • 1 more comment
  • firesrus Dec 09, 2008
    Hi, Thanks Coral45 I tried everything but I can't change the name of the drive because its showing as unallocated. This is external harddrive with power cable to store extra stuff like videos, pictures etc. How can i allocate this drive please?
  • Justin Goldberg May 11, 2010
    I would suggest plugging it into a different USB port. If it's still not working, try unplugging and immediately plugging it back in to the same port.
  • Joe May 11, 2010
    What operating system are you running?
    Problem Solver:
If it says its in the safley remove, but its not showing up, it might have the same drive letter as one of your other hard drives, for XP: 1.go to control panel (start -> control panel) 2.click on "switch to classic view" (top left) 3.click on "administrative tools" it should open up and show more icons 4.click on "computer management" it should open the computer manager 5.on the left side, with the drop down menu's and stuff, open storage, then clikc "Disk Management" 6. in the window left of what you just clicked,find your drive, you should not the capacity and basic stuff about your drive, you should be able to find it 7. right click on your drive and click "Change Drive Letter and Paths" 8.click "Change" 9. in the drop-down menu choose a new drive letter, that isn't being used 10. click Ok and it should work. if it doesn't see if your drive needs to be plugged into a wall to get extra power. or somthing
Posted on Dec 07, 2008
SONY VAIO PCV R53 39 DS WON'T BOOT UP
Pull the harddrive out, install in an economical external enclosure.
The external enclosure has a USB cable.
Plug the USB cable into any available USB port, on a working computer.
Go to My Computer, or Computer; and double-click on the drive letter, that corresponds with the external enclosure.
(Actually with the harddrive in that external enclosure, it is now an external harddrive)
http://esupport.sony.com/US/p/model-home.pl?mdl=PCVR539DS&LOC=3#/howtoTab
It's an IDE harddrive. Also known as a PATA harddrive.
A harddrive is measured across it's width.
2-1/2 inches across is a laptop harddrive.
3.5 inches across is a desktop harddrive. (3-1/2 inches)
So you need a 3.5 IDE (PATA) external enclosure.
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
Regards,
joecoolvette
Mar 26, 2013 | Sony VAIO Computers & Internet
My acer chromebook AC710 SCREEN IS CRAZY CANT SEE ANYTHING BUT COLORS AN LINES WHAT TO DO?
The reason your monitor is in screensaver mode, (Read your other problem too), is there is no video signal coming to it.
No Signal
This is because the Netbook isn't sending one.
It isn't sending one because apparently you have graphics problems. Problems with graphics hardware.
So no, there is no Sync, or settings to change on the monitor.
(It is Not a video/graphics card. Your laptop uses Integrated Graphics. Intel HD 3000 Graphics )
However the point is moot now. Netbook is being sent in.
Point now is getting the info off the Harddrive, before some geek looses it.
(I'm a computer geek too, so that was no slam)
Remove the Harddrive. Then install it in an external enclosure.
You've seen an external enclosure, if you have seen an external harddrive.
You can buy just that 'outside case', too.
The external enclosure has a USB cable going to it.
The USB cable goes inside the enclosure, and connects to a small circuit board, with an interface on it.
The harddrive plugs into the interface.
The external enclosure comes apart VERY easily. Manufacturers make it easy to open the external enclosure, and install the Harddrive.
Usually a 2 piece case. One screw to open. Remove cover, plug Harddrive in, replace cover.
Plug USB cable into a USB port, on a working computer.
This is one example that will work with your Harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
[Harddrives are measured across their width.
A laptop harddrive is 2.5 inches across in Width. 2-1/2 inches.
A desktop harddrive is 3.5 inches across in Width.
Three technology styles of Harddrive, are presently being used;
1) IDE (PATA),
http://en.wikipedia.org/wiki/Parallel_ATA
2) SATA,
http://en.wikipedia.org/wiki/Serial_ATA
These two types of Harddrives use mechanical parts. For example a Spindle, Spindle Motor, and Platters,
http://computer.howstuffworks.com/hard-disk.htm
3) SSD,
http://en.wikipedia.org/wiki/SSD
No mechanical parts. Just electronic components. (Solid State)
Your laptop uses a 2.5 SATA harddrive ]
Going on..................
I haven't had any direct dealings with this laptop. Or the Aspire V5-171 version.
I see no Service Manual listed.
