Question about Mitsubishi WS-55819 55" Rear Projection Television
Number "2" showing up in the upper right hand corner of screen
I've owned this tv for about 8 years and all of a sudden the number "2" shows up in the upper right hand side of the screen. I've gone through all the menus trying to figuire out what it is and how to get rid of it. It's only on the Cable input and I've unplugged the cable box so I know it's not coming from there. It's on ALL the time, never changes or goes away. Any clue what it is or how to get rid of it.
    Scholar:
  • 195 Answers
After 8 years, you need to go buy # 1
Posted on Dec 07, 2008
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
I have upgraded from MS windows 8 to 8.1 Now I have lost my internet connection. The router is working fine
Sounds like your WiFi isn't connected. Pop the charms bar out of the right hand side by putting the mouse in the upper right hand corner, and go to settings.look for the WiFi icon, click it, is it connected?
Nov 30, 2013 | 2wire 2700HG-B Router (2700HGB)
My philips flat screen shows no signal and #3 in right hand upper corner just happened when cat knocked over remote no sound
To which model television are you referring? It sounds like you either need to change the input method for the TV or just change to a different channel (2 or 4).
Dec 10, 2012 | Philips Televison & Video
A lock icon has appeared on the screen in the upper right hand corner and i can't watch tv. the lock is a red thing on the blue screen.
it could be the child lock, accidenty activated from remote or tv buttons,...goto steup mode and switch off the child loc, or any lock that your tv indicates is active...if the problem continues, might be the gate ic, inside your tv needs repaced or reprogrammed...the number on that ic is in somthing 240co8......8 legged small ic..change it....or refer to qualified tech..
Oct 25, 2009 | Televison & Video
The picture on my LTV-19w3 WH tv just shows a blue, black, or green screen with about a 4" sq. plaid patch in the upper right hand corner. Sometimes the sounds works other times it does not. Can anyone...
While the TV is on do the following:
1. Press the "Right Arrow" button on the remote.
2. Press the "Left Arrow" button on the remote
3. press the number keys in order, 1-9
I believe you are in the TV's service menu and the Blue/Green/Black are just test patters. If so, pressing these keys will eventually change the pattern..
Get to the main page of the service menu and press the [power] button on the remote.
Jun 16, 2009 | Westinghouse LTV-19W3 19 in. LCD...
LCD Screen says ''2 missed calls''
The "[1]" (or other number) in the upper right is the number of the extension. If you have more than one extension, they will each have their own number. Unfortunately, I can't anwer your other question as I have the same problem myself.
Feb 16, 2009 | Panasonic KX-TGA101S Cordless Handset
Number 2 in upper right hand corner of screen
Had this problem also when I rebooted my Time Warner Cable box. Unplug everything from the wall including power strip and wait 60 seconds then plug back in and turn everything back on. Worked for me and havent had a problem since. Time Warner does not know what causes this yet.
Jan 28, 2009 | Samsung LN46A530 46 in. LCD HDTV
Can not remove the number of the tv channel from the screen
How to remove the green number three from the right corner of the tv screen without having the original remote as the cable company suggested.
Dec 12, 2007 | Televison & Video
Sungale dvd2026
I found a "hack' to make mine work :)
1. Open the tray
2. Press "Setup": Menu Screen should appear
3. Press "8-8-8-8" ( if you changed the password, you might have to change it back to 8888 ) The region number should appear on upper right corner. No other notation. Typically just the numeral "1".
4. Use the right (->) or left (<-) arrow keys to change the region to 255 for all regions.
5. Use the up or down button to go to 3001 and 4000. I had to change 4000 to 4001 to get mine to work,
6. Press "Setup" to exit.
It was a big relief to find this hack, because I misplaced my receipt and thought I was simply out of $30.
Dec 09, 2007 | Philips DVDR725 DVD Player/HDD Recorder
Mitsubishi WS-55819 55" Rear Projection Television Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
