Question about Casio WK110 Portable Keyboard
Looking for the "sustain" feature
Regular pianos have a sustain pedal. Does the WK-110 have a sustain mode I can set?
  • cindy_skinne Dec 07, 2008
    I know, but the store where I bought the unit doesn't carry the pedal...I'd have to order it and of course I need to use the keyboard TODAY! :-))
There no setting for this but i baught a sustain Pedal from RadioShack and it's already a plug in the keyboard and it costs only about 7.25 US$
Posted on Dec 28, 2008
    Sergeant:
  • 236 Answers
I don't think there is a setting for this directly, but there is an optional sustain pedal you can plug into it.
Posted on Dec 07, 2008
Are the currently manufactured Roland Home Piano series pedal assemblies compatible with the Roland HP237?
This wish an after market pedal, or the original 3's connector? If the keyboard is on when you plug and unplug that, it is likely due to a voltage reference getting confused. Usually when you get constant sustain then most likely a switch is stuck closed, or open, down there in the pedal. How these things work normally is that a pliable switch is opened, for sustain, or closed. It depends on the keyboard. Some keyboards have a setting inside them to accommodate both types of pedals, and some pedals have a switch to choose either. Your keyboard does not have a setting that I can tell, other than adjustments for a resonance option (nice feature). I am not sure the newer RPU-3 pedal is compatible, it seems to be for the newer models. If you are handy with a volt meter, then can check the cable's pins for a common, then a pin that changes with each pedal (use continuity mode, beeps when circuit is closed). Could be a piece of dust is in there, or hair or carpet stuff, and a good cleaning would fix that from blocking the normal function. Manual Link: http://media.rolandus.com/manuals/HP-237_OM.pdf
Aug 02, 2014 | Roland Hp337 Digital Piano
Casio Privia 410r Piano soft pedal problem
The Casio Privia 410r has two pedal jacks at the back. One is the sustain pedal, the other is the soft/sus jack. Please use the other jack if you want to use sustain pedal. Only 1 of the 2 jacks can be used.
However, if you have the optional sp30a pedal which plugs UNDER the piano instead, then only can you have 3 different piano pedals.
May 18, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
Fc4 sustain pedal is in "sustain" mode at all times -- it won't release the sustained notes. I tried plugging the pedal in (to a roland ep-9) before powering up and had the same problem.
Sorry, but the Yamaha pedal has the opposite sense (it is a normally open contact) than what is REQUIRED by Roland equipment. Roland requires a Normally Closed contact. Unfortunately, one is confused because the Roland jack for the sustain shorts itself to no sustain when you unplug a pedal. SOMETIMES one can open a pedal and with soldering iron change a wire to reverse the pedal sense IF the particular pedal has both contacts available.
Jun 16, 2011 | Yamaha FC4 Piano Style Sustain Pedal
The sustain pedal is permanently on!
You MAY be trying to use a Roland pedal on an instrument that requires a different one.
The Roland have a normally closed contact where MOST others are normally open.
If you are using Roland equipment, then use of another brand OR a broken cable will cause this as will a shorted cable with other brands.
It looks like you MIGHT have a Technics given that number you posted. Not sure of which polarity pedal you require with that, So you need to test it.
Plug in a regular instrument cable and see if it sustains with nothing at other end. If it does, you need a normally closed one.
Jul 05, 2010 | Music
Needs USB-MIDI Driver For WK 110 Piano for Windows 7(64 Bit)
Here is tie official site for the driver ... http://driverwhiz.com/drivers-en?brand=Casio&logo=Casio&subid=1001-us-en-10000000394&gclid=COT9m4uGhKACFdx05QodUT3Zkw
Evidently Casio has not written drivers for Windows 7/64 if I understand your comment. I am not that familiar with 7 but I do know in past versions, Windows has offered "compatability mode" so older devices might work with newer operating systems. Have you explored this possibility?
Here are the options I see:
Look for compatability mode on your new computer.
Ask Casio for a driver.
(I'm not a big fan of third party drivers - maybe you are - you can look for a third party driver)
Continue to operate your WK 110 using a 32 bit computer.
Thanks for your interest in FixYa.com
Feb 21, 2010 | Casio WK110 Portable Keyboard
What type of sustain pedal Roland EP-90 digital piano is using - open or closed at rest?
CLOSED is typical for Roland pianos when at rest. (open to sustain).
Note that the jack PROBABLY has a grounding contact so when no pedal is used/plugged in, the jack is shorted at the piano.
Sep 19, 2009 | Music
Casio WK110 Portable Keyboard Logo
286 people viewed this question
Top Casio Computers & Internet Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
