Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20 won't come on
Green light comes on for a second or two once manually-no picture and two more times by itself still no picture only a blip of sound
  • thielectronick
    thielectronick May 11, 2010
    In some cases there are broken solder connections on the deflection/power board. If you can re-solder the board you may be able to fix. Look for burnt up parts, if you have them replace the board.
    Genius:
  • 1,139 Answers
This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 08, 2008
My TV is an RCA D52W20 52 in. Rear Projection HDTV-Ready Television. When powered on the green power light will come on for a few seconds then go off and back on a few times before finally staying on. Once...
Hello
Actually the fault is with your TVs power supply section. If you want to locate the fault, and to repair yourself, you must have through knoledge in electronic, and skill to locate the faulty components. In short; you must be an experienced service technican to do this work. As power supply voltages will be high, and potential to touch, since all the components in that board will be "Live" while working, you must be very causous too. If you can inform me. I'll send you the service manual to your TV. Upon seeing its schematic, you can determine whether you can do this work by yourself or not. It is in Adobe PDF format document. So I cannot send that file to you by this window. If you want to get it, send your Email address to me by Fixya. Just see it, and determine what to do; whether try to work on it or get it repaired by some well experienced service technician. OK.
Oct 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
61" RCA DLP won't turn on after power blip
Hi, thank you for visit fix ya.
Do you havve problems with power supply capacitors.
Replace this:
2200uf 25V, 220uf 25V ( bowed or vented). Located beside power transformer.
Thank you
Jul 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 ( power works, but no picture.)
There are four bad capacitors on the sweep board in the power supply. Pretty hard to do yourself unless you have some experience.
May 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture
does the tv try for three times then go out or does it just light the led once then go out? Also is your model numbeer the D52W20? Please respond to this same post when replying.
Sep 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture
green light comes on, then go's right off
Aug 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
caypianan@yahoo.com
Jul 18, 2008 | RCA HD52W58 52" TV
RCA TV Will Not Power On - Powered Off Suddenly
Theses sets had 2 problems pip mod or most of the time Flyback Transfomer bad.
Jul 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv possessed by the devil
The d52w20 processor will shut the set down if it detect one of many problems. this processor generates an error log. technicains have computers that can read those errors. to help find out trouble.. common problems include bad horizont output. flyback and signal board. for the fact it comes on indicates to me power defection issues
Oct 19, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
99 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
