Question about Sansui Televison & Video
Closed captioning can not find the options for closed captioning is the a way to set it up on my t.v. if so how can i get it i have hearing promblem.please help....... Thanks, Mrs.Lindsey
  • 195 Answers
Closed captioning comes on automatically, when you hit the mute button.
Posted on Dec 07, 2008
On set-up menu the closed caption option is not highlighted to engage closed captions.
are you using the original remote control of the tv? did you try the remote control provided by comcast? go to comcast website for further help.
Oct 04, 2015 | Televison & Video
Samsung LN-T4061F
To view the captions, all you have to do is turn on the decoder by following these simple steps:
  1. Access your TV menu screen using your remote or by pressing a button on the face of the TV.
  2. Select the closed captions heading. Several different caption options may appear.
  3. Select the "CC1" option.
  4. Exit the menu.
Closed captions should appear within approximately one minute of adjusting this setting. If they do not, review this portion of your television's operating manual or contact the manufacturer of the television set.
Public Television stations do not transmit Closed captioning
Apr 23, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Closed Caption keeps coming back on
When you turn it off are you going into the setup menu to do this?? if so after it comes back on and you go back to the menu and you see "on" You will need to save your settings before you exit out of the menu
Feb 17, 2008 | Televison & Video
How do I make the closed caption bigger. It has a black background and white letters that are too small. How do I fix it?
I suspect it depends on the TV. On my Viewsonic TV, I can select my CC font by choosing Menu > Option > Closed Caption. When the CC is set to On, go to Option and select Font Size.
On a Samsung TV, I use Menu > Setup > Caption. With the Caption set to on, then choose Digital Caption Option and Size.
Note if the captions are being provided by a set-top box, you may need to set the caption size on the box directly.
Please add a comment with your TV manufacturer and model; I'll try to find the specific directions for your TV.
I hope this helps.
Aug 12, 2011 | Televison & Video
Unable to find how to access the closed captions section
Hi scorpiow2001
If you find the tools button on your remote you should find captions vision in the section of the menu hope this helps.. Cheers nikki
You can go to this link and download the manual for you tv
Please take a few seconds of your time to rate my solution as i have taken time to answer your question the best i can Thank You......
Jan 17, 2011 | Sony BRAVIA KDL40XBR 40 in. LCD TV
How do I get the closed caption to turn off? It's been on for weeks, all the time. I've tried to turn it off from the remote: I press "menu", scroll down to "features" , go to...
What is the Source of the video? The captions menu item that you found will only enable/disable the closed captions from select sources, including your TV antenna or RF cable. For other sources (particularly HDMI), you need to disable the captions using the options for that source.
On my IPTV (fiber-optic TV) box, that requires entering the setup menu with a passcode from my provider. Next I go to the Hardware menu and find the captions option under the Audio sub-menu. On one satellite setup, I found that a secondary set-top box could only get the closed captions if they were enabled on the primary set-top box. Thus disabling the captions required accessing the set-top box's menu from the correct TV.
I hope this helps. Please add a comment with your TV source (make and model), if you'd like help finding the CC option menu for that device.
(With a slightly different IPTV set-top box, the included remote had a CC button that worked without needing the passcode. The current one doesn't.)
Jan 21, 2018 | Philips 42PFL3704D LCD TV
How do you get closed caption on
manual below. Turning On Captions Pressing the CC button displays caption options: ? CC on: Displays captions. ? CC off: Turns off captions. ? CC mute: Displays captions when the Mute button is pressed. To assign your preferences for captions, see “Using the Closed Caption Menu” on page 33.
Mar 17, 2010 | HP PL4260N 42 in. Plasma HDTV
I need to activate CC for my Dad, Please help I have to go to work. I have a flat screen SOYO
Determine if closed captioning is available on the program that you've selected. In your program guide, the letters "CC" should appear at the end of the description.
Locate the closed captioning option on your remote. Some remotes have a "CC" button that you simply need to push to activate closed captioning
Locate the closed captioning option in your television's menu if there is no "CC" button on your remote. To do this, push the "menu" button on the remote control. The closed captioning option will probably be in the same section as the language function.
Set the closed captioning option to "on." Within several seconds, you should see the text appear on your screen.
To use closed captioning for DVDs, look for the "CC" label on the lower back section of the DVD case where it lists audio information. Turn on your TV's closed captioning and you should see the captioning like you do on a television program. Alternately, some DVDs include English subtitles that you can turn on in the setup/language menu of the DVD.
Thank you.
Aug 28, 2009 | Televison & Video
Turning on closed captioning
Some older telivisions don't have the option hoever caption with always be under the menu. Or if your playing a DVd then under the language set up.
Feb 12, 2009 | JVC AV-20220 TV
Can't get closed caption when i'm playing a DVD
The DVD player needs to have the decoding built into it.
Sep 18, 2007 | Sanyo DP42746 42 in. Plasma Television
Televison & Video Logo
59 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
