Question about Oregon Scientific Oregon S54 Replacement Saw Chain
McCulloch Pro Mac 610 replacement chain
What is the proper replacement chain for a McCulloch Pro Mac 610?
  • Anonymous Feb 05, 2009
    clutch lock for the chain, the spring popped when we changed the chain and we can't get it back on properly.
The McCulloch ProMac 600 series (610/650) doesn't recommend a saw chain replacement part because you can get differently-sized bars for it. This one came with a 20" bar.
According to an Amazon.com search tonight, the Oregon company makes a replacement part stock number D70. I have got an Oregon H78 replacement chain at my hardware store and it's a hair too small. Not all 20" saw chains are created equal!!
Posted on Jul 02, 2010
How do I replace a pull cord for pm 605 mcculloch chainsaw?
First remove the pull starter housing.
The next part is tricky. You'll have to release and unwind the spring that rewinds the pull starter cord. Remember how you do this because after replacing the cord, you'll have to rewind the cord and spring before inserting it back in the housing.
re-attach the pull cord housing to the chain saw.
Hope this helps.
Oct 19, 2014 | McCulloch Pro Mac 605 610 645 650 655...
Mcculloch chain saw,pro-mac 610, with electronic ignition, no spark at plug
If there is no spark with a new plug, and the earth cut out wire not connected, then it will require a new ignition unit, the old unit is not servicable.
Oct 28, 2011 | McCulloch Garden
I have an older McCulloch chain saw- Pro Mac 610. When using the saw the chain will get very tight. If I adjust the chain to the proper tension, make a couple of cuts the chain loosens and must be...
The main reason for a chain to tighten is because it is not getting enough oil to the bar, or too thin an oil is being used, you should see a good spray of oil off the end of the bar when held against a tree stump, if not try adjusting the flow if it has an adjuster.
Apr 01, 2011 | McCulloch Points Pro Mac 6 Or 6a Chainsaw...
Need to replace fuel line on pro mac 610. How do i get the thing apart to replace it. Any schematics available?
This one?
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/564ff25e56449e8c88256c2f001cd723?OpenDocument
A McCulloch 11-600041-02 example follows (may not be your saw):
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
http://www.ordertree.com/modelinfo/MCC/11-600041-02-PRO-MAC-610-07%2F90-to-Current-IPL-218689-02/139.11-600041-02-PRO-MAC-610-07%2F90-to-Current-IPL-218689-02.1.59.1.html
If you want to try a different 610 print try here (many prefixes and suffixes for the 610):
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
This may help fill in a few blanks. The video explains how to put hose in the tank without taking it apart.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 09, 2010 | McCulloch Garden
I have a McCulloch chain saw- pro mac - 610- the saws chain lock came apart, do you have a diagram of one?
This saw? Be kind to your elders.
The IPLs I’ve found for your saw don't show this detail. I suggest you try here:
ArboristSite.com Chainsaw thread
http://www.arboristsite.com/forumdisplay.php?f=9 (free to join)
There is a McCulloch thread. Your saw is held in high regard. I’m quite sure some of the members will be willing to post some close up photos of the set up on their saws. HTH
Lou
Sep 27, 2009 | McCulloch Garden
Operator and parts manual
Robin219,
I have found an owners manual on E-bay for 7.99 + Shipping. Will this suit your needs? The Auction on it ends on Sunday the 25. Take a look at http://cgi.ebay.com/McCULLOCH-CHAIN-SAW-PARTS-MANUAL-FOR-PRO-MAC-610-%2F-650_W0QQitemZ360124205014QQcmdZViewItemQQimsxZ20090119?IMSfp=TL090119129004r31016 Hope this works out for you.
Jan 21, 2009 | McCulloch Garden
How to adjust carb. settings on a McCulloch Pro Mac 610 chain saw
turn both jets in untill snug (don't force) turn out ccw one full turn. increase by 1/8 turns untill set proper. should be between 1 1/4 and 1 1/2 normally. good luck. be safe.
Sep 13, 2008 | Garden
Oregon Scientific Oregon S54 Replacement Saw Chain Logo
3,804 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
