Question about Welding Tools
In my welding m/c Earth cable sime times brunout
We contious using that m/c but we check input & out terminal connection tightness were checked , winding insulation were also checked every thing okay but we can not find out that problem
  • 92 Answers
Was that "the earth cable burns out"- earth cables will burn out due to
1] the connections are loose and
2] the size of cable being used is too small,
increase the size of the earth cable, many manufactures fit a very thin cable to the set which are cheep and nasty, depending on the amperage used multiply by 11/2 times, tell your supplier what the sets maximum amperage on the set and he will give you the correct size. don't get it to long, and always get copper cable not aluminum.this also applies to the welding cable.
Posted on Jan 23, 2009
X300 want turn over after replacing battery and checked fuses. Make clicking sound when you try to start it
There's three things that spring to mind ..
One is a loose/dirty wire/connection from the battery positive terminal (the red cable) to the starter motor.
There's a problem with the starter motor itself - such as a sticking/dirty solenoid.
You have an earthing problem. Check the security/tightness of your battery negative terminal. Also check the cable itself - corroded/broken strands in the copper cable will cause an earthing problem.
Also check where the negative - black - cable attaches to an earthing point, which is usually the engine block or the gearbox housing. Undo the bolt that connects the black cable to the block, clean the cable terminal and mating face, then refit the cable/bolt.
The symptoms you describe are classic 'bad earth' problems.
A very quick check .. if you have a battery booster cable (you only need one...) .. connect one end to the battery negative terminal and attach the other end to any suitable earthing point on the block. If the car then starts, that's pointing at a 'bad earth' problem.
Sep 16, 2017 | Cars & Trucks
2014 Holden Barina radio turns itself off takes out the sound of the indercators and then it has shut down the whole dash and a last straw shut down the motor I have now had three radios put in
Hi i dont think the radio is the problem,I would be looking for a common denominator. If these isues are connected I would be looking at major power/earth connections starting at the battery.I believe the indicator tick sound comes through the speaker so if radio stops functioning no sound will come from the indicator.Check all earth terminals at battery and where it connects to chassis.Also check the positve terminal Lift the red plastic terminal cover and check all cable terminals are tight (use a small amount of force)some techs seem to miss this area because of the plastic cover. If all appears ok take it to Holden preferably when the no start issue is apparant. Good luck
Jul 05, 2017 | Holden Cars & Trucks
I have a 2004 Sea Doo GTI LE That clicks like a bad batt. I have a new batt installed. Ocassionally it will turn over like it should but only for a second. Any suggestions.
There is a bad connection at the battery terminals or cable connections, check the battery posts and cable terminals are shiny clean, check the earth cable is clean and tight at the chassis , check the cable to the starter motor is tight and clean, if all is good there the starter may be at fault.
Feb 27, 2017 | Cars & Trucks
Hi i have a mx 2002 holden frontera. car is dead no start, lights nothing. tried another battery still dead. any ideas on what to check
start at battery terminals
or the cables them selves
check earth to chassis connections clean and tight
check both cables are not broken or corroded at the terminals or starter
if terminal to old or not tight enough replace both with full brass
check all the large fuses in the engine bay cluster
Nov 03, 2016 | Holden Cars & Trucks
Is there any buttons on welder to get a earth I have brand new jasic 250 all set up but cant seem to get a earth no spark did I do something wrong
The welding rod lead has to go into the +ve while the current return which looks like a big alligator clip goes into -ve and is clipped to the metal object you wish to weld.
if you are using mig then check the little black switch under the left zero has been switched to mig.
there is a orange power switch thing on the back of the welder that needs to be checked also .
Jan 23, 2016 | Welding Tools
FIRST OF ALL I WANT TO THANK THE EXPERTS THAT ANSWERED BACK TO MY HONDA PROBLEM,BUT I STILL HAVENT HAD THE CHANCE TO FIX MY VEHICLE.OK THIS IS HOW MY PROBLEM STARTED.SOMETHING WAS DRAINING MY BATTERY SO I...
The fact that you've had no ignition or dashboard lights when you've turned the ignition key is mainly pointing to :
  • A failed battery.
  • A discharging battery via a failed alternator (the rectifier can burn out, causing the battery to rapidly discharge).
  • A 'bad earth'
Start with the easiest thing first. You say that your car started with a boost - a jump start - which suggests that your non-starting problem may be due to the battery or the 'earth'. When you connect another battery to your own via cables, your car is using the other car as an 'earth'.
A quick check - if you have battery jump cables - Connect a jump cable to your battery negative terminal - the earth terminal (black cable) and connect the other end to any suitable metal point on the engine/bodywork of your car, and try and start the engine. If it starts, it's now telling you that the problem is that of a bad earth.
A 'bad earth' can be caused by corroded cables- check both battery cables for a greenish/blue corrosion and/or broken strands in the wire.
Bear in mind that if you disconnect your battery you may lose your radio code. But .. loosen and turn each battery terminal to clean it and fully retighten. Then check the battery earth lead - the black cable - where it attaches to the engine/bodywork. Loosen and clean the cable and attaching bolt. If a car has a 'bad earth' it can cause sluggish/non starting problems.
If you're quite happy that the battery terminals, cables and earthing point on the engine/bodywork are clean, tight and ok ... suspect the battery.
Don't rush off and buy a new battery. Get somebody to jump start your car and then drive to a workshop and ask them to check it out whilst the battery is in situ - they can also check the alternator output at the same time.
Mar 11, 2017 | Honda Accord Cars & Trucks
Xterra won't start when the battery has juice free of corrosion and starter is freshly installed
Check the cleanliness and tightness of the battery terminals. Loosen, twist and retighten them. Also check the cleanliness and tightness of the black earth cable where it attaches to the engine block/bodywork. A bad earth can cause the symptoms you describe.
A quick check you can do is to connect a jump cable to the battery negative terminal - the earth - and connect the other end of the cable to somewhere suitable on the engine/bodywork.
If the car starts no problem with the jumper cable - it's pointing towards a bad earth/connection somewhere on the battery earth
Mar 14, 2017 | 2001 Nissan Xterra
Replaced battery, starter good, will not crank
Do the basics. Check that the battery terminal connections are clean and free of corrosion and that they are on tight. Check that the main relay is triggering when the ignition switch is engaged. follow the main cable to the starter motor and ensure that all connections are clean and tight. Check that the cable to the starter solenoid (sitting on the back of the starter motor body) has voltage when ignition is switched on. Check the condition of the earth strap between the engine and chassis and again ensure connections are free of corrosion and tight.
Dec 05, 2010 | 2004 Pontiac Grand Am
Engine turns over very slowy.
check battery connections are clean and tight check main engine to body earth cable for condition and security check connections at starter motor to check for engine earth problem put a good quality jump lead between bat neg terminal and engine crank and see if ok
Jan 22, 2010 | 1995 Land Rover Discovery
Hi, I have a murex tradesmig 160, when welding its like it loses its earth, but earth ok, some times get a good run, and then wont work. feeds wire but no power.
Look inside the unit (make sure the set is unpluged from the wall socket) and check the bolt that secures the cable to the socket, remove the bolt and clean the earth lead and the socket, check that the cable is ok and tight when refastend.
Oct 20, 2009 | Welding Tools
Welding Tools Logo
112 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
