Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Picture goes to verticle colored lines then goes blue screen tv s
Shuts off push reset repeats same sometimes 3min or 3hours
  • ms29668 Dec 11, 2008
    just got rebuilt chassis back from mitsubishi same problem.
  • 505 Answers
This is likely capacitors failing in your DM or FMT module. This model is know for the 1000uf caps going bad after 4 years or so. There are 4 on each board, plus 4 on the power supply that may go bad. You can tell by the bulging tops that are not flat. Two 3300uf caps go bad in the power supply regularly as well. I recommend getting a service center to send the whole signal block or chassis into Mitsubishi for rebuild to get it all taken care of. The dissassembly is very difficult and frustrating. If you have tons of time and determination you could repair yourself.
Posted on Dec 07, 2008
  • thielectronick
    thielectronick Dec 12, 2008
    Rebuilds take 4-6 weeks from Mitsubishi, how did you get your so fast? It would have to be the DMD board on the light engine but typically the FMT board of the chassis is at fault. Vertical colored lines is a video processing malfunction usually, maybe mits has some of the final scaling done on the DMD board (light engine).
Picture goes black with gray fuzzy lines ~ 1/2" apart horizontal.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sanyo DP50749 50 in. Plasma TV
Purple and blue screen on dlp tv
Sounds like a problem with the Vertical Video Card.
Have fun finding one. If your TV is still under warranty... send your TV off for repair.
Oct 03, 2012 | Samsung HL-R5656W 56" DLP HDTV
Vizio screen problem. Please help!
The screen is ok Your T-Con board quit. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 03, 2017 | Vizio VO320E LCD TV
Samsung ln46b630 started with verticle lines still have picture but it looks fading with lines on top of it started this 2 monthes ago cleared up then started back last week & now the the lines are...
screen ribbon needs resetting not an easy job to do if you not done them before as you need to take the screen out and remove the screen shield off to get to the ribbon, then put a foam or rubber spacer over the ribbon so that when you fit the shield case back on it just pushes on it slightly so it has good contact. and its best to do all the ribbons as this will help it not do the same to the reset.
Dec 24, 2017 | Samsung LN46B630 LCD TV
I have a Panasonic Multimedia Projection HDTV when tv is turned on it has red & blue color spots & red verticle lines showing on the screen what could be causing this to be happening
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have shadows colors pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Power comes on but no picture
I have the same problem. After power on I just get a blue screen and no sound.
I can get a piture and sound if i do the following.
Leave the TV on for a minute or two then unplug the power while still on. Plug back in and power on. I begin to get sound, repeat and then I get a picture for a few moments then blue again. Repeat and then I get constant picture with defunct colors. I then use the remote to power off and back on an color corrects. sometimes have to repeat this as well. Sometimes it takes unplugging, replugging, and powering on up to five times before i can sit down to watch tv.
Nov 16, 2009 | Advent HT3061A TV
Mitsubishi VS-50707 screen is jittery when it first turns on
Sounds like the verticle circuit is failing a honest shop will take of this for you around 180-230 if you want to do yourself youll need a iron and some filters and an verticle ic
Sep 26, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Rainbow of colors on screen
I just had a rainbow of colors on my tv screen...i thought it was a problem with my TV...however the screen went the "sign off" screen (verticle lines-red/blue/green) Then all of a sudden the picture came back and all was back to normal again.
So I say it's nto your TV it is a station problem!
Aug 04, 2009 | Panasonic Televison & Video
40 samsung lcd picture problem
first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
Sep 01, 2008 | Samsung Televison & Video
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
98 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
