Question about HP OfficeJet 4255 All-In-One InkJet Printer
Help Urgent I'm trying to get my printer off fax so i can print from my computer but im unsure how to take my printer off fax. Every time I turn my printer on it comes up fax. I have tried to rstore the factory settings through my printer buttons but I still get the fax on the printer screen. I have even tried just pressing the fax button to try turn the fax off but no luck. PLEASE HELP AS THIS IS URGENT.
    Guru:
  • 731 Answers
Hi Natasha,
If the button settings didn't help, then try resetting the printer.I have mentioned all 3 kinds of resetting, try and let me know.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON button for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait until the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Remove the Ink Cartridges, then unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait until the ON light flashes,or wait for 20 seconds then release the button.If the printer goes off don't worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Thanks n Regards
Rizwan
rizwan84tx@gmail.com
Posted on Dec 07, 2008
I moved my computer from 1 room to another and im having a hard time getting the printer hooked up to my computer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/gKXn7F. Select your operating system, download and execute the file.
Oct 19, 2011 | Lexmark X4270 All-In-One InkJet Printer
Im having trouble printing to my lexmark x6650 all in one printer
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at . Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 30, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Minolta Fax 3900 problem at work
I have a Minolta Fax 3900 and it at times while trying to send a fax will say *tx cancel* and only send 2 pages of a fax. It appears like it does send the fax but it might not be the complete fax. I can't cancel the fax or stop it either. Does anyone know how to fix this problem.
Apr 22, 2010 | Konica Minolta Minolta FAX3900 Digital...
How do you print a fax report? HELP! URGENT!
1 Press the FAX button, then press the Menu button.
2 Press the < or > button to select PRNT REPORT/LIST, then press the OK button.
3 Press the < or > button to select ACTIVITY REPORT, then press the OK button.
The Activity report is printed.
Oct 31, 2009 | Canon PIXMA MX310 All-In-One Printer
My printer is not responding to my computer.
Go back into Printers and Faxes, delete your printer icon, restart your PC and reinstall your printer driver. Good luck.
Jul 01, 2009 | HP Hewlett Packard Officejet 7310 InkJet...
MP830 canon 3in1 scanner lock.
my mp830 will print, copy, fax but it will not scan to the computer. Please help
Sep 10, 2008 | Canon MP830 All-In-One Printer
Hp 5610 won't print
If you need Vista drivers for your printer, go to HP.com to get them and see if that works.
Jun 17, 2008 | HP Officejet 5610 All-In-One InkJet...
Fax report stuck in queue
try unpluging the power from the fax machine/
Jan 09, 2008 | HP Officejet 9110 All-In-One InkJet...
HP OfficeJet 4255 All-In-One InkJet Printer Logo
104 people viewed this question
Ben Johnson
