Question about Kitchen Ranges
Specs for burners for Amana AGS761W
I see the BTU output of the new ranges as high as 16,000, usually with a simmer burner at 5K and two burners at 92K or 95K. I'm wondering how high the BTU output is for my range. I've always been disappointed in how long it takes to use me burners to cook. They were listed as ''energy saving'' but if it takes twice as long to cook, how does that save energy?
    Habit-Forming:
  • 171 Answers
That maybe that it's on the propane settings fron the factory on the regulator, and it's running on natural gas.Or if you see that the burners go smaller and smaller as you turn one burner after the other. if that replace the regulator. you can also get bigger flames when you make the orifises bigger. that's what supplies gas to the burners.
Posted on Dec 07, 2008
Igniter switch on top burner will not shut off
try thoroughly cleaning the burners, particularly the holes in the ring that the gas come through. The gas come through to heat the ignitor so that the ignitor knows to stop trying to light the burner ; if the holes are clogged the ignitor doesn't heat.
The burner is easily disassembled from the top by removing a thin bolt, and you can clear the holes with a paper clip.
Sep 21, 2013 | DCS RGS-305 Professional Gas Kitchen Range
I need to know the btu input for a ge cooktop (gas) model gejgp975sekss
I see if I can find a diagram, ensure you posted right model number here.
Aug 29, 2008 | GE Kitchen Ranges
How can i adjust the burners to not be so hot? simmer is actually medium high rather than simmer
The switch itself is what cycles the burner to come on/off.
If it is acting up, you,ll need to replace the switch that controls the burner.
Dec 20, 2010 | Whirlpool Kitchen Ranges
HOW DO YOU ADJUST SIMMER FLAME ON AN LP RANGE WITH SEALED BURNERS MODEL WFG374LV01 THE FLAME IS MUCH TOO HIGH WHEN SET LOW
The simmer adjustment is behind the knob for each burner.
Here are the instructions from the installation guide. Let me know if you have questions.
May 05, 2010 | Whirlpool Kitchen Ranges
Dcs 48" gas range igniter comes back when set on low/simmer
This is not a solution but something to think about for troubleshooting.
On the DCS there are two ports that feed gas to the burner.
One for high flame and one for simmer.
On the DCS if the flame is snuffed out on simmer it will automatically reignite.
So if the igniter will not shut off while on simmer, the sensor is bad and is trying to reignite the burner.
May 11, 2009 | DCS 24-24G-1 Gas Kitchen Range
Burner flame too high
make sure you have a gas range and not a propaine range. You may have a bad pressure regulator.
Nov 18, 2008 | Whirlpool GS460 Gas Kitchen Range
Jenn-Air JGD8130
i have the same problem.. jgd8130.. can i change out the burners or orfices..etc to make one or two of the burners for more btu's? ro9beam2002@yahoo.com
Mar 09, 2008 | Kitchen Ranges
Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
Simmer is to hot
I am hesitant about answering your question because if the flame is adjusted incorrectly it could be dangerous.
Remove the knob and look inside the stem of the gas valve. You will see a very small adjustment screw. This is where you adjust the flame for the burner.
What I usually do is light the burner and turn it to the lowest setting. Hold the stem in this position and turn the screw. They are usuall kind of stiff to turn.
You want to adjust the flame so that it just comes to the top of the burner cap at the low setting.
This is the important part!!!
When you have got the flame adjusted, put the knob on and turn the flame to high. Quickly turn it from high to low, if the flame goes out, adjust it higher. Repeat this test until you can turn it from high to low quickly and it stay lit.
Also important to remember. When turning the screw, a little turn goes a long way.
Post back if you have any questions.
Oct 31, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Kitchen Ranges Logo
116 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
