Question about Ricoh CL3000E Laser Printer
Ricoh CL3000 Laser Replace Waste toner
Ricoh CL3000 Laser, replace waste toner, waste toner cartrige is empty. printer will not print? How do I reset unit?
  • 8 more comments
  • Stphen Gray Feb 18, 2007
    Thank you, it works fine now.
  • Sbtowner218 Jul 07, 2008
    I have used canned air to clean the place where the toner connects to the waste toner case and I'm still getting the same error message. please help
  • Anonymous Mar 12, 2014
    waste toner reset
  • Anonymous Mar 16, 2014
    Ricoh CL4000DN Laser Printer error365
  • Anonymous Mar 17, 2014
    Is the Ricoh c5100 a good printer?
  • Anonymous Mar 20, 2014
    Where can I find what type of toner to reorder
  • Anonymous Mar 21, 2014
    the toner has been replaced and it wants to replace it again
  • Anonymous Mar 23, 2014
    reset ricoh 1500 waste ink
  • Anonymous Mar 31, 2014
    waste toner life warning
  • 624 Answers
Couple of things to try: - If you just emptied the waste cartridge then you have to take the bottle back out and clean the insides as well. The sensor sees the toner on the walls and still thinks it?s full. FYI as typical the manufacturer recommends replacing the bottle with a brand new one. - If not that then you may have toner covering the optical sensor. Try blowing the area where the waste bottle attaches to the printer with canned air. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Feb 17, 2007
2 Suggested Answers
  • 624 Answers
SOURCE: Ricoh CL3000 Laser Replace Waste toner
This is a duplicate post, click this link to view the active posting: http://www.fixya.com/support/t134401-ricoh_cl3000_laser_replace_waste_toner
I am getting the Replace Waste Toner error on my Ricoh CL3000. I have already emptied and cleaned the waste container, and blew off the section of the printer I install the waste bottle onto, but I'm...
not a solution - but a problem... i emptied the toner waste bottle in my MPW2400 and a new error message appears...says there is no toner and it keeps dumping toner from the new cartridge until it is coming out of every orifice of the machine. What is that about?
Sep 06, 2011 | Ricoh CL3000E Laser Printer
Waste toner
You have to "tell" the printer that you have "emptied" the receptacle. Depending on the model of printer, you may either need to replace it, or use the controls on the printer to "logically" do a "reset" operation.
Apr 16, 2010 | Ricoh Aficio CL7200 Laser Printer
Replace waste toner. what does it mean?
open the cartriage their are a waste toner in your cartriage cleane the cartriage then use
Oct 03, 2009 | Office Equipment & Supplies
I need to empty or repalce the used toner bottle
Hello sir; You may open side door, you will find out a retangle plastic box that is the waste toner bottle, on the top of waste toner bottle have a green knob, just slide it to right, you can remved it and dump it out.
May 18, 2009 | Ricoh Aficio CL3500N Laser Printer
Waste toner disposal procedure
It's not recommended to empty this as it contains 4 colored toners and you would heve to ensure that the light sensor sees completely clear in the view area. Replace the bottle with type 155 waste toner bottle (about $25) from on line supplier. To do this is simply a matter of opening the right side cover and sliding the green lock lever to the unlock position. Then remove the bottle and replace. Don't forget to slide the green lock lever to the lock position and close the cover.
Nov 18, 2008 | Ricoh Aficio CL2000 Laser Printer
Replace Black PCU
open rhs panel, lift flap, remove waste toner container and then slide out black pcu.
Oct 16, 2008 | Ricoh CL3000E Laser Printer
We removed the waste toner bottle and it won't reset the error message
You will need to vacuum all the toner out as in the machine there is a sensor that looks through the waste tank and checks that it is clear. You can also wash the tank out then install it and you will not have the problem.
Thanks J
Jan 25, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh CL3000 Laser, replace waste toner displar unit will not print, waste toner cartrige is empty.printer will not print? How do I reset unit?
Feb 17, 2007 | Ricoh CL3000E Laser Printer
Waste Toner Light won't go off?
The waste toner is usually a bottle near the toner cartridge which collects excess toner powder from the cartridge. It is usually present in more heavy duty laser printers, not all printers have them as a replaceable supply. You would need to refer to your manual for replacement instructions, they vary from printer model. For this machine, the Waste Toner supply number is #420131. In the case of the first poster, my best guess would be there was spillage of toner on the sensors to detect the waste basket overflowing, hence why the error message is constant. This would require cleaning of the sensors, a relatively simple task but for proper access, the machine would need to be partially disassembles for thorough cleaning. It would be best done at a repair centre.
Aug 04, 2006 | Ricoh Aficio CL2000N Laser Printer
Ricoh CL3000E Laser Printer Logo
1,944 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
