Question about Refrigerators
Fridge not cooling
Fridge was in garage working perfect. We moved it inside, did not lay down at all, fridge remained upright, only had to move it about 8ft. Now that it's inside the freezer works perfect, but the fresh food side isn't getting cool. It was unplugged when we moved it for approx. 10 min at the most and like i said never layed on side or nothing. Now it's not cooling!!! Please help.... Looked at fan and nothing is bent or rubbing, coils underneath are not hot or warm at all. Model # 106.56542400
    Scholar:
  • 82 Answers
Hello.
The first thing you need to do is take out the bottom drawer in the freezer and look into the slots in the back panel. Make sure that you can see silver coils, and not a bunch of frost. If there is, then you need a new defrost timer, defrost heater, or defrost terminator.
If all looks ok then make sure the fan in the freezer is running. (You may have to push the door switch if yours has one.) If the freezer fan isn’t blowing however, the freezer will be warm at the top and cool at the bottom, and you fresh food compartment will be warm.
Another thing to make sure is that the light it turning off when the door is closed. Again you would have to push on the door switch. I was amazed to learn when I first started this line of work, that even a little light bulb can make enough heat to cause a problem.
These are the most common issues.
Let me know if everything looks ok and I will go over some other things, as the list of things that can go wrong with a refrigerator is fairly long.
Posted on Dec 09, 2008
Samsung RF265AARS 6 years old been sitting unplugged 5 years wont start
Remote chance fridge is on defrost cycle but more likely the compressor has seized.
Have it check by a qualified tech.
It's usually cheaper to buy another fridge than to have the compressor replaced and new refrigerant installed.
Nov 02, 2017 | Samsung Refrigerators
Tip
Moving a fridge or laying it down.
Moving a GE, Hotpoint or some Kenmore refrigerators can be more of a job than you dreamed.
Did you know that the defrost heater of some of these models are made of glass and wire? They really are! Glass and wire!
A little bit of a rough ride or a bump can break it. So if you move a fridge and 2 weeks later it does'nt work you probably have broke the defrost heater.
Thats not all! Surprise surprise here is the big news. YOU CAN LAY A FRIDGE DOWN TO MOVE IT. Who would have guessed right? How many times have you heard that myth. Plenty I am sure. But its true you can.
Here is what to do. After you are finished with the move and the fridge is in the upright position,,,leave it up for about 6 hours before plugging it in which will allow enough time for the oil to flow back to the compressor so it starts pumping freon while the tubes are clear and you will be good to go.
Thats it,,,,I am sure this will help someone.
on May 27, 2010 | Refrigerators
I am moving and need to lay the fridge on its side, but have been told you cannot do so, is this correct?
You do not want to lay that refrigerator on its side because the refrigerant will leave the compressor and fill the system with liquid refrigerant where it should only be existing in a gaseous state, and if the refrigerator is tilted far enough over or lay-ed onto its side then the refrigerator will have to stand up-right and un-plugged for at least 24 hours before the liquid refrigerant will settle back down where it belongs, and then the refrigerator should actually function again if there was no other damage caused when moving the unit.
Sep 21, 2010 | Sanyo SR-3660S Compact Refrigerator
I moved a perfectly working KitchenAid fridge from inside the house to the garage and now it blows the ground fault breaker the second it is plugged in.
Almost definately, there is a wire or more accidently pulled loose while carrying the fridge.Check where the cable enters the fridge and the surrounding area.
Jul 19, 2010 | KitchenAid Refrigerators
My fridge quit cooling when i moved it to my new house
Did you lay it down? if so trun it off and leave it for 24 hours(minimum) try again, if still no good you will need a professional to fix it.
Apr 17, 2010 | Whirlpool ED5VHGXM Side by Side...
Moving a Eurocave wine cooler laying flat
the reason you should not lay a fridge/freezer on its side is that you will get air bubbles in the cooling pipes,which you may not be able to get rid of when you turn it back upright.I have moved loads of f/f, in the past and have had no problems,as long as you give the unit at least 24 hours to right itself.....and keep the door(s) closed while it is "resting"
Apr 17, 2010 | EuroCave Comfort 260 Collector's Package...
Moved fridg to new house pluged it in dosen,t get coled at all!!!
If you had to lay the fridge down to move it? Then you have to let it stand upright for at least 24 hours before you can plug it in and use it or it won't cool, as oil will get into the coolant lines and foul the works.
If you didn't have to lay it down, then check for a switch and or harness under the front grill that may have got bumped out of adjustment of knocked the plug off.
I hope this helps you, and good luck.
Sep 16, 2009 | Maytag MBB2256GES Bottom Freezer...
I just moved my dads fridge to my house and after about 7 hours I smelled a burnt plastic smell. I smell it on and off.The fridge is still cooling.When i moved it I layed it down.
When a fridge is layed down the oil in the compressor will flow into the refridgerant lines and will have to be stood upright until the oil can return the the comrpessor. It may be too late for yours but I would try cutting it off for a day before trying it again. This may not be the cause of the smell so keep a nose on that and try to locate exactly where it's coming from.
Aug 21, 2009 | Whirlpool GC5SHEXN Side by Side...
Fridge not cooling
Hello.
The most common thing that happens while moving a frig is when moving it they put the dolly underneath the condenser fan housing and bend it into the fan causing the compressor to overheat before it has a chance to cool down everything. If this isn't the case then I will send you a list of things to check out. Let me know.
Dec 07, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Moved The Fridge, Not cooling
Check the evaporator fan inside the freezer compartment.
Dec 23, 2007 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
121 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
