Question about Sharp AL 800 Copier
Toner error message on copy machine
The new toner cartridge I placed in the Sharp AL 800 copier is not working. I am getting a CL message code and I cannot determine why I am getting this message. I've tried manuerving the cartridge and wonder what else I can do.
  • bon_chat Dec 22, 2008
    The error message that comes up is CH. I insert the toner cartridge but the blue plastic strip across the top will not stay locked in place when I shut the front cover. That's when the CH error message comes on. Yes, the rest of the lights on the display panel stay on, just that the CH comes up in place of the number of copies. Thanks!
  • Vladimir Machlis
    Vladimir Machlis May 11, 2010
    1. What's the message?
    2. Is it Toner or Drum cartridge?
    3. Any lights on display panel?
Sharp AL-800 copier quit. On the alarm panel, there is a blinking "roller"?. Anyway, it looks like it could be a roller. Nothing I do will make this alarm go away. What can I try?
Posted on Sep 03, 2010
Sharp AL 800
Error message "L" flashing in the # area.
What is the error message and how do I fix it?
Posted on Jan 31, 2009
    Problem Solver:
  • 7 Answers
Is "CH" steady or flashing? If it's steady, the door is not shut properly.
If it's flashing, the machine doesn't detect the presence of the toner cartridge (defective toner cartridge). Try another toner cartridge (an empty cartridge will do).
To get the blue handle to stay locked sometimes takes fiddling with it when the cartridge is in.
Posted on Dec 23, 2008
My Sharp AL-800 copier only returns blank pages even after I replaced the toner cartridge with a new one.
toner is not the problem remove the photoreceptor and gently clean the inside very well expecialy the two charging unit.
Jul 30, 2010 | Sharp AL 800 Copier
SHARP AL-1622 START BUTTON LIGHT OFF. NEW TONER.
Sounds like not coming to ready....Probably fuser issue. Themistor, lamp, thermofuse.
Apr 06, 2010 | Sharp AL 1631 Copier
Sharp AL-800 light copies
Check the machine for a **** or dust glass above the drum.
Check and clean coronas, the wires and shells may be dirty reducing charge.
Run a few white copies, to check of the toner / carrier ratio is low.
Hope this is of some help.
Ed
May 11, 2009 | Sharp AL 800 Copier
AL 800 falshes "L" - new toner cartridge inserted
Manual can be found here.
http://www.sharpusa.com/files/cop_man_soho_AL800.pdf
Apr 16, 2009 | Sharp AL 800 Copier
Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Nov 05, 2008 | Sharp AL 1631 Copier
Black line on side of copies
You should replace the drum and toner cartridge if you haven't in the 5 years, that should take care of the lines. The only problem is the cartridges can cost more then the machines is worth... Hope that helps
May 30, 2008 | Sharp AL 800 Copier
Sharp Al-800 Skewed Copies
one problem with this machine, a small pin comes out on the paper release handle in the back, which lets on side of the paper lift tray to come up higher than the other. might look in that area. good luck
May 15, 2008 | Sharp AL 800 Copier
Manual for Sharp AL 800 digital copier
hi im jules_09.you need a new toner cartridge for the copier when the toner light comes on it indicate the cartridge is empty.buy a new cartridge there is a instruction on the packaging that will guide you to install it your self
Dec 01, 2007 | Sharp AL 800 Copier
Sharp AL 800 Copier Logo
183 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
