Television i have replaced the hot trans, and flybacktrans........still the same problem
    Genius:
  • 1,239 Answers
HI
the base to emitter of the hot will read short on a diode checker/test on ohms it vairies but typically about 50 ohms.e to c, or b to c should have very high resistance. unsolder the collector of the hot. make sure all solder is gone. now test the ohm between your tuner ground & the pad of the hot collector it should read open.
Posted on Dec 07, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 07, 2008
    Horizontal output transistor usually has a damper diode across C and E and a bias resistor included between E and B. these internal components alter one's expected ohmmeter test of H transistor; here's how. the base to collector junction will test as a diode, but E to B will show a low resistance, approx. 50 ohms in both directions. now the E to C ohmmeter test will test as a diode. the foregoing results indicate a good transistor. readings other than these indicate a bad H output transistor.
    President:
  • 1,952 Answers
What is ur tv model and brand
  • 2 more comments
  • mohammed marika thambi
    mohammed marika thambi Dec 07, 2008
    please make ur doubt and problem in briefly
    it might be a bad flyback. but also something in the drive circuit could
    have made it run hot and killed it. i would replace it and if it does
    fire up then the drive circuit is the problem. if it blows the output
    or just hums for a sec i would go for the flyback
    check if Horizontal Output goes hot. If
    so, check for a ceramic capacitor located near HOT, I think it is .0022 1.5 kv.
    Resistor R-3242 or RX3242 1 ohm or 2.2 ohm opens
    up near lot. IC LA7837/8.
    With the set turned off use the remote to enter
    Display, 5, volume up, power. Then be CAREFULL.
    Face the rear of the set and describe the layout
    of the circuit board/boards. One large board/two boards/three boards, location of
    the high voltage transformer/ right/left/center etc. Are boards horz or
    vertical? Look for dates on the components/picture tube/inside the cabinet.
    Sometimes there is a sticker inside the cabinet, giving the circuit board pt
    numbers. With this description, someone will recognize the set and be able to help.
2004,Mazda 6,4cyl,battery gets really hot,and now automatic transmission will not shift stays in 3rd, replaced battery, and is still doing same thing
SOUNDS LIKE ONE PROBLEM CAUSING 2.BRAKE FEEL MUSHY? FROZEN CALIPERS HOLDING BACK TRANS-RACING MOTOR CAUSING OVERHEATING BATTERY? OR.... BAD TRANS CAUSES RACING MOTOR TO OVERHEAT BATTERY.? SOUNDS LIKE 1-(CAUSE) SLIPPING TRANS , RACING ENGINE,,BATT OVERHEATS ETC........DEPENDS ON WHICH STARTS FIRST-TRANS ISSUE, 2 ENGINE RACING, 3 HOT BATTERY? THAT EQUALS A PUZZLE READY TO BE SOLVED. IF YOUR BRAKE SYSTEM WHERE IN GOOD SHAPE (EMERG BK TOO) I WOULD LEAN TOWARD THE TRANS FROM HERE. GOOD LUCK, FRANK M (PS, DONT KEEP CHANGING YOUR BATT BECAUSE OF THIS,THE ALTERNATOR IS OVERCHARGING THE BATT DUE TO THE RACING OF THE ENGINE DUE TO EVERYTHING ELSE. GO FOR THE CORE!
Feb 14, 2016 | Cars & Trucks
E250 transmission just had my tran rebilt when it gets hot it is slow off the line they say it's not the tran but it work great be for they changed it what do you think
It could be a bad tourqe converter. If it wasn't drained it still has metal shavings and old fluid in it. I would recomend draining it and replacing the fluid/filter.
Jun 17, 2013 | Cars & Trucks
AUTOMATIC TRANSMISSION SKIPS ALSO FLUID GETS HOT AND I LOOSE 3rd&o-d
sorry but your trans has went out. 3rd and over drive are on same shaft with different control solenoids once fluid gets hot not enough pressure for gears to engage internal wear and tear of system . have trans rebuilt or rebuilt unit installed or good used trans. jaspers used trans are warranted you can find them on line.
Jul 15, 2012 | 2000 GMC New Sierra 1500
Im working on a RCA ITC222-it has 3 chirp problem with burnt CL031. Unfortunately RL106 is burnt (I need value)and, FL100 is open (I need current rating)and finally, DL032 and DL033 are shorted (I need...
Cl031 is the sfaety retrace capacitor check DL030 an the HOT trans they are most likley blown as well. Usually if anything other than the Hot and DL030 are blown the entire deflection board will need replacement. Its also best to check all three of the CRT necks to be sure none are cracked and broken on the CRT necks . Unfortunately several designs of the deflection components had different parts although the deflection boards will usually interchnage bewteen the ITC222 chassis sets. The ITC222A will not interchange. www.tvrepairworld.com has replacement parts and boards and can also assist with part numbers that you require.
Oct 14, 2011 | RCA HD52W59 HDTV Projection Television
Show picture of flyback transformer and out put transistor
Heres a picture of the flyback. The trans HOT is located just ahead and to the right of the flyback its attached to an aluminum heat sink,slinteriors_16.jpgslinteriors_17.jpg
Jul 24, 2011 | RCA P61960 61" Rear Projection Television
My car will not reverse but it will go forward
Sounds like a typical reverse band problem...cover the easy things first however... is the fluid full??? check it engine hot in park....is the fluid burnt??? bad smell not red like out of the can... if its low or if its burnt make sure you purchase the proper fluid for your particular vehicle some trans fliuds dont mix...a trans service may fix it as the trans has a filter that (may) be clogged but usually this causes a non shift in drive as well as reverse...if all else fails sounds like a trans repair/replacement is in the horizons.Cost factors: Trans fluids $3.00 qt.: trans service $30.00-$100.00: Trans repair/replacement $600.00-$1500.00.
May 06, 2010 | 1999 Saturn SL
RCA F32450, low freq. chirp while plugging it in.
Yes the decopling cap
there flat round and bright blue /gray/black
near the Hoz out trans, they should read
10+ meg ohms out off cricut if good
if lower replace them.
Jun 30, 2009 | RCA F32450 32" TV
2004 dodge ram is over heating, the thermostat and fan clutch have been replaced.Doesn't(over heat) in cool weather,but will in mod. weather if driven over 70mph or hilly terrain due or increase of rpm,and...
Water pumps can stall out, but do you have air trapped in system.
Had you recently had the system "open" to replace hose, thermostat, temp sensor. Some Ford and GM have a bleeder screw on a high point in cooling system to bleed out trapped air.
Check your trans fluid color. Since the trans cooler is built into radiator (automatics)
IF the engine is overheating the trans CAN overheat
IF the trans is overheating the engine CAN overheat
They share the same cooling source and trans fluid gets hotter than oil, but yet it has a wimpy cooler built into radiator. Maybe add trans oil cooler to system.
Also outside temp affects the cool down rate of the radiator, ie...hot air trying to cool down hot radiator/engine is less effecting than cool air cooling hot radiator/engine
Aug 06, 2008 | Dodge Pickup Cars & Trucks
Hot overheats
If this is your hori out put it means you have a bad flyback transfomer.
Jan 19, 2008 | LG RU-27FB30C TV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
