FixYa.com
Tags:
RCA RT2280 System
Surround cuts out??? (by 2 users)
posted by justmack14 on Mar 05, 2007
Hi I have a problem with my rca rt2280??? When I am in surround it works then it cuts out then it works then it cuts out I don't understand but when it is in 2 channel mode it works fine so I think it might have todo with the dsp processing chip there might be something wrong with it??? Could you please help me thanks
Justin
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by decube, posted on May 21, 2008
I have the same problem with the sound constantly cutting in and out. I noticed though the longer it goes on the longer it will stay out. It is hooked up with a digital audio cable and has been working for at least 6 months now. I have had it since 2002 so I don't know if it is just past it's time?
Best Solution
posted on Jul 09, 2007
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Are you useing a digital audio cable when its cutting on & off? How long between the on & off? I have the same problem when I use a digital audio cable or a coaxial audio cable from my DVD player. To use the surround (6 CH) feature you need to use the 6 channel RCA jacks and if what ever your hooking up dosent have the RCA outputs your out of luck. My DVD player does have the 6 channel outputs and they work but the digital cables won't work. What are you connecting to it? I think something is wrong with the digital circuit board in mine, I would like to replace it and see. Reading your manual will help understand the 6 channel RCA and fiber optic digital cables. I hope any of this helped.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Home Theater Systems problems?
RCA RT2280 System
no sound
Iv had this surround sound for... Answer This...
RCA RT2280 System
TV died slowly
My ProScan died slowly. If I... Answer This...
RCA RT2280 System
no sound from my rca rt 2280
after being subjected to low or... Answer This...
RCA RT2280 System
direct tv remote code for...
We lost the remote for the RCA... Answer This...
RCA RT2280 System
RCA RT2280 surround sound mode...
I have my dvd player (this... Answer This...
Repair Service
Find Home Theater Sys. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