Searching the internet for Harddrive replacement info though, I ran into that there is a large panel on the Bottom of the Netbook; which has a single Philips head screw in the middle.
Remove the screw, remove the large panel.
This is supposed to be in the User's Guide, but cannot seem to download it right now to see.
It will be in replace the Memory. Ram Memory.
The Harddrive should sit in a compartment area all it's own.
The Harddrive itself will be in a sheet metal Caddy. Harddrive Caddy.
Remove a screw, or screws; to remove Harddrive, and Harddrive Caddy.
Once screw/s are removed, L@@K at the Harddrive.
There should be a piece of 'silk strap', to pull on.
Keeping Harddrive flat, and down in Netbook, pull on the strap; and pull the Harddrive across towards the OUTSIDE of the Netbook.
You are unplugging it.
You DO NOT want to lift straight up on the strap, as you will bend contact pins.
Once the Harddrive is slid over, then lift at an angle; and remove.
Lift up on the Back of the Harddrive.
This is the opposite side of the one that plugs in.
Open the external enclosure case, slide the harddrive in; then close the external enclosure case. (Referring to Tigerdirect example. Other external enclosures will be different)
Plug the USB cable into any working computer's open USB port.
Look in My Computer/Computer. (WinXP/WinVista - Win 7)
The external harddrive will be shown.
DOUBLE-click on the drive letter it is next to.
Have problems with that post back in a Comment.
Your Netbook, is supposed to be just an ACER Aspire V5-171 series of Notebook PC; with a Chrome logo on it.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 05, 2013 | Acer Computers & Internet
External hardisk can't be format
Hi something wrong with the harddrive.
It may be the harddrive is damaged ( the spindle is weak ) or the cable connector from your cpu to the external harddrive may be bad.
Try to get a better cable connector ( i think yours is usb cable )
If the problem persist, try connecting the harddrive into another computer.
If the same problem arises, you may want to replace the harddrive ( or claim for warranty )
Jun 14, 2012 | Seagate Computers & Internet
About 2 months ago I bought a samsung s2 portable 1Tb. It has worked fine until yesterday. It slipped down from where it was laying (while plugged in and running) and was hanging the 20 cm usb-cabel. Now I...
Hanging by the 20cm USB cable?
The cable could be stretched, and wires broken inside.
The cable to small circuit board, inside the case, could have broken solder joints.
The circuit board inside the Samsung's case could be broken.
Inside that small outer case of the Samsung portable is a laptop size Harddrive.
The harddrive measures 2.5 inches across in width.
(6.4cm. In comparison a desktop size harddrive is 3.5 inches across in width, or 8.9cm)
The harddrive is a SATA unit also.
This is a general example of a 2.5 SATA harddrive,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148591
Inside the outer case (External Enclosure) is also a small circuit board (PCB)
The harddrive plugs into the small circuit board, and the circuit board has a USB cable attached to it.
(Or there is a small cable from circuit board to harddrive. Then a USB cable to the circuit board)
I would suggest removing the 2.5 SATA harddrive, and install it into an economical external enclosure.
Example of a 2.5 SATA External Enclosure,
Basic guidance in removing the Harddrive from a Samsung S2 Portable,
1) It looks as though the outside front is a thick cover like a label. It may be that you peel back the corners, and there will be a screw in each corner.
(For example; Where it states Samsung. Go to the right corner. Does this cover-like material peel back? Is there a screw underneath? Remove it.
Go to the opposite corner. Now above to the left and right corners)
The unit looks to come apart in two halves.
Might just be held together by sticky tape.
Here are some videos performing opening the external enclosure, (Case) of other external portable harddrives,
1) http://www.youtube.com/watch?v=dMzRYCZXVEs&feature=results_video&playnext=1&list=PLC129A4F797CCC09E
2) http://www.youtube.com/watch?v=Y2vUMO2mGLE&feature=related
There are other related videos. In general most are not very professional, but get the job done.
Regards,
joecoolvette
Sep 18, 2011 | Samsung S2 Portable HX MU010EA 1 TB...
Can not get computer to recognize hard drive any more?
You could try using another USB port on your computer. Perhaps that USB port you have the IOmega external harddrive plugged into is bad.
More than likely not, though.
The problem is usually inside the IOmega's case. (External enclosure)
Inside that IOmega external harddrive's case is a regular harddrive as used in a desktop, or laptop computer.
