Question about Bose 3 2 1 GSX System
Feedback on speakers when I plug them into computer
I don't know if feedback is the word, but it sounds like when a guitar player makes that terrible noise on stage by accident when I plug in my Bose companion 2's into my computer. You know that sceaming noise.
  • kswift Dec 07, 2008
    Sorry, I need more information. I'm not even sure what you are talking about? Thanks
  • Anonymous Mar 23, 2014
    Bose acoustic 10 speakers aren't working sound is distorted just noise no words
    Scholar:
  • 55 Answers
Is there a microphone also plugged into or built in to your computer, and is it enabled? If so, be sure to turn it off ..
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
Posted on Mar 06, 2010
    Genius:
  • 1,199 Answers
WRONG INPUT?
Posted on Dec 07, 2008
I cant get sound from my tv thru my ht-r380 reciever
This is most likely a connection or switch problem:
  • Make sure you are plugged into the appropriate sound out jacks on the TV
  • Make sure you are plugged in to the appropriate sound in jacks on the receiver
  • Make sure the source for the receiver is set correctly
  • ensure volume is set appropriately
  • ensure correct speakers are selected.
If you are playing a DVD, the input to the receiver should come from the DVD player
Jan 10, 2015 | Onkyo Audio Players & Recorders
The right side cord once plugged into a speaker does not produce any sound. I tried plugging the left side of the chord into both speakers and i do get sound from both speakers. Can this be fixed or do I...
From your description, it sounds like there is a break in the wire. If you can find where the break is by wiggling the cable, it can probably be repaired. Be sure to have the volume turned on low, however, so you don't damage the amplifier.
Many speaker systems use RCA style connectors (shown in the attachment). If it uses these, you can buy them at a local Radio Shack store (or online). You will also need some speaker wire (20 gage or 18 gage is best).
If you are able to do electronic soldering, you can make a replacement cord yourself. If not, and you know someone who can do it for you, it is an easy job.
That would be the most economical solution to fix your problem. If this doesn't work for you, you'll have to find out what kind of connectors are used on the cable and do an online search.
Jul 13, 2011 | Bose 3·2·1 II System
Have been trying to connect speakers to my samsung AV-R720 receiver but I am getting a terrible buzzing sound and only the center speaker is playing. I have lost the manual and would like to know about...
http://www.retrevo.com/support/Samsung-HT-AS720-Home-Theater-Systems-manual/id/6333ci454/t/2/
Page 10 discusses speaker connection.
Disconnect everything but the speakers and evaluate the buzz. It may be coming from external hardware or loosely connected analog cables.
Sometime juts rotating the ac plug on one device eliminates the ground loop buzz.
Feb 07, 2011 | Samsung HT-AS720ST Theater System
How can I connect my Panasonic SA-HT540 to my PC in order to get the full 5.1 surround sound out? I currently have an auxilery lead running into the 'Front Speaker Out' on the back of my PC from my...
If your sound card supports 5.1 and your Panasonic supports 6 channel input then you should be able to do this with extra cables and changing some settings on your computer. Your sound card should have three "headphone" plugs on it. The cable you are currently using for front speakers is likely a 3.5mm to RCA cable. You will need two more of these. With these you will have your 6 channels, or, 5.1. All you do then is tell the sound card driver that this is how you want it to output and it will tell you which cable to hook where.
Otherwise, you have have a single coaxial digital out on your sound card and this is probably best.
Which you use should depend on which component has a higher quality DAC.
Jan 14, 2010 | Panasonic Home Theater System System
Yamaha Mg12-4fx 12-Channel Mixer
ok look here on page 21 & 22 of 32 http://www2.yamaha.co.jp/manual/pdf/pa/english/mixers/mg12_4fxe.pdf
section #5," ST output"
the "st out" will go to the amp you have for the mixed sounds
section #1, "line or mic input"
this is the input for the guitar or a mic , but only one(mic or line ) per input # at a time
Mar 31, 2009 | Yamaha Mg12-4fx 12-Channel Mixer with...
I have a Yahmaha MG12/4 mixer or whatever and a speaker
heres a link to the manual for your mixer (big file)
http://www2.yamaha.co.jp/manual/pdf/pa/english/mixers/MG16_4E.pdf
to connect a guitar to a mixer you really should have DI box (direct injection) its matches the imbalances between the mixer and guitar for proper operation. If you have a guitar pedal this usually works as well. but if you just want to make it work plug the guitar into a channel input NOT INSERT. hope that helps
Mar 29, 2009 | Yamaha Mg12-4fx 12-Channel Mixer with...
JVC TH-M45
no, u cant use the speakers with other normal DVD player because it wont have amplification for the speakers... u can use the sub to other dvd player because its inbuilt 120 watt woofer. ur dvd player is 5-disc player as wel as 120 X 2 and 80 X 3 watts amplifier (AV receiver ).... so just the JVC better sound thru the sub and speakers... ENJOY
kanny_amancha@yahoo.com
www.kanny-sounds.blogspot.com
Jan 24, 2009 | Pioneer 1000 Watt 5.1 Surround Sound...
Subwoofer feedback, and no sound
Hi
Take it back and get another if you can.
Jan 01, 2009 | Coby DVD-755 System
I've just got a tascam dp01cf recorder and i'm having trouble with it, its abit hard to understand what to plugs in were, i'm using a electric guitar,a yamaha magicstomp effect pedal and a amp. also i'm...
You have a couple of options with your guitar input. You can either plug your guitar directly into the right (Hi-Z) input and use the Tascam's onboard effects with it instead of your effect pedal.
You can put your pedal in the chain between your guitar and the (Hi-Z) input. So guitar into pedal is, pedal out into Tascam Hi-z in. (Still doesn't use the amp).
Or my preferred method for recording guitar would be to mic the amp. In that case you'd just input a microphone (placed about 8-12 inches from your amp) and record your guitar that way. The mic would be plugged into either one of the Tascams two mic inputs to record the amps speaker output while your guitar, pedal and amp would just be hooked up in the normal way.
Please note: Never plug the output from an amp into any of the Tascams inputs. Those inputs are line-level and the speaker output level which comes out of an amp out would damage your Tascam.
To get a backing song into a track in your Tascam, you'll have to first, using a PC, get the song into a 16 bit mono Wav file format. Then you'll have to use the USB import function to copy that wav file onto your Tascam onto the CF media cards fat partition. From the you'll be able to import it into the Tascam choosing which track it will import into.
Cheers,
BD
Apr 17, 2008 | Tascam 2488 Portastudio Multitrack...
Bose 3 2 1 GSX System Logo
236 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
