Do u know the power ratings (voltage & current in sensors)???
  • 1 more comment
  • karax Dec 07, 2008
    do u know the power rattings (voltage & current intake label sensors in zebra 110xiIII+).can we drive any relay by that current????
    can u hav the circuit diagram to trigger the relay by the take label sensor output??
  • Rob Duron
    Rob Duron May 11, 2010
    Which sensor? what are you trying to accomplish?
  • 55 Answers
I'm going to take a wild shot here. The voltage is most likley 5vdc becuase it's a logic device. as for the relay no you can't drive a relay with a current that won't smoke your sensor. You could however drive a transistor that could drive your relay. The current is going to be determined by the voltage needed to drive the relay and the impedance of the relay. (ohm's law will solve all your problem's)
let me know if you need more info.
Good luck
Posted on Dec 07, 2008
GE microwave fuse model jes532wn rating 15v but what voltage rating: 120v or 240v ?.thanks
fuses do not have voltage ratings they are a current device. the 15 V does not make sense. It might be 15 A which is the current rating. A standing for Ampere which is the maximum current named after the discoverer of current creating magnetic fields being Andr?-Marie Amp?re in 1826. The 120v or 240v relates to the transformer design in the microwave. The transformer would be design to run on 240V AC 50 HZ AC like in Oz and UK or 120V 60 Hhz AC like used in the USA out of the power point from the power company.
Also the current relates to the voltage. So voltage divided by circuit resistance equals current.denoted by the formula I = V/R
Jan 24, 2015 | GE Microwave Ovens
Need a replacement power supply for a Evernote scanner
Sorry Gregory, gave you the wrong number.
You could try something like this. Various voltages and currents with different adapter plugs. This is on Ebay UK but I would think there are others, don't know where you are.
Ebay item number: 201154296095
1.Rated Input Voltage: AC 110V or AC240V
2.Vibration Input Voltage Range: AC95V-265V
3.Input Rated Current: 0.4-0.6AMP
4.Input Power: 90W
5.Efficiency: >88%(TYP)
6.Out Power: 90W
7.Output voltage: 15V/16V/18V/19V/20V/22V/24V(0/+0.5V NOLOAD): DC15V-24V
8.Output voltage: 15V/16V/18V/19V/20V/22V/24V(-0.4/0.5V@rating load): DC15V-24V
9.Output current: 15-20V/4.5A@22V-24V/4.0A: 4.5AMP(max)
10.Overload protection: YES
11.Short Circuit Protection: YES
Dec 17, 2014 | Office Equipment & Supplies
What is my current rate
Which current are you referring to ??......
If you think of an electrical device as a piece of plumbing, voltage is the amount of water that you send down into the pipe, resistance is the pipe's relative width or narrowness, and current is the speed with which the water flows.
Power measures the water's relative difficulty or ease making its way through the pipe.
You relate all these values to one another using a common set of physics equations known as Ohm's law.
If you need to calculate electricity's current flow, you'll need to have at least two of the three values -- voltage, resistance or power -- listed above.
Calculate current flow using voltage and resistance.
According to Ohm's law, you can express electricity's current in amps as a ratio of its voltage in volts to the resistance of the device it's flowing through in ohms -- I = E/R, respectively.
For example, if you want to know the current flow of 220 V of electricity as it flows through a laptop computer with 80 ohms of resistance, you would simply plug these values into the equation as follows: I = 220/80 = 2.75 amps.
Calculate current flow using power and resistance.
Ohm's law also states that electrical current, "I," is equal to the square root of the power dissipated as it travels through the device divided by that device's resistance.
If a light bulb dissipates 80 watts of power and has a resistance of 55 ohms, you can calculate the electricity's current as follows: I = sqrt(80/55) = sqrt(1.4545) = 1.20 amps.
Calculate current flow using power and voltage.
If you have a space heater which dissipates 420 watts of power when it takes in 120 V of electricity, Ohm's law states you can calculate this electricity's current using the equation "I = P/E." For this example, compute current like so: I =420/120 = 3.5 amps.
Aug 13, 2013 | Computers & Internet
Needs a fuse, what amp?
Consider the power consumption and Voltage of Air conditioner . Why you might ask because you can calculate likely current requirement. Power = Voltage x Current. So Current = Power / Voltage. Eg a 4800 Watt power on say a 240 Volt supply. Current calculation 4800/240 = 20 amps. As a rough guide what fuse rating is the fuse in the fuse box of the house for the AC power point. I would think 15 amp for lighting and between 20 Amp to 30 A for power.
Feb 16, 2013 | Goodman CLQ36AR49 Air Conditioner
Wht kind of current comes out?
The computer's switch mode power supply produces DC (direct current) electricity.
Nov 05, 2012 | Computers & Internet
I want to know voltage rating of power adoptor
On the bottom of your power adapter there is a label printed with the input and output voltage also the output current.
If this adapter is for a laptop, then the label on the bottom of the laptop will show the votage and current requirements for this laptop.
Aug 05, 2010 | Computers & Internet
I have a waterace R4v 1/2 hp, the float goes out every couple of months, the replacement floats are very!
Are you getting the correct rated current float. You might be getting a lower current float. Is is easy to find the current 1 hp is 745 watts, the formula is power = voltage x current so current = power/voltage Example 1/2 hp = 372.5 watts if your pump is working with 120 VAC.
So Current=372.5/120=3.1 Your current is 3.1 amps. I suggest you get a float rated for 10 amps. If this is your case with 1/2 hp and 120 VAC. Hope this helps
Mar 04, 2010 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Line fuse rating?
usually fuses have voltage and current ratings mark on them you just have to look for it or sometimes near the fuse housing.or you can use the formula power consumption of the unit divided by the voltage rating of the unit. I (amp) = Power(watts) divided by Voltage(110V) X power factor(PF). use 0.866 for PF
Feb 02, 2010 | KLH Audio Players & Recorders
I need to know if there is still some were to purchase and Ac Adapter for a Balance LCD Monitor CM2019?????????
All you need to know is:
- The output voltage (usually 12V)
- The rated output current (usually above 5A)
- The plug polarity (usually plus on the inside)
Then just purchase any replacement AC adapter that has the same voltage, same plug polarity and rated current preferrably more (at least 120%) of the original.
That's it.
You can buy them online, for example at
Dec 24, 2009 | Balance CM2019 19" LCD Monitor
55 people viewed this question