To explain;
Harddrives are physically rated in width, as well as type, and size.
A laptop harddrive is 2.5 inches across in width. (2 and a half inches)
A desktop harddrive is 3.5 inches.
The larger desktop harddrives are usually used in external harddrives that are 500GB, and larger.
(Not always the case when it comes to the 500GB size)
Harddrives have two technologies, or types.
IDE (PATA) or SATA.
You didn't state the Model Number so I can't even hazard a guess at this point.
The harddrive inside the case plugs into an Interface.
The Interface may be separate, and connected via a cable to a small circuit board, or the Interface may be soldered directly to the small circuit board.
It is this Interface, and circuit board which go bad.
The solution is to remove the harddrive inside, purchase an inexpensive external enclosure, and install the harddrive into it.
The external enclosure has a USB cable just like the IOmega external harddrive did.
As stated the harddrive inside is just a normal harddrive. Made by a harddrive manufacturer.
Could be a Western Digital, or Seagate, or Hitachi, or Maxtor, or Fujitsu, or IBM, just to name a few.
(Seagate bought out Maxtor)
On the harddrive will be a decal with it's specifications.
You will also be able to physically measure the width.
This external hookup will support harddrives that are 2.5, or 3.5 inches in width, (And 5.25), plus will support both IDE (PATA) or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7220658&CatId=3770
This external enclosure is for a desktop sized harddrive, 3.5 inches, and will support either IDE (PATA) or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1951866&CatId=2780
This external enclosure example is for laptop sized harddrives, 2.5 inches, and will support either IDE, (PATA), or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7041055&CatId=2783
Just one example of how to disassemble an IOmega Select Portable harddrive,
http://www.youtube.com/watch?v=NvUvz5Qb4vw
Other styles are listed in the Suggestions column down on the right.
Not a good source for information on disassembling an IOmega external harddrive, but there is very little info available.
(It isn't that tough for any external harddrive enclosure. The screws are usually hidden under labels, and the case pops apart in two halves. Just a little different design here, and there)
Regards,
joecoolvette
Jun 14, 2011 | Iomega Computers & Internet
Lead from external harddrive to tv- to show films,--usb connection from harddrive to 15pin to tv
Dear ragalgey,
As far As I can remember, most TV design to receive the signal to watch whatever you want limited to available TV station in your local broadcaster.
If you think you connect your harddrive to TV USB or 15pin (VGA cable) then you can watch the movie file from harddrive is a totally wrong!
You need a drive or a player for those file that capable to configure your TV to play them. Or at least you need a PC or Laptop Computer that played your harddrive then send the images/video via Video Out Jack (Yellow) from your laptop, or connect the 15pin VGA jack from Laptop PC out then plug in to your TV. In this case you'll need the Jack/adapter to convert from 15pin VGA from laptop to available Video jack on your TV.
Good Luck!
Best Regards,
bionic23
Dec 08, 2009 | Samsung Computers & Internet
I have left my hard drive off for 12 hours as adviced, but on turning it on again the problem is still the same. The drive is trying to boot up over and over again.
My solution will be multipart, and lengthy. So if you're a coffee drinker, I suggest you make yourself a fresh pot
Reasoning? I'm going to explain a little bit about the hardware makeup of an external harddrive, and multiple solutions that in the hopes of one of them, may cure your problem.
I'm trying to arm you with as much information as I can, so you can use deductive reasoning, and take the best approach for You.
General symptoms that affect an external harddrive,
1.Bad USB cable. Although it is unlikely, USB cables can go bad.
2.Power supply.
To solve this problem, you need another power supply just like the one you have, for a test. ( Not exactly laying around. I have a work around for that, which I will detail later)
3.Controller failed.
Inside that external enclosure, (The metal, or plastic box of the external harddrive), is an ordinary harddrive such as used in a desktop, or laptop computer.
Yours has a Desktop size harddrive in it. (They measure 3 and a half inches across in width. 3.5"
Laptop HD's measure 2.5")
Harddrives are IDE, or SATA. All harddrives have been going to SATA for quite some time.
Yours is a SATA harddrive.
Inside the external case is an Interface, connected on a Controller Board.
Harddrives use metal round pins that are built on the harddrive itself. These in turn plug into an Interface, or also can be referred to as a Socket.
