My sub makes a wierd sound like theres plastic vibrating and if i turn my stereo up past 10 it shuts off, and now i think its fully blown, is there a way i can fix that myself? or will kicker fix it? its a 15" solobaric L7 and its lie 4 months old
    Scholar:
  • 195 Answers
Take packing plastic out.
Posted on Dec 07, 2008
Backfeed problems
a noise filter, and upgrading your RCA's, i had the same problem with my subs. Heard a wierd sound when i turn my stereo off or change songs. Got some monster cable and the problem stopped
May 09, 2010 | Car Audio & Video
10 inch subs need help
It sounds like the wiring either to the amp or to the subs is put together wrong. This can be because you have them setup in stereo but have the sub on bridge mode or vica versa. This can also be from how you ran the audio input wither from speakers or rca..either wired wrong or the switch for the two options is wrong. Also make sure your gain is turned up. Sound also depends on what kind of box it is in. It HAS to be in a box.
Jan 28, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Kicker sub wont work
Im guessing that it is possibly blown... either you ran too much power to it, or it was hooked up wrong... you should unscrew the sub from the box and look inside to make sure that it is connected correctly.... positive to positive, negative to negative,,, if they so much as touched then the L7 could very well be blown.... smell the magnet and if you smell a burnt smell... it is blown... maybe turn your amp down a little... its possible that it is also in protect mode because you are running too many watts to the amp. Feel free to ask if you have any other questions.... Please rate! :D And good luck... i really hope its not burnt out. that stuff is not cheap.
Dec 29, 2008 | Kicker Car Audio & Video
Do you know if my woofer is blown?
well if you hear a rattle sound its probably already blown...and the amp could be drawing too much power if the radio shuts off...make sure all your wiring is correct. also if your car is off and you turn it up it will most likely shut off cause the battery cant handle it. but as for the sub i think its blown. good luck
Nov 16, 2008 | Jl Audio 12W3 Car Subwoofer
Sub works but doesn't sound right
hey been there before u need new rca wires form ur radio to the amp.
Nov 12, 2008 | Jl Audio 12W3 Car Subwoofer
Subwoofer just stopped working. There's power but no sound.
I have the same problem. My guess is that the subwoofer coil is messed up. You MIGHT have to get it recoiled. But before you do any of that get someone with a sub to play their sub in your car, if it works.... then your sub is messed up, if not.....then your amp is messed up ( trial and error ). Today i noticed my subs rubber surrounding is crooked, that may be the problem for me. Also when I press down on the sub it makes a sticking sound, like something came loose. So once i get everything opened and out ill let you all know the solution. Good Luck!
Jan 05, 2008 | Jensen JS1000-A Subwoofer
Alpine pdx 1.1000 amp
These subs are dual voice coil I'm sure...make sure they are putting a 2 ohm load on the amp total, and also set your gain and frequency setting right. Set the frequency around 85 or 90, make sure the lo pass filter is on. Turn the gain ALL the way down and turn your stereo to the point right before your speakers distort....then slowly increase the gain until the subs are playing at full volume. This should not even be close to all the way up, and the subs should sound accurate and bold. Turning them past this point will cause distortion, in which case you should back off the gain a bit. Distortion causes power to cycle through the amp very rapidly and can cause blown subs and blown fuses. If you do not know how to wire both subs for a combined load of 2 ohms, please let me know what type of subs you have.
Aug 05, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Mission speakers...i think i've blown one of them...
I'm guessing you mean one of the bass drivers (as standmount or floorstanding speakers don't have subs as such). Place your hand lightly against the driver when playing some music at normal volume, there should be some vibration (this increases the louder you play). If there's no vibration, you're probably right.
Contact Mission, who can send you a new driver, contact a Mission dealer to see how much it'll cost to go through the dealer network. I'd recommend going down the latter route if you are unsure of what to do yourself.
Just noticed you posted this in March, in which case, I hope you got it fixed (or are enjoying your new pair instead!).
Mar 18, 2007 | Mission 702 Speaker
Speakers are making wierd sounds
yes........maybe the ground is poor,pin jacks broken ,open ground in the preamp stereo ouput...all for the ground..try this........ take a pice of wire and put one end in ground of car chasis in area with no paint, and the other side in the amplifier input pinjaks and check if the static goes off. good luck.!!!!
Mar 13, 2007 | Lanzar HRWDC15 Car Subwoofer
20 people viewed this question
 Grubhead
Grubhead
