Dell dimension4550 when turn on all i get is a screen that says that there is no primary hard drive
  • howhud2000 Dec 07, 2008
    does not show in bios and have tryed other HDD also
    yes I have checked all the above and suspected a issue with the MB. You guys have confirmed it. Thank you for your quick responses.
    Novelist:
  • 183 Answers
Open your computer an reseat the Hard drive connecting cables on the Mother board.
then Check in BIOS if it shows the Hard drive there
Posted on Dec 07, 2008
  • Inderpal Singh
    Inderpal Singh Dec 07, 2008
    have u tried changing the HDD cable.
    have u tried changing the slots for connector.
    if u have already tried that it seems to be an issue with Motherboard slot.
SATA Primary hard disk drive failure
Sounds like your hard drive has failed and will need to be replaced. You will need to make sure you have all the recovery cd/dvds Dell sent with the system; or you created when you got the system. The new hard drive will be completely blank, so you will have to install the OS, drivers, and other software from these CD/DVDs.
Hope this helps
Apr 25, 2012 | Dell Dimension XPS 400 PC Desktop
Dell: Primary hard drive 0 not found Primary
Sorry, but this isn't a good sign. Drive 0 is most likely your main hard drive, and only if you have a second one would you computer ever find anything on Drive 1.
I would check the connections inside from the motherboard to the hard drive, as well as from the power supply to the hard drive.
Here's the manual: http://support.dell.com/support/edocs/systems/opgx60/en/ug/sffabout.htm#1103481
Also, if you boot your computer to the Dell copy of Windows, go through the motions of reinstalling Windows and you probably won't be able to detect any drive to install it on.
You'll most likely need to replace the hard drive altogether. Sorry!
Hope this was helpful for you (even though it was bad news)! If so, please give a rating!
Mar 09, 2010 | Dell Optiplex GX60 PC Desktop
Primary disk drive not found
Check the connection of your hard drive and make sure it's plugged properly On The Motherboard.
Is this a SATA drive? Has it ever operated properly? If worse comes to worse, you'll have to reload windows from scratch.
Nov 11, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Primary hard disc drive 0 not found
replace your hard drive, its toast !!!
then reinstall OS or run the repair/restore disc.
if you did not get one contact dell.
Oct 21, 2009 | Dell Latitude D600 Notebook
Dell optiplex gx110 device detection problem
I'm guessing that the computer is not booting at all. This is saying that it cannot find any hard drive to talk to. Drives are labeled in the computer code with numbers starting at 0. There are up to 2 drives on an IDE ribbon cable, the Primary, and the "slave" or secondary. So, possibilities are that your hard drive died, the power connector to it came loose, or the power supply itself is having an issue with that connection that is attached to the hard drive.
Jun 11, 2009 | Dell OPTIPLEX GX110/200 PIII-866MHz 256MB...
Dell dimension 2400 diskette drive 0 seek failure
Check your BIOS setting to see if it detects the hard drive (Primary disk 0). If it can't detect the hard drive then the hard drive maybe faulty. Open the case unpluge the IDE cable from the hard drive and reconnect it again, also unplug the IDE cable at the motherboard and reconnect it again including the power connector on the hard drive.
There maybe an option to test the hard drive in the BIOS, if so use it to test the hard drive.
If the hard drive is faulty, you need to replace it and install Windows, the various device drivers and your programs to get a functioning computer again.
You might consider buying a new computer (it will be faster & better than the old Dell) and you have your new monitor to go with it.
May 21, 2009 | Dell Dimension 2400 PC Desktop
BIOS screen says no primary hard disk, then "no bootable device available", now I have blue STOP screen with instructions
the hard drive may be bad. try re-partitioning the drive. if that doesn't work the hard drive will need to be replaced. if you still have warranty dell will replace it for you for free. www.dell.com/support. if you do not have warranty you will need to buy a new one for your computer. best buy sells them cheap. thank you for using fixya
May 01, 2009 | Dell Latitude C600 Notebook
Dell Dimension 8250
Yes you need a new hard drive
Dec 09, 2008 | Dell Dimension 8200 PC Desktop
Primary Drive 0 is not found when I boot my computer
First things first use teh arrow keys for left and right to select auto for the primary drive. If when you reboot and the drive is not seen then double check if the hard drive is set to master you can see the jumper settings and how they should be set on the top of the drive itself. Then check the power if the drive feels like its vibrating then its ok. After that turn on the computer. If after that the drive is still not detected then you might have to consider that the drive is defective and i would suggest you try another drive and see if it is detected.
Kindly reply back for additional questions.
Nov 19, 2008 | Quantum Fireball Plus AS (QMP30000AS-A) 30...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
