Question about Refrigerators
Replacement light bulb for Avanti Refridgerator ???
I am looking or a replacement light bulb for my Avanti Refridgerator. When i first moved into my apt i just threw out the blown out bulb and now i finally have the time to replace it and i have no idea what it is.. i've bought a couple generic fridge light bulbs but they don't fit! the model # is RA758WT - 7.5 CU FT.
  • wexler1 Dec 11, 2008
    I'm looking for a light bulb for a two-door Avanti refrigerator, too.
SOURCE: Haier 1.7 CU Ft. Refrigerator - what is warranty
1 year parts and labor
Posted on Aug 17, 2008
SOURCE: Light bulb socket replacement for a really old Air Fare kitchen hood
The chances are that your range hood light socket was fully impacted with grease from cooking. Shut the power off to the range hood or, in many applications, simply unplug the power cord. Remove the socket. Get a spray can of electrical parts cleaner and saturate the socket through the tiny pin holes you may see at back of socket. shake out all of the cleaner fluid. Somehow hang the socket up with bulb base facing up all night. Hook it up. That might solve the problem.
It worked for me very recently on a 20 year old range hood.
DON'T USE ANYTHING OTHER THAN AN OFFICIAL ELECTRICAL PARTS CLCEANER. Most hardware stores, etc., have it.
Posted on Oct 24, 2008
daniel719
  • 240 Answers
SOURCE: EPSON POWERLITE BULB REPLACEMENT PROBLEMS
ok
look at your users manual.
all epson models need to have lamp life reset befor the lamp will light.
I have had this same problem befor.
Daniel.
Posted on Jan 11, 2009
SOURCE: 2003 Mercury Sable headlight bulb replacement
This problem is now resolved, thanks to a prior post by sableowner.
http://www.fixya.com/cars/t1479995-2001_merc_sable_headlight_replacement
The 2003 Sable has the same headlight assembly and removal/replacement instructions as the 2001 Sable. Once I had this information in hand, bulb replacement was easy.
Posted on Jan 13, 2009
SOURCE: Kitchen Aid Superba Model KSRS22D
Hi-
The Kitchenaid Superba KSRS22D has 14.4 cu.ft. refrigerator space and 7.1 cu.ft. freezer space for a total of 21.5 cu.ft. Hope this helps... -Syren
Posted on Sep 13, 2009
Where is the fan located on a ra758wt avanti refridgerator
In the freezer compartment behind the rear inner panel
Oct 04, 2014 | Refrigerators
Has anyone had a Right tail light not working?
The CORRECT answer is... yes. Someone at some point in history has had a right tail light on some vehicle that was not working.
Swap the right bulb with the left bulb, see if the problem moves with the bulb or stays in the same corner of the vehicle. If the problem moves with the bulb, replace the bulb... even if this is already your second or third replacement. They're not all perfect when they're new.
If the problem stays in the same corner of the vehicle, use a test light to see whether power is there when it should be there. If it is, then look for a grounding problem. If not, look for a poor connection in the wiring harness between that socket and the left-side socket.
Aug 10, 2014 | Thule 2000 GMC Sonoma - Regular cab -...
Which kind of Refrigerator/Freezer accessories are availble for purcahse?
Here is a list of some popular accessories: 1.Ice and Water Filter. 2.Electric Water Filter Replacement, Built-In, Without Adapter 3.Universal Appliance Light Bulbs 4.Freezer Lock Key.
Aug 12, 2010 | Avanti Refrigerators
Not getting very cold
thermoelectric needs a good heat dissipation. Give the unit a good ventilation to dissipate the heat, you will cool the unit. The cooler the ambient, the cooler the box. Remember not to reverse the switch, you will get a heated box instead.
May 24, 2009 | Avanti Compact Thermoelectric Refrigerator
Avanti DG 241 BS gas range oven burner goes out and wwill not rel
You need to order parts from AVANTI.
http://www.avantiproducts.com/
Very disappointing customer service.
I have been waiting 6 weeks for a new thermostat. It will not
arrive from China until June -- I was originally told it would come in April. All AVANTI parts are from China and AVANTI in Florida is the
only dealer. I will never buy AVANTI again.
Feb 19, 2009 | Avanti DER24CSS-1 Electric Kitchen Range
Light bulb replacementR
A fridge light bulb is usually a 40 watt appliance bulb with a screw base. It is heavy duty to last in the temperature. If it is not easily accesible to unscrew and replace, there may be plastic cover to unsnap.
Dec 27, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Does it have a fan and is it running.
Dec 13, 2007 | Avanti EC15W-2 Compact Refrigerator
Refrigerators Logo
206 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
