Question about ASUS Eee 4G Notebook
To upgrade my Asus Eeepc 4G
I have an Asus Eeepc 4G, with 4 gig of SDRAm and 512 Memory. Can i upgrade it to at least 20 gig or 40 gig and memory of 1 or 2 gig?
Thanks!
Cheryl
I've got the same little EEE as yours. I just did a bit upgrade my little one with a ram DDRII 2GB. That's the most it can go. I asked about the internal HDD, they said that EEE-PC has a built-in one. So, it ended up that I put an internal HDD into a box. That will solve it all. And...OH! I changed WINXP to Linux as well. That saved some space...I believe.
Posted on Feb 03, 2009
    Scholar:
  • 55 Answers
The only way you can add space is for you to use an external HDD because an Eee PC has a built-in hard drive that cannot be upgraded.
Posted on Dec 07, 2008
How much memory does HP Pavilion EN996AA have?
512 Meg (2 x 256Meg) Have a look here:HPS7310N
Maximum allowed 2 Gig (2 x 1 Gig)
Feb 01, 2012 | HP Pavilion s7310n (EN996AA) PC Desktop
I would like to know the type and max ram amount that can be installed on my laptop part # av3270-ee1 it says it has 512 now so I would like to go to 1 gig. I also have some keys in operative, shift...
Welcome to Fixya. Memory Upgrade for Averatec AV3270-EE1 Laptop, the Averatec AV3270-EE1 Laptop takes the PC2700 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your Averatec AV3270-EE1 Laptop to up to a maximum of 1.0 GB Memory, the system has 1 socket to install Memory, already with 512 MB (removable) standard Memory installed.
Thanks for using Fixya.
Feb 07, 2011 | Averatec 3200 Notebook
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Helo, i want to upgrade memory on my ASUS CUBX-L motherboard. Manual says it recive max 4 x 256 MB of SDRAM. Is it possible to put 512 MB or bigger RAM modules?
yes you can put 512 mb of ram even 2 of it because the capacity of your board is up to 1024 mb of ram but make sure that it is an sdram and it has the same specification on whar is your manual indicate besides on the ram size.
Oct 14, 2010 | ASUS Intel 440BX Chipset CUBX-L...
Can I put a 4x/8x AGP card on this motherboard? Also can I upgrade the memory to 1 Gig of PC2100 SDram Non-ecc unbuffered?
The AGP (graphics port) only takes 4x on this motherboard, you can upgrade the memory as far as 2 gig, so yes you can upgrade the memory to 1 gig pc2100.
Feb 06, 2010 | EliteGroup L7VMM2 Motherboard
How to install memory upgrades on GATEWAY GT 5042B PC
CLICK HERE. to get all the information you need about your computer.
Memory:-
  • Installed: 512 MB DDR2 533 MHz (PC4200) SDRAM
  • Expandable to: 4 GB (4 DDR2 slots)
  • If you want to know how do i install it? CLICK HERE.
    please rate my solution very high, if this infornmation is helpful.
    Sep 23, 2009 | Generic Memory Computers & Internet
    Ram Upgrade
    Max speed supported for your mobo is: DDR2-533
    You will have to buy (4) 1gb sticks (2gb sticks not supported)
    To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
    Here is the specs :
    ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
    CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
    Chipset: Nvidia GeForce 6150 LE Chipset
    HD Bus:
    Front Side Bus options:
    Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
    Special notes:
    - Motherboard manufacturer's name: ASUS A8M2N-LA
    - HP/Compaq name: Nodus-GL8E
    NOTE: *Actual available memory may be less w/o 64 bit os
    Dec 24, 2008 | Computers & Internet
    Upgrade beyond limits
    if you goto this link it will tell you what you can put into your comp you can only put in the maximum it tell you the link is http://www.crucial.com this will scan your computer and tell you everything about it and anything you can put in it.
    It will also tell you everythin that is compatible hope this helps you let me know how you get on ok
    Nov 29, 2007 | Sony VAIO Digital Studio PCV-RX550 PC...
    Memory swap
    This is the memory specs for your board 4 x 184-pin DIMM Sockets support max. 4GB unbuffered non-ECC PC3200/2700/2100/1600 DDR SDRAM memory Dual-channel memory architecture
    Jun 08, 2007 | ASUS P4S800D-X Motherboard
    ASUS Eee 4G Notebook Logo
    807 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
