Question about Vtech VT 2931 Cordless Phone (VT-2931)
INTERCOM I have V-tech model mi6889. If someone is on one phone I push talk to get on with them on another phone. That part works fine. However, how do I get off the line w/o hanging up the phone??
0 characters
1 Points
My phone said it is on hold but I do not have a hold button. How do I get it off hold ?
Which model is it? This is a shot in the dark, but perhaps it is like call waiting. Push the green talk/flash button. Some Uniden models have a "Intercom/Clear" button. If yours has one, push it. You may have accidentally pressed it during a call. On the "base" there may be a "FINDHS/INTERCOM" BUTTON. Push that button. Hope I helped.
Jan 05, 2015 | Uniden Cordless Phone
Intercom does not work
There needs to be an additional instruction. I am having the same problem. From standby mode, I press Intercom, the screen says "Please wait" for 2-3 seconds, then I choose a handset. Nothing happens. The user guide doesn't have any additional instructions after this point. I don't hear any paging or anything other than silence on any handset.
Jun 15, 2011 | Uniden D16602 Twin Cordless Phone
How to use the intercom system
  • Check your telephone to see if it has an intercom feature. Many wireless phones that come with multiple units allow you to temporarily turn one unit into an intercom to contact other units attached to the same wireless phone system. Depending on the model, you can contact all the other phones at once, or a single specific phone, by pushing the intercom button and entering the other mode. To put the phone back into regular mode, all you have to do is switch off the intercom option.
  • Contact your telephone provider. Some telephone service providers allow landline phones to call themselves, which enables the phone to function as an improvised intercom. You would simply pick up the phone, dial and then close the connection. Once the phone is answered elsewhere in the house, you will have established a line to another phone and you can speak normally on it. This has largely been eliminated due to lack of need as technology advances, but it may still be an option with some providers.
  • Purchase and install an intercom system that will work through an existing phone line. Many of these products, some of which are produced by Panasonic, operate as a halfway point between a traditional intercom system and a phone line. The exterior intercom links directly to the phone line, and you can pick up the phone and talk through the intercom unit outside once the system is properly set up
  • Dec 18, 2010 | Uniden Cordless Phone
    Panasonic KX-T7633
    You're in luck. Without picking up the handset, press PROGRAM the line 1 button, and dial 0 001 (or 01) and STORE. Press PROGRAM to exit.
    If I "guessed" right, on your TDA system, you have line 1 back.
    Sep 17, 2009 | Panasonic KX-T7633 Corded Phone
    How do i use the intercom on my Uniden dect. 6.0?
    March 25, 2013 - INTERCOM INSTRUCTIONS
    Here is the answer! Press the INTERCOM button one time.
    The INTERCOM display will show on the screen.
    Use the UP or DOWN arrow button to select the HANDSET number.
    Press the MENU/SELECT button to ring the HANDSET selected.
    Press the END button when done talking
    Sep 01, 2009 | Uniden DECT 6.0 Cordless Telephone...
    Intercom use
    We have the 25414RE, so I can tell you how ours works and hope it helps solve your problem...
    You first have to assign each phone a "number". Push the menu button, and go to phone options (you scroll by pushing the review button to the left or right), choose set phone id (once you are on that option push the select/save button just above the review button) - I started with the first phone I plugged in and made it number one, and so on (we have a total of 5). Once the phone ids are established, simply push the intercom button and the corresponding number on the right speed dial/intercom numbers - it should dial the phone you want. It also has an option (again we have the 25414RE) to have the phone auto answer the intercom - so if you are paging someone in a room that isn't near the phone, or the phone is shared by several users, it picks up without anyone having to push anything. Otherwise, the phone that you are calling has to either have the handset picked up or the speaker button pushed. Hope that helps you!!
    Mar 10, 2009 | RCA 25404RE3 Corded Phone
    Misplaced one of the phone
    I looked up that model and they are equipped with intercom service.
    What good would an intercom function (I ask myself) without some way to ring another handset? It wouldn't make sense to have to holler for someone else to pick a handset ;-)
    The phone's control layout is identical to ours (it is 2.4 gHz instead) so check the lower right-hand corner for a button perhaps marked Hold & below it 'Intercom' printed.
    Using that function, you choose the station # and it will ring the remote (lost) handset until someone picks it up and presses Talk or speakerphone button. .
    Sep 03, 2008 | Panasonic KX-TG1033S Cordless Phone
    How to use intercom between two handsets
    For models with 2 or more
    handsets included
    Making an intercom call
    1 Press {INTERCOM}
    2 To page the base unit, press {0}.
    To page another handset, enter its
    extension number ({1} – {4}).
    The destination unit beeps for up to 1
    minute. Someone else can answer the other unit and talk to you.
    3 To end the intercom call, press {OFF}.
    Aug 18, 2008 | Panasonic KX-TG5632 Phone
    Vtech VT 2931 Cordless Phone (VT-2931) Logo
    14 people viewed this question
    Top Vtech Phones Experts
    Are you a Vtech Phone Expert? Answer questions, earn points and help others
