Question about Mitsubishi VS-50705 50" Rear Projection Television
Mitsubishi projection tv display does not turn on
Hi, I connected internet cable (was just experimenting whether internet cable will get tv channel signal or not) to the antenna port of my mitsubishi 50" projection tv and tv's display turned off after 5 seconds and it is not getting turned on. Is it because of the internet signal short circuited one of the circuits in the tv? Could you please help me solve this issue? I appreciate your help.
  • vishnu_manth Dec 07, 2008
    It was NOT an ethernet cable. It was a cox cable which is connected to cox internet/phone modem which looks same as the usual antenna cable. The model number of the TV is VS-5059. I appreciate your response.
    Thanks,
    Vishnu
  • thielectronick
    thielectronick May 11, 2010
    what internet signal did you hook up? an ethernet cable to the tv?
    Problem Solver:
  • 7 Answers
Unplug your tv for an hour and let it reset the cable didnot hurt your tv if that doesn't work check the tv's bulbs
Posted on Apr 28, 2009
2 Suggested Answers
Service Dude
  • 201 Answers
SOURCE: Hi, I connected internet cable
LOL!!!!!!!!, your tuner is now faulty and maybe your Microprocessor as well, you will have to take it to a repairer this something you wont be able to solve sorry ......
Posted on Dec 07, 2008
Sound won't work
If your TV has a picture but no sound, start by checking the obvious such as whether the mute button is on or whether the volume has been turned all the way down.
Next check your cable connections and make sure everything is plugged in tightly.
Change channels to make sure that it's not a technical difficulty with your TV service provider or TV station. Call your service provider to see if they're experiencing issues with their audio.
Try reconnecting the HDMI cable after you turn off the TV.
Make sure your remote is on the correct input, and see if you have sound while playing a DVD or video game.
For a simple troubleshooting checklist, see No sound on TV and get more details on some simple fixes for this problem. I hope this helps!
Sep 13, 2012 | Mitsubishi WD-73735 Television
I got a Mitsubishi ws-55411 from a friend and I am trying to set up the cable. this is my first HD TV. The cable comes from a wall outlet (no cable box). I followed the manual and attached the cable into...
Go to the customer menu and switch the set from air-antenna to cable.
The set is in the air band and not the cable band hence only channels 2-13.
Let me know if you need help.
SD TECH
Apr 11, 2011 | Mitsubishi WS-55411 55" Rear Projection...
The mitsubishi model vs-60805 tv will provide air channels off of cable hook-up, but does not provide cable channels. What needs to be done to recieve cable channels? The menu does not provide an apparent...
Mitsubishi VS-60805 is 1999 model tv and unable to receive digital cable channels because it is equipped with analog tuner that can not receive cable channels because it is almost 11 years old.
You need to hook Cable Box in AV input of tv, plug digital cable in cable box and get digital cable channels in tv. Cable box has its own remote control and inbuilt digital tuner to receive all digital cable channels and widely available in Store, Radio Shake, amazon.com etc.
Let me know if you have additional question.
Thanks.
Aug 07, 2010 | Mitsubishi Televison & Video
Can only get channels 1-13 on mitsubishi ws-48313 tv
Hi,try to see in tv menu setup and set to cable then use autoprograming channel
and you should be done ...
hope that help
Mar 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi TV having issues with HD channels
Unplug for a few then try it again you need to search channels again
Jan 27, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-55809 Upconvert Stopped working
your problem is the 2hdw board is located in the signal board.
Feb 02, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Slow Channel Changing
The question really is whether or not the set has always had this problem. If not, then we need to look at a possible problem with either the power supply or the tuner. Can you update this and indicate whether or not this is a new problem?
As far as using an external device (cable box or Tivo), if the tuning is done with either type of external box, then the TV would be on a fixed channel so yes, the problem woud go away.
Dan
Jan 12, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Hi, I connected internet cable (was just experimenting whether cox internet cable will get tv channel signal or not) to the antenna port of my mitsubishi 50" projection tv and tv's display turned off after...
Dec 07, 2008 | Mitsubishi VS-50705 50" Rear Projection...
No audio or video
If you can see the channel number as well as the volume setting when you press on the appropriate buttons on the remote, then it would seem that what happened is that your TV went into muting (video and audio). This can only be brought about if the TV is not receiving any signal from your cable or aerial. This is a built-in feature. Another possibility is that the tuner section of the TV has some issues. To determine whether cable or tuner, pls try installing a known operational VCR and play a good tape. Connect the RF OUT of the VCR to the CABLE/ANT IN of the TV. Select channel 3 or 4 and should you be able to watch the tap video, then you have just confirmed that it is your cable (or aerial). If on the other hand there is likewise no display on either 3 or 4, then you have just confirmed that somethings needs to be done internally in the tuner section.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Mitsubishi VS-50705 50" Rear Projection Television Logo
138 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
