Question about Lexmark Office Equipment & Supplies
When I scan it makes loud buzz and says paper jam. every time.
    Problem Solver:
  • 10 Answers
Some dust in the Scanning Wheel, or rusted on the rod
Posted on Dec 07, 2008
Well, I did everything your steps said to do but that did not fix the problem. When all is done and turned back to online, the printer buzzes and flashes the 13 paper jam again; however, there is no paper...
If your printer makes a load clicking sound and then shows "paper jam" then the problem is a broken drive motor gear. This is a very common problem with this unit. The nylon gear on the drive motor becomes brittle due to the age of the unit and cracks. When this happens the gear teeth do not mesh with the other gears and you get the grinding and clicking sound, and no paper pickup. You can change the gear yourself. The drive gear is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_49&products_id=61
And here is a video showing how to install it:
Jan 28, 2011 | HP LaserJet 4p Printer
CLEAN CARRIER JAM
Open the access door on the back side of the printer to remove the jam.I once used some paper that always went into my printer two or more sheets at a time,causing a jam.I flipped the paper over ,then it would load a sheet at a time.Hope this helps?
Dec 20, 2009 | Dell 924 All-in-One InkJet Printer
Said paper jam, but there is not
plz make sure the paper u r scanning does not have any folds....and is thin to enter ur scanner...
please vote for me...
Oct 04, 2009 | HP 5510 4-in-one Printer
Loud buzzing noise
seems the the motor is ****! avoid switching it more further to prevent its motor from burning!
motor could be stuck due to rust build-up.
or something might have jammed along the motor area or along the rotating part.
Jun 18, 2009 | Dryers
Sharp AL1642 CS Copier Grinding noise and Paper Jams
Loud clacking sound, jamming in fuser ? sounds like the gear that turns the fuser are bad and not meshing together,
accordion jam is the fingers or claws that ride on the fuser roller are probably worn out ( these can be replaced usually 3-5 ).
You can buy the parts and replace them yourself if a handy person, not that difficult.
Nov 19, 2008 | Sharp AL-1642CS Copier
HP C3150 Printer Continuing Paper Jam Errors
Sometime the ink jet mechnism is out of time or it gets stuck in the lock position. You might want to see if it looks like there crooked in the trays at the end of the printer.
Jul 04, 2008 | HP Photosmart C3150 Printer
Samsung SF5100 has a loud buzzing noise
Hi there you might have a faulty toner cartridge is it a original or has it been refilled? I suggest to install a new toner cartridge and hopefully that will cure the fault. If this dosen't there maybe a small piece of paper stuck in the cartridge or after the toner cartridge within the heat section open the back of the machine (the jam door) and check there is no paper.
If the printed document is getting stuck just after the toner cartridge it will most likely to be the heat section will need replacing.
Hope this helps you and please rate me
Thanks J
Dec 31, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
My New ML-2010 creates a loud annoying sound!
Ok, it is good you checked for paper jams. I need you to look inside the unit where the paper roller is on both sides and see if both sides look even and the same. It still sounds like a jam to me, and this would definitely create a loud sound as your unit is trying to print for you and the mechanism will keep trying to turn even if it can't. Something may snap or break if there is a jam so make extra extra sure you check every nook and cranny as jams can be so very tiny. I found a piece the size of a matstick width in mine that my toddler had posted in it, and it was caught in the paper roller teeth inside the unit. When you open your printer, does the cartridge holder roll by itself to the left or stay still??? Take out the toner cartridge and thoroughly clean inside with solution and replace.
Aug 16, 2007 | Samsung ML 2010 Laser Printer
26 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
