IR sensor doesn't respond to several remotes including original. Only on intermittent occasions will it respond. Is there any way to fix this easily or somehow connect a new sensor without having to open up the TV?
  • Rah-Dawg Mar 28, 2009
    My Philips TV does not respond to any remotes. I believe the IR sensor on the TV itself is dead. I would like to know is it an easy fix? Can I replace the sensor myself, if so where can I buy the sensor...or will it require a professional?
    Scholar:
  • 195 Answers
Use it intermittenly, (Smile)
Posted on Dec 07, 2008
RCA flatscreen remote doesn't work
\its most likely the ir sensor which has the issue. I will need the model number of your set to help you further on the issue. You can reply to this same post for further assistance if needed.
Jan 01, 2013 | Televison & Video
Remote
does the remote controller is the original remote for your tv ?. if yes and doesn't work the cause is either the IR sensor of the tv is get bad or has a problem in the board.
Oct 16, 2012 | Sony KV-27S20 27" TV
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Directv remote and LG remote will not control tv, just receiver
Let's start simple first. Your TV is not responding to either remote control, but specifically if your factory original LG remote does not operate the LG TV, then the problem could be with the IR receiver in the TV itself.
Ensure nothing is blocking the IR receiver on the TV. Move anything out of the way.
Test both remotes to ensure that they are sending an infrared IR signal to the TV. Use a digital camera (such as the one on your phone) and point the remote into the camera lense and press the power/volume/channel buttons. You should see a faint flashing light in your camera viewfinder. This indicates that the remote is sending IR signal. If you don't see anything, then there is no signal. Try FRESH batteries.
If your remotes are working, and since this is an LG, look at the back of the TV by the video inputs. Look for a port called "REMOTE CONTROL IN" or similar. It looks like a 3.5mm headphone jack. This port is used for external remote control and may be dirty.
UNPLUG the TV, then use a regular 3.5mm male headphone jack to plug in and out several times. You basically want to push all the way in and all the way out several times to dislodge any dust and remove any oxidation that has built up in the port. 10-15 times should do fine.
Then plug in the TV and try your remote.
Best of luck.
Nov 05, 2017 | LG 32LG30 32 in. LCD HDTV
Remote works intermittently
Hi!
Unfortuntately, you and many others have this problem. I will point you in the direction of two "fixes" I have found.
Fix 1 is from Kenwood themselves, per the following quote:first try replacing the batteries if you haven't already. If that doesn't help, try resetting the receiver. Simply unplug the receiver, then press and hold the power button on the receiver while you plug it back in. Turn the unit on, and the display should say 87.50 to confirm the reset. If the remote still does not work, use a digital camera as an eye, face it towards the IR of the remote control. Depress any of the remotes buttons; you should see IR flash each time a button is pressed. If not then the problem is with the remote. If the remote works fine, then the problem is with the receiver. In order to determine the cause of the problem, I suggest you take the defective unit to a Kenwood authorized service center for evaluation. You can find information for authorized service centers in your area by visiting our website at www.kenwoodusa.com.
The second fix involves some very simple soldering, and has been endorsed by many as the solution:
http://www.remotecentral.com/cgi-bin/mboard/rc-theater/thread.cgi?3016%2C3
I hope this helps. Good luck and please let me know if this solves your problem!
Bob
Oct 09, 2008 | Kenwood VR-407 Receiver
My TV won't respond to the remote control
"My TV does respond to several channels from the remote , but not to all of them."
yoopergal , I know you love the little IR component az do I , The little IR may not be the problem.
What you may me experiencing is a remote control that has become defective or dammaged.
What kind of dammage is anybodies guess.
It could be the CPU inside , or it could be that the little contacts inside are not working.
so you may need to find a Universal Remote and you may want to check to see which one is the best before purchasing one.
When you look for a new (UVR) Universal Remote Control make sure you buy one with an small digital display so that you can see the alpha numerical data output of the remote.
Make sure that the UVR you buy contains the codes for the equipment you already own.
azkeyz@fixya.com
Wizard Division
Sep 23, 2008 | Toshiba 32A33 32" TV
If the remote is working but the TV will not respond, it means that the little IR receiver in the TV has stopped working. This is most likely because the receiver has burned out, but it could also have come loose. This is a very easy thing to correct, but the set should be serviced by a qualified tech.
Sep 03, 2007 | Philips PR0930X 9 in. Portable Television
IR Reliability--Intermittent
The Kenwood VR-510 does indeed respond to IR remotes. I now use a Logitech Harmony H659 which is IR only.
Your issue is a problem with the VR-510, actualy the whole series had a problem with cold solder joints on an assembly behind the front panel. Fix that and fix the problem. It frustrated me for 5 yrs.
Go here for the fix:
This site has the fix well documented: http://resnet.uoregon.edu/~gurney_j/kenwoodrepair/.
All is working great now!
Jun 08, 2007 | Kenwood VR-510 Receiver
MY DMR-EH55 has problems repsonding to the supplied remote control
Firstly, check you do not have bright light shining across the IR sensor.This can degrade the signal to noise ratio of the IR receiver.
Second, check you do not have a noisy mains electricity supply, arcing plug block or running from square wave inverter supply. Either of these can cause problems with IR receiver in the DVD player.
Feb 25, 2007 | Panasonic DMR-EH55 DVD Recorder/HDD...
TV not responding to remote
you can check your remote with a celular camera turn on the camera and point to the lens you most see the remote blinking if yes then wait for techman he will give you somes tips...good luck
Aug 05, 2006 | Samsung HCJ552W 55" Rear Projection...
Televison & Video Logo
135 people viewed this question
Top Televison & Video Experts
