Question about Mitsubishi VS-50705 50" Rear Projection Television
Hi, I connected internet cable (was just experimenting whether cox internet cable will get tv channel signal or not) to the antenna port of my mitsubishi 50" projection tv and tv's display turned off after 5 seconds and it is not getting turn on. Is it because of the internet signal short circuited one of the circuits in the tv? Could you please help me solve this issue? I appreciate your help.
  • vishnu_manth Dec 07, 2008
    Hi, Thanks for your response. Would you be able to tell me the approximate estimate if I need to get the tuner/microprocessor replaced?
    Sergeant:
    Champion:
  • 201 Answers
LOL!!!!!!!!, your tuner is now faulty and maybe your Microprocessor as well, you will have to take it to a repairer this something you wont be able to solve sorry ......
Posted on Dec 07, 2008
  • Jonathan Van Rensburg
    Jonathan Van Rensburg Dec 07, 2008
    you will look abour R480.00 Im not sure what the guys charge im in South Africa
How to program channels
go into settings and then rescan for channels
May 07, 2015 | Televison & Video
Wont receive digital channels after scan non found
Hi Patrick,
You must have a UHF / VHF antenna connected to the antenna input of the TV to scan for digital channels. Most new TV's have a threaded, round 75 ohm coax cable connection for this - but yours might even have connection consisting of 2 small screws to connect a 300 ohm twin lead antenna cable instead. Use which ever yours has.
If you are using this input for the input of a cable TV "set top box" (STB), satellite STB, or similar, you will likely only find a single analog channel (Ch3 or Ch4) after a scan as the scan will only find the output of the STB - which is usually on Ch3 or Ch4 - and not be able to scan the STB channels.
Additionally, the antenna input of the TV will only provide a standard definition picture if connected via coax cable from the STB. It will only provide a high definition picture if connected to a UHF / VHF antenna and a broadcaster is close enough for its signal to be received by the antenna. The way to obtain the best possible picture (high definition) when using an STB for tuning channels is to use an HDMI cable between the STB and TV. An HDMI cable will provide the very best picture and audio signals from the STB to the TV; all over a single cable and is the recommended practice.
I hope this helps!
Dec 26, 2014 | Televison & Video
Unable to tune into any channels
It's much more likely to be the antenna. How old is the TV? Check whether the antenna connection is loose. Check whether the antenna cabling is all connected. Did anything change just before the TV stopped working, like someone doing work outside? If you're receiving cable TV check the connections to and from the cable box.
Nov 16, 2013 | GPS
I have a Sanyo DP32648 that keeps losing only one channel in the program. When the TV is turned off, that channel disappears from the program. I have to manually reboot the entire list. How can I solve...
It sounds like there is some electrical noise interference that would not be "fixable". If though, we reconfigure the way that they are connected together, we may be able to avoid the noise.
Instead of allowing the antenna signal to "pass through" the 625 we will skip it.
After following the directions, switching between satellite and antenna will be done by selecting on the SANYO "Input 1" for satellite, and selecting "Ant" for antenna. K?
Try this:
From the 625 Tuner 1- using RCA cables (a.k.a. composite cables, or red, white, yellow cable), connect to "Input 1" on the Sanyo TV. To see composite cables go to http://www.wowvision.tv/settingsandconnections.htm
Next, remove the coaxial cable between the Sat box and TV. (Sanyo "Ant. In" port and 625 "Out to TV" port) Set that cable aside.
Now, remove the incoming antenna cable from the 625 "Ant. In" port, and connect it to the Sanyo's "Antenna In" port.
Finally, scan for channels and check for the presence of CBS.
Once verified, test the TV by turning off and on.
Turn on the satellite receiver and switch Sanyo to "Input 1" to verify sat picture.
I believe this solution will satisfy your needs. Please let me know if it doesn't work, and I will need to talk to you about signal strengths, again.
God bless,
Highdefjeff
Jun 13, 2010 | Sanyo DP32648 32 in. LCD TV
Sudden no signal on digital channels on a Vizio VX37L
Your cable signals are probably encoded so that you have to use their cable box for reception. Renders your tv tuner useless used for OTA.
Aug 28, 2017 | Vizio VX37L Television
Cant maintain internet conntection simutaneously on my 3 devices
what is happening is ur voice frequency is bleeding in to the ur digital frequency
what u have to do is change channels of frequency on ur router
type 192.168.0.1 or 192.168.1.1 for most routers
in address bar and that should take u in to the interphase of router then go to wireless settings and change the channel that ur running on
rate my service pleas , July
Apr 10, 2009 | Computers & Internet
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
HDLCDVD2600
The HDLCDVD260 is digital. Change the signal type, in the menu, from CABLE to AIR, then run the automatic search to program in your channels.
Feb 23, 2009 | Sansui HDLCDVD260 26 in. LCD Television
Mitsubishi projection tv display does not turn on
unplug your tv for an hour and let it reset the cable didnot hurt your tv if that doesn't work check the tv's bulbs
Dec 07, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Can't Get A Radio Signal When I Connect A Cox Cable
Hi...
Some cable companies dont put the FM band on cable and some others put an FM trap (which kills the FM band) in line with the cable.
One of those is your problem.
You'll need to buy a FM antenna
Jul 25, 2008 | Sony STR-DE597 Receiver
Mitsubishi VS-50705 50" Rear Projection Television Logo
90 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
