Question about Car Audio & Video
Does the american pro amp have protection circuits for my subwoofers
  • 117 Answers
Probably not .most amps have a thermal shut donw circuit if the amps over powered (driven into clipping) or over heated ,this protects amp and any spks attchae to it check manual or website for model number and thier toll free ph number to call ....
Posted on Oct 29, 2009
I have an amp hooked up in my car.when I tried to connect the two woofers up to amp, the stereo cut off and the deck said that's all it will do is read protect.Wat do I do?
This is a circuit protection to stop you frying your audio! Could be a short circuit or wired wrong......remove the fault and it should reset! First remove the 2 sub woofers since that was when this happened and test the deck!
May 12, 2015 | Car Audio & Video
It goes into protection mode. how do i get out of it?
Check your speaker connections and speaker resistance of each speaker with an OHM METER. Most speakers are marked either with a 4 ohm or 8 ohm impedance. You might have a burned voice coil (shorted out) and the amp senses the short and goes into protection mode to protect the amp from being overloaded and burning itself out.
Sep 03, 2010 | American Pro VS1406 Car Audio Amplifier
Need a wiring diagram for a american pro 1406
Very simple :
12V+ = Red 8 Gauge Wire to positive battery terminal with a 30 Amp fuse
Ground = Black 8 Gauge wire to non painted surface on chassis of car.
Remote Turn on = Blue / white thin wire from radio's blue/white , this will turn on your amp.
A set of RCA cables which are self explanatory. Out to In or In to Out
Radio to Amp under carpet to back of vehicle along with your blue wire.
Then you have your speaker wires, you hook these up to your subwoofers.
Hope this helps, good luck.
May 21, 2010 | American Pro VS1406 Car Audio Amplifier
Just installed the sub it work for 10 sec then quit checked the amp and its working with a old sub do the subs freeze or something
The amp needs to "see" a load and if the new sub is incorrect the the amp will sense improper amps and will shut down, a protective circuit. Load the amp with the correct speaker....
Feb 13, 2010 | Kenwood eXcelon KFC-XW1000F Car Subwoofer
Dont have wire schematic to hook up american pro bass machine limited edition model 1406,need to know how?
You should go to they are very helpful and pretty much have a schematic for every single car audio situation and they give you all your options. If they have nothing go to and go to the learning section then subwoofer and amp wiring. It all depends on the subs that u wanna hook up to it as well as the ohm impedence and the amount of voice coils and so forth they have all of that.
Jun 13, 2009 | American Pro VS1406 Car Audio Amplifier
Trying to figure out what kind of amp i got amercian pro vs-3507?
The VS3507 Is a class D monoblock.
Your optimum wiring for this amplifier is a 2 Ohm load - so it produces its full potential power of 350W RMS.
To Achieve a 2 ohm load, the most common load is one of the following...
(1) Dual 4 Ohm Voicecoil Subwoofer Wired in Parallel.
(2) 4 Ohm Voicecoil Subwoofers wired in Parallel.
(1) Quad 2 Ohm Voicecoil Subwoofer wired in Parallel/Series.
(1) Single 2 Ohm voicecoil subwoofer.
American Pro VS3507 2000W Car Audio Monoblock Amplifier
American Pro VS3507 Monoblock Amplifier Details
  • Built-In Crossover
  • Variable High/Low Pass Filters
  • Phase Shift Control
  • Subsonic Filter
  • Bass Boost Control
  • Dancing Lights at the Rhythm of Music
  • Protection Circuits
  • Gold Plated Terminals
  • Power & Protection Circuit LED
  • 1 x 250 Watts RMS @ 4 Ohms
  • 1 x 350 Watts RMS @ 2 Ohms Thanks for using FixYa - A FixYa rating is appreciated!!
Jan 29, 2009 | American Pro Car Audio & Video
American Pro VS1405
Sounds like the thermal protection on your amp is doing its job. You can put an external fan in to help in cooling, like the crossflow type shown here, or a couple of muffin fans like these (look familiar?). You may have fashion a bracket to mount the fan(s), but that shouldn't be too much of a problem. Many fans are shipped with mounting tabs attached.
Jan 27, 2009 | American Pro VS1405 Car Audio Amplifier
The thermal protection would have reset when the amp cooled down. When cool, if it still goes into protection when it powers up, there are likely blown output transistors. To be sure it's not a wiring problem, disconnect the speaker wires 'from the terminal block of the amp' and disconnect the RCA cables from it. If it still goes into protection, the output transistors are almost certainly shorted.
Sep 09, 2007 | American Pro VS-2043 Car Audio Amplifier
Car Audio & Video Logo
80 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