With an external harddrive, the harddrive itself may plug right into the Interface, (Socket. The metal pins of the harddrive plug into the Interface socket holes), or the Interface plugs onto the harddrive, and cables lead from it to a small PCB in the external harddrive enclosure. (Case)
The metal pins transfer data (Information) back and forth. (Signal pins)
Power for the harddrive is also transmuted through these pins.
Just like plugging in a lamp to a receptacle.
The Controller Board is a PCB. Printed Circuit Board.
This is connected to the bottom of the harddrive. It controls the mechanism inside the harddrive.
This is a link to Howstuffworks>Computer Channel>
Computer Hardware>Hard Drives and Disks>How Harddrives Work,
When you arrive at Page 5 you'll see the Controller Board. (Their term is Electronics Board)
The Controller Board can be safely removed from the harddrive, and not ruin the harddrive.
You cannot open a harddrive case itself, where the Platters and Arms reside, Unless you have the proper environment.
('Clean Room'. A 99.9% dust free room that would make NASA jealous! This type of room is where a typical harddrive is assembled)
If you use an ESD wrist s-trap and connect it to a good ground source, plus work on a table, you can safely remove, and replace the Controller Board. (No magnetism Anywhere near! NO speakers!)
An average ESD (Electro Static Discharge) wrist s-trap is about $6.
This link shows the connector pins I have been referring to,
http://en.wikipedia.org/wiki/File:Hdd.jpg
(You can click on the photo to enlarge it)
At the bottom of the photo is the back of the harddrive. All the way to the right are 4 pins. These are not recommended to be used on a SATA harddrive, but are for power to the drive.
All the way to the left, is a connection which has 15 pins for the Power connector, and to the right of it are 7 pins for the Data connector.
(It's in the upside down U shaped opening. There is a rectangular wide opening all the way to the left, then a narrow rectangular opening, then the upside down U shaped opening)
4.Harddrive failure. The mechanism inside the harddrive itself has failed. These are mechanical components, as you can see in the Howstuffworks link. Average lifespan for a harddrive is 5 years. Depends on how much it's used.
Solutions:
A.If the harddrive is still under warranty, you can see if the manufacturer will replace it. HOWEVER, they do not guarantee anything that is stored on it. You will get another harddrive minus your information.
B.You can take it to a Data Recovery Specialist. Average price is $50 per hour on up. Average time is minimum 1 hour, and usually takes 3.
I could be mistaken, do research for your area.
C.
1.You could start with using another USB cable, and see if this is the problem.
No?
2.Then it's on to the power supply. This solution cures 2 possible problems. I didn't mention, that sometimes the small PCB board in the external case also goes bad. Most of the time, according to hits on the internet, this is a major problem with a LaCie external hardrive.
The small Printed Circuit Board inside their external harddrive case, (Enclosure), goes bad.
Solution is to buy an external enclosure for a 3.5" SATA harddrive. Take the harddrive out of the LaCie external enclosure, and install it in this one.
Check computer hardware websites on the internet. (Examples of two are Tigerdirect, and Newegg) Look for Harddrive Enclosure. Then 3.5, then SATA.
Average price for a decent one is $20.
3.If this doesn't cure it it may be the Printed Circuit Board on the bottom of the harddrive. If your data warrants saving, then you may want to buy the SAME style of harddrive, borrow it's PCB, and get your information off of your old harddrive. More cost I grant you, but cheaper than a Recovery Specialist. You aren't buying another LaCie external harddrive, you are buying just the saqme SATA harddrive used inside.
Past this, the harddrive mechanism itself has quit. Only a very competent, reliable, Recovery Specialist can recover your data, if possible.
Nov 01, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Watch movies and music off Wd harddrive conencted to PS3
If you want to hook up any kind of external HDD or flash drive via USB to your PS3, it needs to be formatted in FAT32.
Sep 29, 2017 | Western Digital WD Passport 250GB Portable...
Did a system recovery on pc now can't find my harddrive
Hi Shannon,
yes, you could - and should - connect the external harddrive directly to your pc in case it throws errors. You will need to do this in any case to figure out, what is wrong with the drive.
Connect the USB cable to your PC and check whether the drive is recognized by your Operating System. If it fails to be detected get back to us and we will try to help you.
Jun 30, 2017 | Maxtor OneTouch III Mini Edition (R01E100)...
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
