Question about Panasonic NN-P794SF Microwave Oven
Panasonic NN-ST666W Microwave oven
The door fails to spring open when you depress the OPEN DOOR button/lever. When the button is depressed, you can open the door but it seems like the mechanism is not pushing it open like it used to. Description of required parts or parts list would be great assistance before I disassemble oven.
  • Anonymous Jan 26, 2009
    must slam the door shut for the microwave to run.
  • Anonymous May 19, 2009
    door button wont spring out
  • Panasonic Master
  • 9,098 Answers
What usually breaks is the door open lever, but it may be that the rear of the door open button and the face of the door open lever are worn to the point where they will not actuate.
On a counter top model, the outer cover will need to be removed to diagnose and repair this.
On an over-the-range model, only the control panel needs to be
removed in most cases.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can find Panasonic parts in Australia here.
Posted on Dec 07, 2008
How to fix the door button on panasonic microwave t6648fx?
Clean the inside edge of the door and oven where it contacts the door. Grease or oil is preventing the door to swing open.
Aug 28, 2014 | Panasonic Microwave Ovens
Door does not open
You'll need to remove the outer cover to get to the door open button or door lever, either of which can cause this problem.
The service manual is here.
You can order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
Jan 15, 2013 | Panasonic NN-P295SF Microwave Oven
Panasonic NN-SN789S
Hello, I don't know if it is helpful, but here is the manual - Panasonic Nn Sn789 Users Guide
Aug 20, 2012 | Microwave Ovens
Over the range microwave oven
The problem is the release spring is broken or the button is sticking, pick up a small can of electronic cleaner attach straw and spray into the button crevis to break down the crud, grime, and dirt this should help release the mechanism.
Apr 23, 2012 | Panasonic NNH965BF Microwave Oven
Have a Panasonic Microwave Mod. # NN-P294BF. The Door opener (push button type) became detatched from the door latch. It is mounted over the stove. Do I have to take it down to be able to take the...
Here you can find what you need for a very similar model
Yes, to take down the face you must have the unit fully accessible - the bolts are accessible only from the rear.
Apr 13, 2011 | Panasonic NN-P295SF Microwave Oven
Our panasonic inverter microwave (3 years old) needs repeated hard slams to shut the door so that the light goes off and the microwave will work. How do we fix this problem as I'm afraid we are going to...
We have a Panasonic Inverter microwave. Door became difficult to close and had to slam it hard while holding themicrowave to keep it from moving. When opening the door did not pop open but did unlatch. I ordered a new door lever from Panasonic. When got part I removed case from microwave and lever was okay. I then removed the perimeter strip on the inside of the door. With a screwdriver I stretched the spring at the bottom that keeps the door latches pulled downward. Spring still worked just not as stiff. Put perimeter piece back on the door and replaced housing (which I didn't need to remove in the first place), and then put a small drop of vegetable oil on the cams where the door latches hit when closing door. Viola, door opens and closed as new. Problem solved. Diagnosis: over time the latch tension spring hardens and gets too stiff. P.S.: I had several similar springs as backup in case I screwed up the original one.
Jan 16, 2011 | Panasonic NN-SN657SMicrowave Oven
Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Jan 19, 2010 | Panasonic Microwave Ovens
The door won't latch closed and the door release button pushes all the way in
I have the NN-T994 SFR model and it had a switch that was staying depressed. I removed the screws to (in my case) the stainless steel cabinet, removed the cabinet and unhooked the wires to lay it aside. Found that the switch was cracked or broken, glued it back exactly as it was, then put the cabinet back on and it fixed it! Now about a year later, I have another problem...oh well. Hope this works on yours.
Sep 28, 2009 | Panasonic NN-T990SA Microwave Oven
Can't open microwave door
It sounds like the push to open lever is cracked or broken. You have to remove the 'wrapper' to open the door manually from the inside to check the 'door keys' or door hooks to make sure that they are in tact. Then, check the door opening lever between the 'push to open button' and the lower door key.
Sep 11, 2009 | Microwave Ovens
Panasonic NN-P794SF Microwave Oven Logo
704 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
